Feb 13, 2012 - 9:07 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Oct 18, '06 From cincinnati Currently Offline Reputation: 10 (100%) |
As the title and description says... anyone looked at their swap lately and seen if its titled/leaning a bit from driver side(higher) to passenger side(lower)?
I know it leans from front to back (toward the firewall). But I talked to another (AT200) 3s swapper who did it from a gt4 clip and he reported the same thing. Info? thanks for any answers. Curious if its a difference in the ST.. -------------------- proud =3sgte SWAPPED= '95 Celica ST owner [calling it the GT2 or half-trac]
309,000 miles n' .... |
Feb 15, 2012 - 4:30 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 7, '03 From Northern Virginia Currently Offline Reputation: 23 (100%) |
As the title and description says... anyone looked at their swap lately and seen if its titled/leaning a bit from driver side(higher) to passenger side(lower)? I know it leans from front to back (toward the firewall). But I talked to another (AT200) 3s swapper who did it from a gt4 clip and he reported the same thing. Info? thanks for any answers. Curious if its a difference in the ST.. it really shouldn't. the ST is supposed to use the same holes for the motor mount on the timing belt side. |
Feb 15, 2012 - 7:17 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Apr 23, '08 From Muskego,Wi Currently Offline Reputation: 8 (100%) |
i noticed this a little bit on my swap also. Been fine for almost 20k miles now
-------------------- 2nd Gen 3s-gte.... It lives!
97celiman "92-gt-quit making up random acronyms that dont mean anything. the only real acronym is JDM" |
Feb 15, 2012 - 11:33 PM
As the title and description says... anyone looked at their swap lately and seen if its titled/leaning a bit from driver side(higher) to passenger side(lower)? I know it leans from front to back (toward the firewall). But I talked to another (AT200) 3s swapper who did it from a gt4 clip and he reported the same thing. Info? thanks for any answers. Curious if its a difference in the ST.. it really shouldn't. the ST is supposed to use the same holes for the motor mount on the timing belt side. i noticed this a little bit on my swap also. Been fine for almost 20k miles now purplegt4- yea i know but maybe the frame is a little bit different? idt so, but its just curious and thanks for the info Stambo. I am curious if we have something extra or not enough on one side or the other? i'm not even sure mine was like this till after returning from the shop it went to for a bit. i'll check pics. more info would be much appreciated. -------------------- proud =3sgte SWAPPED= '95 Celica ST owner [calling it the GT2 or half-trac]
Mar 1, 2012 - 8:13 PM
bump. any more info?
Mar 1, 2012 - 10:11 PM
Enthusiast ![]() ![]() ![]() ![]() Joined May 16, '10 From Raleigh Currently Offline Reputation: 12 (100%) |
Mine doesn't lean at all. It's going to have a lot to do with the mount and mounting location that you are using. IIRC you would likely to have had to tap at least one hole for that mount. Only thing I could think of is finding a buddy with a GT, and taking a look at their exact set up.
Mar 2, 2012 - 9:00 PM
Um, check to see if your motor mount bolts didn't come loose on the motor.
Mar 3, 2012 - 11:23 AM
I am thinking it could be a bracket on the driver side. between the upper trans mount and the rubber mount that bolts to the frame. There is a ~1" thick bracket that I think some pple use and some don't.
Mar 5, 2012 - 1:37 PM
Enthusiast Joined Jan 29, '12 From toronto,ontario Currently Offline Reputation: 1 (100%) |
any pics?
| Lo-Fi Version | Time is now: September 20th, 2026 - 12:34 AM |
