51 Pages V  « < 12 13 14 15 16 > »
> Green Bullet ST205 Re-Born, MODIFICATIONS, AND UPDATES!
post Jan 31, 2012 - 9:20 AM
bsamps4
Joined May 16, '10
From Raleigh
QUOTE (Ted95 @ Jan 30, 2012 - 10:07 PM) *
what kind of IC piping you looking to get?
i bought a couple ebay kit and it came out fine, but i wish i bought better quality piping.
I was just going to do an ebay kit as well. I'm kind of nervous about how it going to weld, but I've got my fingers crossed. It costs a TON of money to have one custom fabricated.
QUOTE (Neon90424 @ Jan 31, 2012 - 2:40 AM) *
where did u get the oil pump for a gen 3 from
www.lithiatoyotaparts.com
These guys are able to source a pretty large amount of gen 3 parts, and for the really hard to find stuff I used:
www.tcbparts.co.uk
post Jan 31, 2012 - 3:19 PM
Ted95
Joined Mar 8, '09
From Westport, MA
do you have a tig welder?
st205 powered ss3 coupe
post Jan 31, 2012 - 4:01 PM
bsamps4
Joined May 16, '10
From Raleigh
Yup, got a tig, mig, and torch.
post Feb 2, 2012 - 8:22 AM
bsamps4
Joined May 16, '10
From Raleigh
You can go ahead and assume that I'm an idiot, but I did some searching around on this site and google, but I still have a question, and it likely has a pretty common sense answer...
What oil filter are you guys using on your 3rd gen 3sgte? Is it just the 2nd gen filter that I can buy at any local toyota?
post Feb 2, 2012 - 4:43 PM
96stgreendemon
Joined Oct 7, '09
From Northern kentucky
Im just using a K&N filter from a 3SGTE mr2
2001 Solar yellow Lexus IS300
post Feb 2, 2012 - 4:47 PM
purplegt4
Joined Feb 7, '03
From Northern Virginia
post Feb 2, 2012 - 11:58 PM
Ted95
Joined Mar 8, '09
From Westport, MA
im running a mobile1 filter for a mr2 turbo. when you go to a parts store ask for one from a mr2 turbo, or you can get one from toyota as well.
post Feb 3, 2012 - 11:34 AM
bsamps4
Joined May 16, '10
From Raleigh
I figured that was the simple answer. Thanks for the responses guys.
Small update... I got my new oil pump installed, and the timing is all set to go. Just have the oil pans left.
post Feb 5, 2012 - 10:34 AM
bsamps4
Joined May 16, '10
From Raleigh
Two days ago, my roommate and I went to install the upper oil pan, and get the motor completely sealed up only to find that we had a big clearance issue.
These bolts right here stick down to low and were interfering with the oil pan, which was a HUGE set back. So we had to clean all of the FIPG off and modify the pan to fit. We took some measurements, and took a grinder to it.
After a S#%t load of cleaning between test fits we finally found success.
Motor is DONE!
post Feb 5, 2012 - 10:55 AM
lookin good dude!
post Feb 5, 2012 - 11:24 AM
'90 MX-5 Mariner Blue
'15 Optima Grey
'04 206 GTi silve
post Feb 6, 2012 - 9:38 PM
96stgreendemon
Joined Oct 7, '09
Ah memories..... Good luck with getting the motor in lol, what trans you using again? and i highly highly suggest getting poly motor mounts, soooo much better
post Feb 6, 2012 - 11:04 PM
Ted95
Joined Mar 8, '09
From Westport, MA
poly mounts are definitely worth it!
i got some info on the IC piping that we talked about last week, for my IC piping i needed 11 90* bends 2 180* and i believe 3 45* bends. i bought 2 ebay kits and was a 2 90* bends short so i had to get another 180* bend to make 2 90* bends.
this should help to give you an idea for what you might need for the piping.
post Feb 6, 2012 - 11:23 PM
Stambo
Joined Apr 23, '08
From Muskego,Wi
i think i did the ebay kit also, I got away with just buying one kit tho.
2nd Gen 3s-gte.... It lives!
97celiman
post Feb 7, 2012 - 8:55 AM
bsamps4
Joined May 16, '10
From Raleigh
QUOTE (96stgreendemon @ Feb 6, 2012 - 10:38 PM) *
I'm using the s54 for the time being until I can afford the e-153. Where did you get your polymounts from?
Ted! Thats a lot of bends! I hope I can get away with just using one kit!
post Feb 7, 2012 - 8:57 AM
96stgreendemon
Joined Oct 7, '09
They are the kirk poly mounts. search kirk on here and you will find the thread
post Feb 7, 2012 - 11:09 AM
bsamps4
Joined May 16, '10
From Raleigh
QUOTE (96stgreendemon @ Feb 7, 2012 - 8:57 AM) *
Sweet! Found it. Will pick up a set of these next time I get paid.
Things still on the list...
Lotek Gauge Pods
Poly Mounts
Passenger Side Axle
Power Steering Fluid
Magnetic Drain Plug
Fittings for my Oil Pressure Sensor
Fittings for my Water Temp Sensor
more recycled stainless for my 3"exhaust
post Feb 7, 2012 - 12:36 PM
easternpiro1
Joined Feb 1, '05
From Charlotte NC
WINTASTIC! when are you putting it in?
post Feb 7, 2012 - 2:30 PM
Ted95
Joined Mar 8, '09
From Westport, MA
it is alot, i just counted up the number of bends on my setup but i dont have any tight bends tho.. hey it works fine for me.
post Feb 7, 2012 - 3:12 PM
96stgreendemon
Joined Oct 7, '09
Yours is WRC, you have 3/8NPT holes threaded by oil filter, those can be used for the oil readings
Lo-Fi Version Time is now: September 16th, 2026 - 5:14 PM
