> high rpm at idle
post Feb 6, 2012 - 8:59 PM
JasonX
Joined Oct 18, '07
From Orange County, CA
Hello everyone--
When I start my car, it starts off below 1K rpm, then it creeps it's way to around 1400. I unplugged the IAC valve connector to see what happens, then the rpm steadily stayed at 1100. What's the correct rpm at idle? Do you guys think I might have a dirty IAC Valve. So far, I removed the throttle body with the IAC, but waiting until tomorrow to remove the bolts at work, 'cause they are stuck. I'm anxious to know what it could be, so wanted to get some input. Thanks.
- JasonX   high rpm at idle   Feb 6, 2012 - 8:59 PM
- - JasonX   i fixed the problem. I replaced my connector to th...   Feb 7, 2012 - 1:37 AM
Lo-Fi Version Time is now: August 26th, 2026 - 11:22 PM
