> 95 GT Auto tranny problem
post Nov 12, 2010 - 11:31 PM
Arsaces
Joined Oct 7, '10
I just got home from a drive outside and was trying to figure out what could possibly cause my car to shift the way it did:
It is cold outside, car has 140k on it, I am not original owner and therefore know nothing about the transmission's maintenance history.
After driving 5 minutes or so, I floor the gas off of a red light, the car gets to about 5800, makes a very feint "pop" and then shifts, continues to 5800 again, shutters, acts like it is going to shift but does not shift. So now I am still presumably in 2nd gear, rpms are slowly lowering themselves, but I am still above 5k rpm. I was flooring the gas but the rpms were not going up, they were slowly going down. I am very unsure of what is going on with the shifting issues there.
When the above happened I let my foot off the gas for a second then pushed back on and it shifted itself, I stopped for another red light and when it hit green I drove normally and everything shifted and acted fine. I figure that if the 3rd gear has a problem it would show itself under both driving conditions not just at high rpm. I have only had the car for 1k miles and so I am working on replacing things bit by bit.
Any help is much appreciated.
Replies (1 - 4)
post Nov 14, 2010 - 3:43 PM
sounds like the auto trany is gving out. solenoids? maybe. replace
post Nov 14, 2010 - 4:16 PM
Spider77
Joined Jan 17, '08
From JB MDL, NJ
I would jumper it and check for codes....but year, sounds kinda like shift solenoids. But the first thing I did when I got mine was do a total drain and change...even though I knew for a fact the Celica was cared for, I wanted to make sure.
post Nov 15, 2010 - 1:41 AM
Arsaces
Joined Oct 7, '10
What do you mean by jumper it? And if there is no check engine light could there still be codes? Also to update this thread I drove the car the next day and did the same thing, I waited about 10 minutes to do it instead of 5, and it shifted fine. I really hope the tranny is not going bad, I just bought the car and it would suck to have to sink more money into it than I already have, Also do you think I should go ahead and replace the tranny fluid and seals/filter, I have no idea how long it has been since that has been done since I have only had the car for 1k miles.
post Nov 15, 2010 - 6:00 AM
Spider77
Joined Jan 17, '08
From JB MDL, NJ
Nah, it'll flash on the OD signal, not the CEL light.
Lo-Fi Version Time is now: August 23rd, 2026 - 4:13 AM
