Jul 15, 2010 - 6:09 PM
Enthusiast ![]() ![]() Joined Aug 29, '08 From Auckland, New Zealand Currently Offline Reputation: 0 (0%) |
title says it.
Also if i can change it will i need to remove the whole dizzy to do it? is there a write up? Or even a quick how to would be much appreciated. Thanks, Paul |
Jul 15, 2010 - 6:23 PM
Enthusiast ![]() Joined Apr 9, '10 From raleigh n.c. Currently Offline Reputation: 1 (100%) |
i think you have to replace the whole distributer
Jul 15, 2010 - 7:03 PM
Enthusiast ![]() ![]() Joined Mar 28, '10 From Columbia, South Carolina Currently Offline Reputation: 1 (100%) |
You have to remove the dizzy, but you don't have to replace it. when you take the cap off, you'll see the ignition coil. There will be 2 nuts holding the wires on, and 4 phillips head screws on the bottom holding the coil to the distributor(you can't access those screws with the distributor on, that's why you need to take it off) and then boom, the ignition coil comes right out. I've got a spare coil if yours is fed speced.
-------------------- ![]() 1994 Celica GT, coupe, 5 speed. Front strut brace, cherrybomb glasspack, intake. |
Jul 15, 2010 - 7:26 PM
oh good. Really glad i dont need to get a whole new dizzy as i just replaced the cap and the rotor 3 days ago. Ill have to check what type is needed and see how much they are around here as im in Nz lol. Thanks Sleek, thats exactly what i was looking for
Jul 15, 2010 - 7:36 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 22, '07 From Houston, TX Currently Offline Reputation: 4 (100%) |
no, but replace the oil seal
Jul 15, 2010 - 7:41 PM
is that the distributor gasket?
Jul 15, 2010 - 7:49 PM
no. its probly called oil seal, or oring... diff from the gasket
Jul 15, 2010 - 8:06 PM
ok, thanks for all the help
Jul 15, 2010 - 10:30 PM
It's an O-ring on the distributor shaft(on the side that connects with the camshaft). You can't miss it.
| Lo-Fi Version | Time is now: September 15th, 2026 - 4:13 PM |
