May 16, 2011 - 11:04 AM
Enthusiast ![]() ![]() Joined Dec 7, '10 Currently Offline Reputation: 1 (100%) |
It happened to me twice since I own the car (6months)
I turn on the car and start driving, then "bling" check engine light is on...usually the ecu would shut everything and drive on very rich fuel... I didn't noticed any loss of performance, I wasn't going far so I parked the car, did my stuff...then turned on the car and drove around a bit...the light never turn on again... |
May 16, 2011 - 5:40 PM
then dont worry about it. but you really need to check the code to see what it was. might have a sensor coming loose
May 16, 2011 - 5:54 PM
I'll have them checked next time I go to the garage! thank you!
May 16, 2011 - 8:12 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 11, '08 From Auckland, New Zealand Currently Offline Reputation: 0 (0%) |
It's a simple one you can do yourself, here is the guide
http://www.6gc.net/howto/determine_check_engine_light_codes It's most likely 54, you probably need to top up your intercooler. Best done with the engine cold, Rev the motor a bit to activate the pump, as the water goes down top it up until full and replace the cap, the pump will turn off in 20 seconds so do it quick. -------------------- Mike W
May 16, 2011 - 9:33 PM
can I still verify the code if the engine light doesn't turn on? because like I said, it's random! it did it only twice in 6 months...
May 16, 2011 - 10:39 PM
Yeah the ECU remembers codes while the battery is still plugged in.
To clear codes from ECU memory you disconnect the battery, or pull the ECU and EFI fuses and let it sit for 10 mins before reconnecting. -------------------- Mike W
May 16, 2011 - 10:48 PM
Ok thanks! I'll do this!
| Lo-Fi Version | Time is now: August 27th, 2026 - 3:25 PM |
