> timing belt, interfering
post Mar 19, 2012 - 11:40 PM
94odiecelica
Joined Jan 24, '12
From titusville pa
i was just trying to find if the 7a-fe engine was non interfering with the pistons and valves for a timing belt change. i only did a little bit of research and just decided to try on here. if anyone can help that would be great. thanks
Replies (1 - 7)
post Mar 20, 2012 - 12:18 AM
Hanyo
Joined Aug 16, '03
From Bay area
the 7afe is NOT interfering.
that means the intake and exhaust valves do not occupy the same space as the pistons.
post Mar 20, 2012 - 9:56 AM
94odiecelica
Joined Jan 24, '12
From titusville pa
so when i change the timing belt, if the gears spin a little, my engine will be fine? wont be out of time?
post Mar 20, 2012 - 11:50 AM
Smaay
Joined Dec 8, '03
From Lancaster CA
well no, you still have to make sure the timing is correct.
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Mar 20, 2012 - 11:51 AM
94odiecelica
Joined Jan 24, '12
From titusville pa
is there anyway to do that without going to a garage? i know not to let them spin at all, but if they happen to, is a garage the only place to do that?
post Mar 22, 2012 - 3:30 AM
blackceclia0823
Joined Mar 22, '12
From rhode island
Nothing going to happen if you spin the crackshaft or the camshaft if you have the timing belt off but if you don't line up the dots right then ya you will run into trouble. There are dots on each gear to show you where to line them up. That is what Smaay is saying with timing being correct.(If I am wrong Smaay my bad)
I would suggest buying a repair book for your celica (Offical toyota repair if not no big deal) If this is your first time doing a timing belt I would take to professional and save your self the headache.
post Mar 22, 2012 - 11:05 AM
Smaay
Joined Dec 8, '03
From Lancaster CA
look in the stickies, i wrote a guid on how to build the 7A-FE. it shows how to set the timing correctly. The 5S-FE is very similar.
post Mar 28, 2012 - 12:26 PM
94odiecelica
Joined Jan 24, '12
From titusville pa
i know this is a dumb question but im still kinda new to the site, where are the stickies?
Lo-Fi Version Time is now: August 23rd, 2026 - 5:55 AM
