> Replaced Speed sensor and speedo and odo not working still
post Mar 27, 2012 - 10:38 PM
ILoveMySilly97
Joined Mar 8, '12
From Hanford/Fresno, Ca
I just replaced my vehicle speed sensor today and test drive it. It's running perfectly fine but the thing is it didn't change at all. The speedo and odo still doesn't work. The replacement part was made by Denso. What else can be the problem because everything was done correctly.
Replies (1 - 3)
post Mar 27, 2012 - 10:55 PM
KAOS
Joined Apr 18, '06
From Calgary, Canada
If the odometer & the speedometer aren't working and you've replaced the speed sensor - have you tried pulling out the gauge cluster and ensuring everything is tightly plugged in on the back of it?
post Mar 27, 2012 - 11:07 PM
trdproven
Joined Aug 2, '05
From Guam
check gauge cluster, film contacts might not be touching, are dirty, messed up, or the wire all the way is just messed up. Easy test is look at it and determine if its still good replug it in tight and test. or get another cluster and test. then just test everything else after.
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Mar 27, 2012 - 11:28 PM
Rusty
Joined Nov 5, '07
From New Zealand
please just stick to 1 topic thanks
http://www.6gc.net/forums/index.php?showtopic=82875&hl=
Closed TopicStart new topic
Lo-Fi Version Time is now: August 23rd, 2026 - 5:01 PM
