> Door install?
post Apr 13, 2011 - 1:59 AM
jtmlb3k
Joined Jun 11, '10
From Los Angeles
Just curious: How difficult is it to install the drivers' side door? I've decided to keep the Celi for another year and my drivers door is rusted and the window internals rattle around so I'm thinking this might make a good summer project. Any thoughts?
Also, does anyone know where I could find steps to do so if it's not too hard?
I have 0 experience working on cars but am always on the forum reading stuff and would like to do a few things if I can.
post Apr 13, 2011 - 3:54 AM
malpaso
Joined Feb 3, '06
From Czech Republic (Europe)
Very easy. I have made door swap my self on my car. really no special skills or tools needed.
post Apr 13, 2011 - 12:39 PM
thatmr2
Joined Aug 4, '10
From Massachusetts
It's pretty simple, you just take out the driver side front fender, driver side door panel. Take out 4 bolts that holding driver side door to the car and you should be all set. You will need someone to hold the door to take out the door and to install it. If you do everything right. You shuold be able to do it 15-20 min no issues.
QUOTE (jtmlb3k @ Apr 13, 2011 - 1:59 AM) *
post Apr 13, 2011 - 1:08 PM
jtmlb3k
Joined Jun 11, '10
From Los Angeles
QUOTE (thatmr2 @ Apr 13, 2011 - 12:39 PM) *
Thanks for the response. That sounds simple enough. Will the door be flush without much hassle? And what about the wiring for the power window? That's the part I'm really worried about...
post Apr 13, 2011 - 1:59 PM
CoreyST
Joined Feb 25, '11
From Delaware
The wires feed throug hthe door (by a plug I'm believe or atleast they did on another car I've replaced doors on) And it should sit flush as long and your hinges and everything were fine before.
post Apr 13, 2011 - 8:35 PM
schmooot
Joined Sep 29, '09
From Prince George, BC CANADA EH!
my only advice is to get a buddy to help you hold up the door while you bolt it in.....makes heaps easier. Also make sure it is aligned properly before you slam it or you may catch something or it will stick closed
ST205 Crew represent
Challenge Accepted
post Apr 14, 2011 - 11:32 AM
thatmr2
Joined Aug 4, '10
From Massachusetts
When you take out the door panel, you will just need to unplug some wires, such as the wire for the power window/lock, wire for door light and another wire I believe, not sure. either 2-3 but it's pretty simple
QUOTE (CoreyST @ Apr 13, 2011 - 1:59 PM) *
post Apr 20, 2011 - 3:19 PM
jtmlb3k
Joined Jun 11, '10
From Los Angeles
QUOTE (thatmr2 @ Apr 14, 2011 - 11:32 AM) *
Awesome. I think if I find a door for cheap enough, I might try it this summer.
My other concern is that my passenger's side door isn't flush with the body. The car was in a fender bender before, so could this be permanent, or do they sometimes just warp over time?
post Apr 20, 2011 - 8:06 PM
schmooot
Joined Sep 29, '09
QUOTE (jtmlb3k @ Apr 20, 2011 - 1:19 PM) *
most likely due to a fender bender from before. You can sometimes adjust the striker and hinges a bit but chances are it is already at its limits
Challenge Accepted
Lo-Fi Version Time is now: August 26th, 2026 - 12:30 PM
