Feb 29, 2012 - 6:42 PM
Enthusiast ![]() Joined Sep 30, '11 From Sydney Currently Offline Reputation: 0 (0%) |
Hey guys,
Me and my friends were thinking if all that was done to a car for a few years was oil change and oil filter what would be a good list do do an overhaul service? We came up with: Brake fluid and pads Clutch fluid Transmission fluid Power steering fluid Engine oil Coolant Oil filter Fuel filter Air filter Spark plugs and leads Valve clearance Dizzy cap and rotor PCV valve Clean and test all sensors Inspection for weird noises etc Wheel rotation Anything that you would add/subtract from that list? We also made a simple regular maintenance list: Oil change and filter Clean air filter Top up all fluid levels Same question as above, anything you would add/subtract from that list? Cheers, Reece |
Feb 29, 2012 - 6:51 PM
Enthusiast ![]() ![]() ![]() Joined May 4, '05 From western MD/NOVA Currently Offline Reputation: 2 (100%) |
trim? mileage?
Feb 29, 2012 - 7:29 PM
Well i have a 1997 ZR(GT) with 134000Km but it was more of a general list not specific to my current needs
Feb 29, 2012 - 7:47 PM
Well i have a 1997 ZR(GT) with 134000Km but it was more of a general list not specific to my current needs well if i did my conversion right. there is one thing that you do not have on your list that you will be coming up to the recommended service.. and that is the timing belt. IIRC it should be done at 90k miles, and you are @ just over 83K ATM.. that and you may want to give a good look at your brake rotors wile you are at it.. good luck! -------------------- |
Mar 1, 2012 - 12:01 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 20, '09 From Winnipeg Currently Offline Reputation: 5 (100%) |
I think they are supposed to be done every 150 000km or 160 000 km, I did mine at 153
-------------------- -Protection mode, For when your amp tries to blow its load. 1995 Toyota Celica GTS - Daily Driver 1999 Chevy Cavalier - Winter Beater 1994 Honda Civic CX Hatchback - Dead My Celica! |
Mar 1, 2012 - 8:14 PM
Enthusiast ![]() Joined Dec 30, '11 From Atlanta via Mobile Currently Offline Reputation: 0 (0%) |
If you are not too worried about replacing it, you could run it till it snaps
I'd take a tape measure and check the toe in on the front end. If you haven't had an alignment in a while you can get it close and save some tire. Sounds like you needed to do mostly time related stuff, cause that is low miles. -------------------- |
Mar 1, 2012 - 8:24 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 17, '08 From JB MDL, NJ Currently Offline Reputation: 30 (100%) |
Just for fun (since you are doing plugs) id do a compression test.....verify timing is correct. While your pulling off wheels, check all your suspension components (ball joints, bushings, etc....).
| Lo-Fi Version | Time is now: September 1st, 2026 - 12:32 AM |
