> engine light on and off, what could b
post Mar 22, 2012 - 8:39 PM
rodriguez046
Joined Mar 4, '12
From maryland
I was driving then suddlenly ma check enginw light came on ..couple hours later it when off what could b?..
post Mar 22, 2012 - 8:45 PM
mkernz22
Joined May 10, '10
From MA
most likely an o2 sensor, or you had a slight missfire
post Mar 22, 2012 - 8:53 PM
rodriguez046
Joined Mar 4, '12
From maryland
What should i do just wait til it shows again to run the diagnosis and find out which sensor is it..or what do u guys advice
post Mar 22, 2012 - 9:00 PM
kurt95gt
Joined Aug 23, '11
From kenton ohio
Mine does that about once a month due to a dirty o2 sensor
94 st hatch my daily driver
n
post Mar 23, 2012 - 7:29 AM
Bitter
Joined Mar 11, '06
From Way South Chicago
could b problem. code best b gotted.
post Mar 23, 2012 - 8:35 AM
cheela
Joined Feb 2, '07
From Berlin, WI
I'd say O2 sensor as well. mine's been doing that for a while.
also, if you have an auto parts store like advance auto or auto zone nearby, they do free code checks on the spot.
post Mar 23, 2012 - 9:11 AM
rodriguez046
Joined Mar 4, '12
From maryland
Would the code show even of the light is off
post Mar 23, 2012 - 10:56 AM
kurt95gt
Joined Aug 23, '11
From kenton ohio
Mine doesnt show any codes if the lights off
n
post Mar 23, 2012 - 11:08 AM
QUOTE (Bitter @ Mar 23, 2012 - 8:29 AM) *
Precisely.
Daw, go ta auto part store them boys well hook u up. jus tell them plug that bish in an read them numbas
This post has been edited by SwissFerdi: Mar 23, 2012 - 11:08 AM
'90 MX-5 Mariner Blue
'15 Optima Grey
'04 206 GTi silve
post Mar 23, 2012 - 12:03 PM
badman322
Joined Jan 31, '12
From Martinsburg, WV
QUOTE (SwissFerdi @ Mar 23, 2012 - 12:08 PM) *
Precisely.
To bad he's got a '95, before obdII. Could be O2 sensor, could also be EGR problem. I had that happen to me where the light would go on and off and that was the code I got from it. Although, the new engine should take care of that!
post Mar 23, 2012 - 3:06 PM
rodriguez046
Joined Mar 4, '12
From maryland
Also it smell like gas
post Mar 23, 2012 - 7:33 PM
Bitter
Joined Mar 11, '06
Werd to yo motha, search n junk to learn how 2 b pull the codes from that b4 obdii car. Aight?
post Mar 23, 2012 - 8:12 PM
kurt95gt
Joined Aug 23, '11
From kenton ohio
Pin e1 an te1 to read the codes on a obd1
n
Lo-Fi Version Time is now: June 25th, 2026 - 11:34 PM
