Mar 3, 2011 - 4:38 AM
Enthusiast ![]() Joined Oct 16, '10 From Vancouver Currently Offline Reputation: 0 (0%) |
so i have a conundrum for all you fellows 6gc'ers.
theres a knocking sound coming from my rear suspension area, and for the all of it I just can't seem to find out where it's coming from. some quick info, both my shocks and springs are fine and at times it seems like theres two separate sounds coming from both the rear passenger and driver. My mechanic friend seems to think it might be my rear struts. so im kinda stuck there. any help would be needed. thanks |
Mar 3, 2011 - 5:13 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 3, '06 From Czech Republic (Europe) Currently Offline Reputation: 56 (100%) |
it should be tons of things unfortunately
- bad rear upper mounts - bad bushing of rear sway bar - bad rear endlinks - exhaust fitment issues (it may hit something) - and (this is the most curious but it already happened) it should be not tight enough lifting jack in the trunk (if you have it in the holder place in rear fender area) that is all that came to my mind... -------------------- No more replicas... This is evolution... This is SS-four :)
![]() ________[Featured Celica of 6gc.net @ 2010]_________ |
Mar 3, 2011 - 4:13 PM
Enthusiast Joined Mar 3, '11 From Dublin Currently Offline Reputation: 0 (0%) |
i think check out the visual things like checking your exhuast then the next step i would take is the rear Anti Roll Bar Bushings...
if it is its not that expensive to fix .. or it might be the rear diff mount.. |
Mar 6, 2011 - 11:19 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Mar 3, '05 From Richmond, B.C. Currently Offline Reputation: 0 (0%) |
| Lo-Fi Version | Time is now: September 11th, 2026 - 9:55 PM |
