> delete post!, delete
post Jan 31, 2010 - 5:26 PM
mgnt232
Joined Mar 16, '09
I dont know if there is one or if someone has one on how to remove the rear bumper on a 94 ST hatch
thanks in advance people-
This post has been edited by mgnt232: Feb 3, 2010 - 8:08 PM
- 6GC for Life -
>Semper Fi<
1994 Cupra :p 3sgte
1995 Celica ST DD
1969 Chevelle SS
alllll balls. P2 approved!
post Jan 31, 2010 - 5:36 PM
ajmorris1977
Joined Jul 13, '09
QUOTE (mgnt232 @ Jan 31, 2010 - 6:26 PM) *
not sure if they are the same but its easy to do on the vert, behind the lic plate panel is a few bolts and three on each side by the wheel well, and its off!
You're here for a good time, not a long time. - Colin McRae
When in doubt... Flat out! - Colin McRae
Understeer is when you hit the wall with the front of the car.
Oversteer is when you hit the wall with the rear of the car.
Horsepower is how fast you hit the wall.
Torque is how far you take the wall with you....
post Jan 31, 2010 - 5:56 PM
yarik83
Joined Nov 22, '04
From FL
On coupes they also glued bumper to the car so you might need a knife to pry it off.
Captain Pessimist
post Feb 1, 2010 - 3:55 AM
malpaso
Joined Feb 3, '06
From Czech Republic (Europe)
If I remember right there are:
- plastic clips just below tail lights (you must remove tails to see them) - easy to remove.
- row of about 5 screws from the bottom side (visible) - for 80% rusted as hell and you will need to cut them (nip them off) and re-drill when installing bumper back.
- 2 screws on each side at fender area (you must remove plastic from the trunk to see them) - you probalbly would need some adapter to get there because there is not much space... you will see.
post Feb 1, 2010 - 1:00 PM
mgnt232
Joined Mar 16, '09
Thanks guys ill post up if I have any problems.
the only thing i need to know is which plastic do i take out from the trunk the very back piece or the two side back pieces?
and I wont ahve to take off the inner wheel well? like the front bumper?
QUOTE (malpaso @ Feb 1, 2010 - 4:55 AM) *
- 6GC for Life -
>Semper Fi<
1994 Cupra :p 3sgte
1995 Celica ST DD
1969 Chevelle SS
post Feb 1, 2010 - 1:37 PM
...the very back part. There is no inner trim on the rear, all bolts are from the inside or under
1) remove tails (3 bolts per side)
2) remove license plate trim
3) remove bumper ( sides, top and bottom)
This post has been edited by playr158: Feb 1, 2010 - 1:38 PM
post Feb 1, 2010 - 4:17 PM
mgnt232
Joined Mar 16, '09
Ok thanks
On the under side of my rear bumper there are like 5 bolts(running in line across the bumper), or well used to be bolts there, all the bolt heads were broken off by the previous owner. Is there anyway to get those broken bolts out?
QUOTE (playr158 @ Feb 1, 2010 - 1:37 PM) *
- 6GC for Life -
>Semper Fi<
1994 Cupra :p 3sgte
1995 Celica ST DD
1969 Chevelle SS
post Feb 1, 2010 - 5:15 PM
jimmykay
Joined Jul 14, '08
From St. Louis
Question
QUOTE (mgnt232 @ Feb 1, 2010 - 3:17 PM) *
Answer
QUOTE (malpaso @ Feb 1, 2010 - 2:55 AM) *
'99 Celica GT - Sold
'11 Mazdaspeed3
post Feb 1, 2010 - 5:18 PM
Question: slightly off-topic, but do mechanics have manuals for each car? It's not a lot of work, but that's more work than I thought. Let's just say I had to bring my car to a shop to get the bumper repainted, that's a lot of stuff for them to remove.
'90 MX-5 Mariner Blue
'15 Optima Grey
'04 206 GTi silve
post Feb 1, 2010 - 6:49 PM
QUOTE (SwissFerdi @ Feb 1, 2010 - 5:18 PM) *
they have an electronic catalog for each vehicle (in the case of paint) that can show parts (exploded diagrams) ect. But this is why mechanics go to school and study these things. removing a bumper is easy in the grand scheme of car systems.
post Feb 1, 2010 - 9:57 PM
I didn't expect them to have to get into the car, I thought the 5 screws at the bottom (and some tabs toward the top) only held the bumper on.
'15 Optima Grey
'04 206 GTi silve
post Feb 2, 2010 - 1:53 AM
mgnt232
Joined Mar 16, '09
I just dont understand how to redrill them? I guess.. i know it prob. sounds stupid lol. Do i drill right into the old bolt? how do I get it to thread?
QUOTE (jimmykay @ Feb 1, 2010 - 5:15 PM) *
Question
Answer
- 6GC for Life -
>Semper Fi<
1994 Cupra :p 3sgte
1995 Celica ST DD
1969 Chevelle SS
post Feb 2, 2010 - 10:59 AM
yes you would drill into the old bolt. and you can use and extractor bit set (google it, or look on sears.com) to remove the bolt or a tap die set (again google this, or sears.com) to rethread.
Honestly you don't even need the bolts under the car on the bumper....they are just excess weight anyways laugh.gif
Lo-Fi Version Time is now: August 9th, 2026 - 1:04 PM
