Jul 19, 2010 - 11:37 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 26, '09 From Albuquerque, NM Currently Offline Reputation: 19 (100%) |
I know it'll fit my 7A, but it doesn't have the little "will fit Celica" fine print so I just wanna clear it before I spend money on it because that put the 0.01% of doubt in my mind that'll make me uneasy. Thanks guys.
http://cgi.ebay.com/ebaymotors/TOYOTA-CORO...sQ5fAccessories -------------------- taking too long to mod since '09
June '12 COTM '95 AT200 |
Jul 19, 2010 - 1:00 PM
Enthusiast ![]() ![]() Joined Jun 18, '08 Currently Offline Reputation: 3 (100%) |
Yes that will fit your ST. The engines are the same...but I'm sure you already knew that
Jul 19, 2010 - 1:25 PM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Mar 8, '08 From Orlando, Florida Currently Offline Reputation: 14 (100%) |
isnt this the one that ends up like 2 inches short from bolting to the existing flange under the car??
-------------------- ◊◊◊ My F/S Thread! ◊◊◊
Jul 19, 2010 - 1:50 PM
Enthusiast ![]() ![]() Joined Jul 23, '09 From Fresno, Ca Currently Offline Reputation: 6 (100%) |
Jul 19, 2010 - 2:00 PM
isnt this the one that ends up like 2 inches short from bolting to the existing flange under the car?? All the 7a headers do lol. A local exhaust shop will do the job to make it fit for $30. Thanks guys! The engines are the same...but I'm sure you already knew that I sense sarcasm, sir. Lol -------------------- taking too long to mod since '09
Jul 19, 2010 - 2:36 PM
Enthusiast ![]() Joined Oct 16, '09 From Norway Currently Offline Reputation: 0 (0%) |
Mine did not fit against the block, because the oil filter was in the way, so i couldn't get the header close enough to the block to get it tight.
Jul 19, 2010 - 3:01 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 2, '07 From Berlin, WI Currently Offline Reputation: 18 (100%) |
hmm... never heard that happening before. Was yours like that one too? there's a bunch of them on ebay. never really know which is a good one though.
-------------------- ![]() *1997 Celica ST - 3SGE Greytop BEAMS *1977 Celica RA29 - Classic Cruiser *2005 Matrix AWD - dedded but still hanging around like a ghost 2019 Rav4 XLE Premium - Sports mode is fun. |
Jul 19, 2010 - 5:00 PM
Jul 19, 2010 - 7:48 PM
you must have gotten a wrong one then or be using a larger/longer than stock filter.
Jul 19, 2010 - 7:52 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined May 29, '09 From Gainesville, FL Currently Offline Reputation: 17 (100%) |
My ebay headers from Race daddy or some junk like that, bolted right to the block. As said, it was short from the second cat, and had to have it welded. Cost me 75 bucks.
This post has been edited by rave2n: Jul 19, 2010 - 7:52 PM |
Jul 19, 2010 - 8:24 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 16, '09 From New York Currently Offline Reputation: 23 (100%) |
mine was from race daddy too! but mine was a worse fitment lol.
All the holes on the header to the block were too small, had to drill them out. came out about 8" short from the 2nd cat, and I had to cut off the piece at the very end of the downpipe, because the "in" on the cat is 1.75" and the piece at the end of the headers downpipe is 2". So I had to cut it off to make it sit flush, and just used some cheap exhaust sealer and extended the pipe obviously. If you do it your self it ends up a $20 project for piping and sealant -------------------- |
Jul 20, 2010 - 12:57 AM
Enthusiast Joined Jul 20, '10 From US Currently Offline Reputation: 0 (0%) |
I know it'll fit my 7A, but it doesn't have the little "will fit Celica" fine print so I just wanna clear it before I spend money on it because that put the 0.01% of doubt in my mind that'll make me uneasy. Thanks guys. http://cgi.ebay.com/ebaymotors/TOYOTA-CORO...sQ5fAccessories I think so -------------------- |
| Lo-Fi Version | Time is now: September 2nd, 2026 - 10:05 AM |
