Mar 22, 2011 - 11:02 AM
Enthusiast ![]() ![]() ![]() Joined Dec 11, '07 From Davie, Florida Currently Offline Reputation: 4 (100%) |
Hey guys,
Before I begin with the problem, let me give you some background. I had a few problems with the 3S before where it just wasn't pulling as hard after 5K RPM. I changed the spark plugs to NGK's BKR7E's and it was running good for a while. I have a Greddy boost controller & I run the boost around 8-9lbs (A little above .5 bar) daily. Now sometimes when I'm feeling a little racy, I switch it to high boost where I have it set at around 15-16lbs (A little above 1 bar). Now when I switch the boost to High, the car started doing the same thing again (not pulling as hard around 5K RPM). Also, My boost gauge says that the boost is not going over 1 bar. It's staying around .9 and won't go over at all after it is finished building up. This only happens when I switch the boost to HIGH now. It's not feeling like the turbo is hesitating, but I'm no expert, what could this be? I was thinking of changing the spark plug wires to NGK 7mm and see if that would help. -Thanks for your time, Ryan |
Mar 22, 2011 - 2:03 PM
When's the last time you did a tune up? (cap, rotor, wires, plugs)
Mar 22, 2011 - 10:16 PM
When's the last time you did a tune up? (cap, rotor, wires, plugs) Sorry I took so long to reply. Just re-did plugs, but I believe the rest was done about 10,000 miles ago, give or take. I was planning to do wires as well. Should I save up to do a full tune up one shot, or check & see how it plays out with just the wires? -Ryan |
Mar 23, 2011 - 8:38 AM
do you have a wideband O2 sensor? you might be running really lean.
Mar 24, 2011 - 9:05 AM
do you have a wideband O2 sensor? you might be running really lean. No, unfortunately I do not. I was thinking it might have had something to do with that, but then one of my friends, who has a LOT of extensive knowledge on Toyota's, said that it could be the with the spark plug wires. He was telling me that the guy before me put cheaper 5mm wires & that has to be upgraded regardless cause it's not good enough. I know, I'm kind of dumb for not posting this info in the first place, right? -Ryan |
Mar 24, 2011 - 11:00 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 18, '09 From Orlando Currently Offline Reputation: 8 (100%) |
Out of curiosity, is this Axel's former Celi?
'90 MX-5 Mariner Blue '93 MX-5 LE '07 Kawasaki Eliminator 125 silver '15 Optima Grey '04 206 GTi silve |
Mar 24, 2011 - 11:35 AM
2nd or 3rd gen?
either way, you shouldnt be lean @ 15-16psi, unless you have some other issue. i would start with a complete tune up with OEM parts, (rotor, cap, and wires) and a fresh set of bkr7's. -------------------- Former Team 5SFTE pro member ;)
Mar 24, 2011 - 11:48 PM
Out of curiosity, is this Axel's former Celi? Yes sir. Thanks Presure2, I guess I'll do a full tune up & see from there. Thanks guys for the help! -Ryan 2nd or 3rd gen? either way, you shouldnt be lean @ 15-16psi, unless you have some other issue. i would start with a complete tune up with OEM parts, (rotor, cap, and wires) and a fresh set of bkr7's. Oh, and it's a 3rd gen. Plus, aren't some people running the stock turbo up to 18psi? That's crazy, is it safe to push the turbo that much? -Thanks again, Ryan |
| Lo-Fi Version | Time is now: August 30th, 2026 - 11:53 PM |
