> ADVICE PLEASE fuel rail, i need some knowledge
post Dec 9, 2010 - 1:51 AM
azn87
Joined Aug 2, '06
From bay area
i need some knowledge regarding the fuel rail. ive bought an after market fuel pressure regulator for my turbo set up that im trying to do. i havent taken it apart yet because this is my daily driver for a while. so basicly i need to know what i can use to bolt up to the stock rail, or should i go aftermarket (if they make them for our car)??
post Dec 9, 2010 - 2:11 AM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
Remove stock fpr, thread new on in. If the threading is different get some lines and fittings to make it fit.
94 Celica gt white (sold)
post Dec 9, 2010 - 2:13 AM
azn87
Joined Aug 2, '06
From bay area
i know that but i need to know what fitting it is, so when i do take it apart im not stuck. like i said this is my daily driver
post Dec 9, 2010 - 9:29 AM
QUOTE (azn87 @ Dec 9, 2010 - 1:51 AM) *
why did you get an FPR, you really dont need one on a basic 5sfte, unless your going all out.
unless its a bolt in affair (99.9% of the ones i've seen are not) your gonna need a bunch of fittings and lines to complete the install.
which FPR did you buy?
post Dec 9, 2010 - 9:30 AM
czwalga
Joined Sep 27, '10
From pittsburgh
Isn't it a banjo bolt/fitting? I know atleast on the fuel filter it is. What line are you planning on running from the fpr to the rail.
-93 Rx7, Turbo 6.1L v8, 725rwhp/760rwtq
-95 Celica GT Rally Car - 3sge/AWD
-10 F150
Always buying stock wheels... PM me if interested in selling.
post Dec 9, 2010 - 10:35 AM
Smaay
Joined Dec 8, '03
From Lancaster CA
the regulator screwes right into the rail and the return line comes out of teh regulator. the easy way to do this is take off the rail and take it to a speed shop that carries XRP fittings. just find the right fitting for teh rail and runa new line the the FPR, then a new line out of the regulator to the return line.
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Dec 9, 2010 - 10:38 AM
mkernz22
Joined May 10, '10
From MA
it's probably not a good idea to do this on a daily driver because changing out certain parts can take a couple days.
post Dec 9, 2010 - 11:46 AM
azn87
Joined Aug 2, '06
From bay area
QUOTE (presure2 @ Dec 9, 2010 - 6:29 AM) *
i bought a sard fpr. (69011 with 6 an fitting)
QUOTE (czwalga @ Dec 9, 2010 - 6:30 AM) *
im not sure thats y im asking, so i know what im getting my self into before hand
post Dec 9, 2010 - 2:07 PM
ok googled what you have, your gonna have a couple ways you could set it up.
depends on what you want to do.
the fuel filter and rail are both 12X1.25 metric fittings.
you will need 6an to 12X1.25 fittings for the fuel filter and rail, 6an hose, and appropriate hose ends depending on where you locate the FPR.
im not sure on the return size for that particular one (it should say in the instructions) but a 4an push fit fitting with appropriate line, or the stock one depending on where you locate the FPR works perfectly for the return to the tank.
::edit::
looks like your also going to need a gauge to mount with it to set and monitor fuel pressure as well.
and again, just FYI, this stuff is all not needed for a 5sfte, your pretty much gonna spend a couple hundred getting this all setup, and complicate it with things that you dont really understand for no power gain at all.
post Dec 9, 2010 - 8:50 PM
azn87
Joined Aug 2, '06
From bay area
But it work make it a lot easier for tuning right??
post Dec 9, 2010 - 9:02 PM
mkernz22
Joined May 10, '10
From MA
why do you need to tune the fuel?
if you're going to turbo it, it would be a lot more cost effective to get a 3sgte.
if you turbo the 5s why not just get an upgraded fuel pump?
post Dec 9, 2010 - 9:27 PM
Johnnyny
Joined Apr 28, '09
From York pa
QUOTE (mkernz22 @ Dec 9, 2010 - 9:02 PM) *
he is not gonna tune the fuel but the air to fuel ratios and map setings for best performance and 0 knock
cost effective sure 3 is better but op chose a diff route
he obviously has to upgrade fuel pump as stock one will not suffice i think you are a bit confused about this thread he is taling about the fuel press reg
This post has been edited by Johnnyny: Dec 9, 2010 - 9:30 PM
post Dec 9, 2010 - 9:28 PM
azn87
Joined Aug 2, '06
From bay area
ok basicly im going to get walbro 255, 540 injectors, 3s manifold, custom down pipe, side mount intercooler, stand alone, 3s oil pan, an a couple of other things that i cant remember. when the time comes im going to do a rebule on the motor, with arp head studs, and head gasket, redo all the seals and maybe new valve springs, retainers and rockers
post Dec 9, 2010 - 10:23 PM
mkernz22
Joined May 10, '10
From MA
totally missed the regulator part. :facepalm:
post Dec 9, 2010 - 10:42 PM
azn87
Joined Aug 2, '06
From bay area
because I've already got one. What I need to know is what size is the rail. I understand the the thread pitch is 12x1.25 but how big
This post has been edited by azn87: Dec 9, 2010 - 10:46 PM
post Dec 10, 2010 - 7:26 AM
QUOTE (azn87 @ Dec 9, 2010 - 9:28 PM) *
you really need to step back, and research before you buy anything else.
the FPR is usless on a 5sfte.
you dont need to mess with your fuel pressure, your only gonna complicate your setup, and make a good spot for a fire to start.
540cc injectors will choke out a 5s on a stock ecu.
BTW, 3s injectors will not work on a 5s.
if you think a 5s has "rockers" you need to forget about turbos for now, and learn about your motor first.
good luck. im out.
post Dec 10, 2010 - 7:46 PM
azn87
Joined Aug 2, '06
From bay area
im not using a 5s ecu, im getting a stand alone, and im also going to learn about the motor as i go along, i thought 6gc was a place to help each other. people are right, people are dicks
This post has been edited by azn87: Dec 10, 2010 - 7:57 PM
post Dec 10, 2010 - 7:57 PM
mkernz22
Joined May 10, '10
From MA
QUOTE (azn87 @ Dec 10, 2010 - 7:46 PM) *
i thought 6gc was a place to help each other. people are right people are dicks
manny's (pressure2) knows what he's talking about. he knows this sh!t like the back of his hand.
they're trying to help you by telling you one thing and you're disregarding it.
Edit: Sorry if I sound like an dick.
Whenever you ask people for help or a decision about something, you are always going to get positive and negative feedback from people.
You just have to take it all it, consider your options, and make the decision based off how you feel.
This post has been edited by presure2: Dec 11, 2010 - 7:48 AM
post Dec 10, 2010 - 8:32 PM
Johnnyny
Joined Apr 28, '09
From York pa
most ppl who ask for help want there whole swap/ build to be done by others on here and dont read one sticky dont search ever u never mentioned u were going stand alone are others supposed to guess what u are and arent going to do with your build he wasnt being a dick just saying the truth if you dont know what you are getting yourself into research it first it will save you massive headaches no need to start crap for no reason
QUOTE (mkernz22 @ Dec 10, 2010 - 7:57 PM) *
any if there's one thing to learn from all this, don't call out anyone on here, especially manny cause he will go ape sh!t on yo a$$.
peace.
post Dec 10, 2010 - 11:21 PM
azn87
Joined Aug 2, '06
From bay area
If u have read my list of stuff I'm going to get. It has my stand alone in there
Lo-Fi Version Time is now: August 22nd, 2026 - 8:12 PM
