> Painting Your alternator, Wasn't Sure where to put this, but good info
post Mar 6, 2011 - 10:32 PM
Lil-Joe101
Joined Dec 7, '07
From Corpus Christi, TX
Found this info on this site, thought it would be pretty interesting for everyone as well as myself.
http://www.ehow.com/how_4889277_paint-your-alternator.html
How to Paint Your Alternator
Paint Your AlternatorHow to Paint Your AlternatorUser-Submitted Article
Changing the color of your alternator is really easy. It will dramatically change the look under the hood.
.Difficulty: Moderate
Instructions.Things You'll Need:
Alternator
Brake cleaner
Paint
Small Paint brush
1
STEP 1: Remove alternator from vehicle. Follow instructions in your vehicle's manual.
2
STEP 2: Clean the alternator with the Brake Cleaner and a rag. Take your time here. The cleaner it is, the nicer the paint job will come out in the end.
3
STEP 3: Using a small paint brush (I used a 3/8") start to paint the alternator. Be sure to get in between all the fins and curves. Wait for it to fully dry.
4
STEP4: Reapply a second coat. This will assure that everything is covered uniformly. This will also make the paint a little more durable.
5
STEP 5: Reinstall the alternator (after it has dried) into the vehicle. Be sure to install it correctly. Now step back and enjoy the work you just did all by yourself!
Lo-Fi Version Time is now: August 25th, 2026 - 9:09 PM
