Jan 13, 2012 - 7:45 PM
Enthusiast Joined Oct 8, '11 From Manassas VA Currently Offline Reputation: 0 (0%) |
i have a 94 celica GT 2.2l 150000 plus. I recently did a coolant change/ flush about 3 weeks ago but when i got in my car to drive my temperature gauge fluctuates and its feels as if im loosing power. the radiator and over flow have coolant, i have heat, its just the temperature gauge fluctuates and feels like its lost power. If any one know whats going on here i would really appreciate the help. thanks.
Jan 13, 2012 - 8:12 PM
Enthusiast ![]() Joined Dec 30, '11 From Atlanta via Mobile Currently Offline Reputation: 0 (0%) |
Bad thermostat not holding the cold coolant? I know when I start in the morning, I can get on the interstate with the heat off, let it get hot then turn the heat on I can watch the gauge drop...
Jan 13, 2012 - 8:35 PM
So are you saying its a bad thermostat??? i never had this problem over the year ive had it wonder why it would start now.
Jan 13, 2012 - 9:46 PM
OOO! and the temp needle drops from normal temp to cold when i floor it. i have a vid if need to know what im talking about. HELP!
Jan 13, 2012 - 10:45 PM
Enthusiast ![]() Joined Jan 2, '12 From pickerington ohio Currently Offline Reputation: 0 (0%) |
OOO! and the temp needle drops from normal temp to cold when i floor it. i have a vid if need to know what im talking about. HELP! Sounds like a air bubble in the system OOO! and the temp needle drops from normal temp to cold when i floor it. i have a vid if need to know what im talking about. HELP! Sounds like a air bubble in the system |
Jan 13, 2012 - 11:14 PM
is there a bleeder valve on this yota motor, if so where is it located??
Jan 13, 2012 - 11:57 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 23, '11 From kenton ohio Currently Offline Reputation: 14 (100%) |
Been awhile since I've done it but if I remember right there's a bleeder valve on the thermostat housing
-------------------- 95 gt coupe, v6 swap weekend toy
Jan 14, 2012 - 12:27 AM
If the coolant level keeps dropping, yeah its an air bubble. Otherwise I suggest a thermostat. Its cheap too at like $7 or so. Then rebleed: done.
Jan 14, 2012 - 1:16 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined May 10, '10 From MA Currently Offline Reputation: 37 (100%) |
you should "burp" the system.
take the coolant cap off (when the car is cold), and start the car up. let it run with the heat fully on so that it circulates the whole system. it should get rid of the bubble and you can add some if you notice that the coolant level drops |
Jan 14, 2012 - 6:19 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined May 29, '09 From Gainesville, FL Currently Offline Reputation: 17 (100%) |
My GT did this, was a loose wire on the sensor itself on the water inlet.
I don't think there is a bleeder, don't we have to "burp" them...raise it up, pop the cap off, sqeeze the tubes blah blah. This post has been edited by rave2n: Jan 14, 2012 - 6:20 PM |
Jan 15, 2012 - 12:10 AM
Allright guys i have came to the conclusion that my Thermostat is failing, i don't see how i would have an air pocket after 3 weeks of driving it. the only time the temp goes down is when i floor it. all the senors are fine. so all the fingers point to the thermostat, plus it hasn't been changed in the cars life time. i really appreciate every ones input thanks. Case Closed.
| Lo-Fi Version | Time is now: August 31st, 2026 - 3:25 AM |
