Apr 23, 2010 - 2:32 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 26, '09 From Albuquerque, NM Currently Offline Reputation: 19 (100%) |
I filled it up to where the oil level was about 3/4 to the full line about 2-3 weeks ago and now, the oil level is about 1/4 to the low line. That's half a quart in 2-3 weeks. Is that normal??
June '12 COTM '95 AT200 |
Apr 23, 2010 - 2:40 PM
that seems to be common in such an older engine, read this
http://www.6gc.net/forums/index.php?showtopic=72502 -------------------- 2001 Celica GT-S Turbo
Apr 23, 2010 - 3:07 PM
that seems to be common in such an older engine, read this http://www.6gc.net/forums/index.php?showtopic=72502 So from what I took from this, cleaning the ring lands and replacing the valve guide seals should do the trick? what if I don't do that and my motor just continues burning oil and I just add oil as needed. Will that hurt the motor? -------------------- taking too long to mod since '09
Apr 23, 2010 - 3:32 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 30, '04 From So Cal Currently Offline Reputation: 13 (100%) |
Same here.
169,000 original miles engine. I add 1 quart at around 2000 miles after oil change. I've been told it is OK. But I really do want a solution to this. -------------------- |
Apr 23, 2010 - 7:50 PM
Same here. 169,000 original miles engine. I add 1 quart at around 2000 miles after oil change. I've been told it is OK. But I really do want a solution to this. Mine only has 89,000 original miles, that's why it's got me worried. -------------------- taking too long to mod since '09
Apr 23, 2010 - 8:10 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 10, '06 From Greensburg,PA Currently Offline Reputation: 27 (94%) |
7afe is known to burn oil... just the way the engine is... if you keep refilling it, not too much damage can occur, your 02 sensor might go bad a little quicker than normal, cat will have less life as well... nothing too dramatic, fixing involves a full engine rebuild
-------------------- Breaking Axles...
Apr 24, 2010 - 1:11 AM
7afe is known to burn oil... just the way the engine is... if you keep refilling it, not too much damage can occur, your 02 sensor might go bad a little quicker than normal, cat will have less life as well... nothing too dramatic, fixing involves a full engine rebuild My cat is dead. I don't pass emissions in Cali lol -------------------- |
Apr 25, 2010 - 6:00 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 22, '07 From Houston, TX Currently Offline Reputation: 4 (100%) |
7afe burns oil. its face. just check/add oil when u add gas. u should anyway lol
Apr 26, 2010 - 1:58 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 7, '09 From Northern kentucky Currently Offline Reputation: 8 (90%) |
i run high mileage oil and i still burn oil, its just the engine, keep an eye on it and you will be fine
-------------------- 1996 Toyota Celica Project Mean Green
3RD Gen 3SGTE WRC Edition W/LSD E153 - Love BOOST <3 2001 Solar yellow Lexus IS300 2001 Dodge ram 1500 Off-road edition |
Apr 26, 2010 - 2:50 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 18, '09 From Orlando Currently Offline Reputation: 8 (100%) |
I do not burn any oil, neither do I run synthetic.
'90 MX-5 Mariner Blue '93 MX-5 LE '07 Kawasaki Eliminator 125 silver '15 Optima Grey '04 206 GTi silve |
Apr 26, 2010 - 6:31 PM
usually a valve seal issue on the toyota engines as they age.
Apr 26, 2010 - 10:03 PM
usually a valve seal issue on the toyota engines as they age. Is this pricey to fix? -------------------- taking too long to mod since '09
Apr 26, 2010 - 10:08 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 30, '02 From San Juan, PR Currently Offline Reputation: 4 (100%) |
Weird. My 7A-FE never burned oil, and my sisters 4A-FE also doesn't burn oil. Mine has 48,000 miles and she's at 70,000, so I guess this happens to higher-mileage engines then. But it shouldn't happen so early, unless the engine gets abused and doesn't get properly mantained.
Apr 27, 2010 - 12:00 AM
swiss your car is still a baby, mine has 164xxx miles on it, this is why mine burns oil, and oobe, your car is also still a baby so you shouldnt have these problems
Apr 27, 2010 - 2:13 AM
Enthusiast ![]() ![]() Joined Jul 15, '08 From Norway Currently Offline Reputation: 5 (100%) |
Its important to not rev the 7A-FE as it is cold. If you drive like an ass, the engine will at last burn oil like that.
So why is it burning oil? Well, the main problem is the oil rings on the pistons. These will stick, and not work, which make the oil come through to the top, and get burned. The valve seals is known to make the oil burn too, but I really think the oil rings is the main problem. Did the rebuild on mine, and it is expensive. Especially here in Norway... But it is totally worth it, and my engine have never burned oil since i did it. (1 1/2 year ago) You can do the rebuild yourself, to save some cash. Good luck though! |
Apr 27, 2010 - 7:49 AM
Its important to not rev the 7A-FE as it is cold. If you drive like an ass, the engine will at last burn oil like that. So why is it burning oil? Well, the main problem is the oil rings on the pistons. These will stick, and not work, which make the oil come through to the top, and get burned. The valve seals is known to make the oil burn too, but I really think the oil rings is the main problem. Did the rebuild on mine, and it is expensive. Especially here in Norway... But it is totally worth it, and my engine have never burned oil since i did it. (1 1/2 year ago) You can do the rebuild yourself, to save some cash. Good luck though! I was told exactly that, oil rings and valve seals. I just don't have the experience to do it myself -------------------- taking too long to mod since '09
Apr 27, 2010 - 8:20 AM
Maybe they can help you out!
No problem of helping. Just ask in this thread again, and I will gladly help you out. Good Luck! This post has been edited by AnaXyd: Apr 27, 2010 - 8:21 AM |
Apr 27, 2010 - 5:57 PM
happens a lot in older engines or high mileage ones. usually the culprit is valve seals. Like pit said, something that people usually don't worry about mostly because it does not cause too much damage and its a lot to rebuild anyways.
| Lo-Fi Version | Time is now: September 20th, 2026 - 12:28 AM |
