Aug 29, 2010 - 6:21 PM
![]() Enthusiast ![]() ![]() Joined Nov 19, '07 From las vegas Currently Offline Reputation: 0 (0%) |
Im planning to put in a kill switch connected to my fuel pump. Does anyone know which wire color is what and directions on how to install it? thanks
This post has been edited by aznpnoiboi55: Aug 29, 2010 - 6:22 PM -------------------- ![]() |
Aug 29, 2010 - 8:27 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 3, '04 From Portsmouth, RI Currently Offline Reputation: 33 (100%) |
if you just turn the key all the way to the left (with the ebrake down since you have a turbo timer) that should work pretty well...
This post has been edited by hurley97: Aug 29, 2010 - 8:28 PM -------------------- |
Aug 29, 2010 - 9:46 PM
sorry im not sure how this will work as a kill switch....
This post has been edited by aznpnoiboi55: Aug 29, 2010 - 10:15 PM -------------------- ![]() |
Aug 30, 2010 - 4:40 PM
ohh i c ....i just read that the hks turbo timer that i have has a kill switch function....but how do i activate it? because even if i had the ebrake in down position it still turned on when i pressed the clutch and brake.
Aug 31, 2010 - 10:38 AM
Enthusiast ![]() ![]() Joined Apr 24, '07 From CA Currently Offline Reputation: 1 (100%) |
I was wondering this too, any one who has ever replaced their fuel pump know which wire is the power?
-------------------- QUOTE what hes saying is if you put blue lights in you car youll lose hp. |
Aug 31, 2010 - 10:48 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined May 10, '10 From MA Currently Offline Reputation: 37 (100%) |
this is just a thought, but get a meter, unplug the wiring from the pump and touch it to each one and it'll tell you which one has power
Aug 31, 2010 - 9:28 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 18, '05 From Lincoln, Ar Currently Offline Reputation: 7 (100%) |
This is for a ST model, but it might be the same for the GT.
Right next to the ECU there is a Circuit Opening Relay ( COR). Its a pretty big relay with 5 wires. I don't have a repair manual anymore so I can't tell you what wire it is. But this is how it works- 12V from Fuse in Engine bay, 2 wires for ground, usually W/B or W. 12V from ECU. Tells the relay to turn on the fuel pump. 1 wire to Switch Fuel pump on. If you have the wiring diagram you can pin point the COR for that wire and solder in a kill switch. |
Sep 1, 2010 - 1:39 PM
I just downloaded the service manual for our 6gcelicas and i was looking through the wiring diagrams. I think its a black and blue wire is the power because when looking at the diagram, the only wire that was showing connected to the fuel pump is a black and blue wire. The only problem is that I dont have any of the tools to check if its the power. If anyone can confirm this for me that would be great.
This post has been edited by aznpnoiboi55: Sep 1, 2010 - 3:00 PM -------------------- ![]() |
Sep 3, 2010 - 3:03 PM
One way to make sure is to check the wires going into the fuel pump. You can do this by lifting up the carpet behind your back seat.
| Lo-Fi Version | Time is now: August 24th, 2026 - 1:39 AM |
