Dec 24, 2010 - 1:52 AM
Enthusiast ![]() ![]() ![]() ![]() Joined Jun 25, '06 From Box Elder, South Dakota Currently Offline Reputation: 2 (100%) |
Just a question on radiators. Are the stateside GT radiators a somewhat perfect fit into the st205 chassis. I mean, they are the somewhat same chassis so i would assum so, as long as i use the GT4 rad hoses...am i correct on this assumption? Btw, i tried searching but didnt get much....
-------------------- (\__/)
Dec 24, 2010 - 11:58 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 3, '04 From Portsmouth, RI Currently Offline Reputation: 33 (100%) |
yes.
They both are 100% interchangeable, hoses and all. -------------------- |
Dec 26, 2010 - 7:14 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 11, '08 From Auckland, New Zealand Currently Offline Reputation: 0 (0%) |
ST205 and ST202 3S-GE radiator have identical part numbers just for the record.
-------------------- Mike W
Dec 27, 2010 - 5:19 AM
Enthusiast ![]() ![]() Joined Aug 29, '08 From Auckland, New Zealand Currently Offline Reputation: 0 (0%) |
Would an st205 radiator work with an st204?
Dec 27, 2010 - 5:27 AM
yes but is functionally the same, if you need a new radiator any 6th gen celica radiator will fit and work the same, if anything given a choice get the st202/st204 radiator as the st205 runs hotter so a radiator from an st205 will be alot closer to needing a new top tank than the radiator from an st202 or st204
Dec 27, 2010 - 5:40 AM
sweet. the radiator cap would be the same fit?? ivehad a radiator in from an st205 for almost 2 years now and its been slowly leaking coolant from somewhere up the top of the rad im thinking it may be the cap.
Dec 27, 2010 - 2:43 PM
rad cap should be the same. change it out, the seals warp over time.
| Lo-Fi Version | Time is now: August 21st, 2026 - 11:45 PM |
