Jan 4, 2011 - 9:20 PM
Enthusiast ![]() Joined Mar 1, '09 From fitchburg, ma Currently Offline Reputation: 0 (0%) |
I just noticed i never started a build thread here...lol...so here goes!
Starting from 1/1/11 (if you want to see from start to finish check it out here http://www.alltrac.net/phpBB2/viewtopic.php?f=44&t=22608 engine built and in the car already ENGINE 3sgte bored 20 over CP 9:0/1 pistons Eagle H beam rods & ARP bolts polished and balenced 3sgte crank ACL race bearing (rods and main) HKS GT3040 turbo (powdercaoted Purple metalic) 3" SS V-band conversion SS ramhorn ex manifold Tial 38mm ex wastegate custom SS down pipe 3" SS V-band conversion Finadanza flywheel 6 puck clutch new OEM bottom end gasket kit Powdercoated Purple metalic shaved OEM valve cover HEAD mild port and polish Engle valve springs new OEM valve seals HKS 272 cams HKS ajustable cams HKS kevlar timing belt Cometic head gasket RMR intake maini KO Racing phenolic spacer(TVIS deleted) BBK 70mm throttle body new OEM top end gasket kit new OEM water pump ATS high volume oil pump new OEM belt tensioner new OEM tensioner pulleys ARP head studs ARP flywheel bolts FUEL Speed-Source top feed fuel rail Presision 880 top feed injectors Aeromotive FPR Walboro 255 in tank fuel pump cusom SS fuel lines new OEM injector spacers & seals ELECTRONICS AEM EMS HKS turbo timer Inovative LC-1 wideband O2 Eclipse 7" double din DVD/CD Rockford Fosgate 500 RMS amp custom 12" sub enclosure (made by me) with MA Audio 12" XL 700 RMS dual coil sub INTERIOR Sparco racing seats Sparco seat mounts (side mount) KYO seat brackets Sparco harnesses Sparco Racer 2 steering wheel NRG quick release mount WHEELS & TIRES STREET Axis Decades 18x8.5 front and 18x9.5 rear Continetal contacts 225/35/18 front and 235/30/18 rear DRAG Rota Revs 17x8 Bridgestone Potenzas 225/45/17 1" spacer in the rear SUSPENSION K-Sport coilovers MISC CS/RC front bumper custom 3" FMIC and piping custom 4" intake Samco radiator hoses Cusco oil catch cam custom aluminum overflow (made by me) Speed-Source poly motor and tranny mounts Speed-Source SS clutch line 2's R us valve cover bolts Hallman maual boost controler MSD blaster coil MSD plug wires NGK one step colder plugs Goodridge SS brake lines ABS delete FUTURE PLANS Willwood BBK St205 rear brakes St205 rear LSD Cusco under brace Cusco rear strut brace Cusco front strut brace custom fabbed rollcage respray Toyota super Red OEM st185 floor matts CS/RC hood CCW Classics custom offset wheels On to the pics! Engine painted and assembled ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Powdercoated some parts ![]() ![]() HKS 272 cams, Engle valve springs and shimless bucket conversion ![]() ![]() HKS cam gears installed ![]() Then HKS true timing belt ![]() ![]() Findanza flywheel and ARP bolts ![]() st205 tranny mated to engine ![]() ![]() ![]() Speed-source brass shifter bushings ![]() New OEM coolent bypass hoses (hose from hell) ![]() Engine install ![]() ![]() Zaklee corp clear cam gear cover (waited over a year for this!) ![]() RMR intake manifold and BBK TB mock up ![]() ![]() That's all for now, update soon! should be done in a month or so |
alltracst185 alltracst185's All-trac build thread Jan 4, 2011 - 9:20 PM
Ted95 wow thats sexy broo, good workkk Jan 4, 2011 - 9:46 PM
alltracst185 Thanks! It has been a long expensive road but ... Jan 4, 2011 - 10:02 PM
HectortheRican I. Am. DIGGING. the clear belt cover. So sexy. Jan 5, 2011 - 2:13 AM
alltracst185 QUOTE (HectortheRican @ Jan 5, 2011 - 3... Jan 5, 2011 - 11:14 AM
4-eyed-freek looks so clean! nice work man! Jan 5, 2011 - 11:19 AM
presure2 looks great bro! that mated to the 205 tranny ... Jan 5, 2011 - 11:28 AM
alltracst185 QUOTE (presure2 @ Jan 5, 2011 - 12:2... Jan 5, 2011 - 11:37 AM
mak5603 Wow. Awesome 185 man, some quality parts for sure... Jan 5, 2011 - 12:16 PM
alltracst185 QUOTE (mak5603 @ Jan 5, 2011 - 1:16 ... Jan 5, 2011 - 6:16 PM
richee3 Wow, that's a long list of parts... Seems like... Jan 5, 2011 - 10:41 PM
alltracst185 When i got it in summer of 2004
Track setup
... Jan 6, 2011 - 10:22 AM
HectortheRican Honest opinion, you should get smaller around town... Jan 6, 2011 - 11:00 AM
alltracst185 Track wheels are 17x8 all around and the around to... Jan 6, 2011 - 4:36 PM
HectortheRican QUOTE (alltracst185 @ Jan 6, 2011 - 3... Jan 6, 2011 - 4:39 PM
DEATH Damn son - you just gave me engine envy
9.0:1? N... Jan 6, 2011 - 5:01 PM
alltracst185 QUOTE (DEATH @ Jan 6, 2011 - 5:01 PM... Jan 6, 2011 - 10:50 PM
epocsirhc What are your power goals? I love this man! Th... Jan 6, 2011 - 11:02 PM
alltracst185 QUOTE (epocsirhc @ Jan 7, 2011 - 12... Jan 7, 2011 - 6:45 PM
presure2 hey do you have a list of PT#'s for the abs de... Jan 7, 2011 - 7:21 PM
alltracst185 QUOTE (presure2 @ Jan 7, 2011 - 8:21... Jan 8, 2011 - 11:28 AM
cheela I want an alltrac! sucks trying to find them r... Jan 8, 2011 - 5:06 PM
mak5603 QUOTE (cheela @ Jan 8, 2011 - 6:06 P... Jan 8, 2011 - 6:15 PM
alltracst185 QUOTE (cheela @ Jan 8, 2011 - 5:06 P... Jan 9, 2011 - 1:40 PM
Smaay very nice! i cant wait till i get my All-Trac ... Jan 12, 2011 - 3:16 PM
alltracst185 QUOTE (Smaay @ Jan 12, 2011 - 4:16 P... Jan 13, 2011 - 11:48 AM
alltracst185 Ordered the last of my parts lastnight...should be... Jan 18, 2011 - 1:25 PM
presure2 QUOTE (alltracst185 @ Jan 18, 2011 - 1... Jan 18, 2011 - 1:55 PM
alltracst185 Dentsport, ESP, KTR, Connetic motorsports, synapti... Jan 18, 2011 - 9:13 PM![]() ![]() |
| Lo-Fi Version | Time is now: June 15th, 2026 - 9:28 AM |
