> Low idle on cold start
post Mar 30, 2012 - 4:10 PM
ILoveMySilly97
Joined Mar 8, '12
From Hanford/Fresno, Ca
Every time I have a cold start in cold temperature like around 45-55 degrees it'll crank up to 800rpm then goes down to 100rpm then goes back up to 200rpm. The only way I can get it to jump back up to the normal (850rpm) is to rev it up pass 3000rpm then it'll come back down to 850rpm. After that it'll idle normal. I was told there was something like a cold air control or something like that? I have a 97 Toyota Celica GT and the only mod I have is a injen short ram. That can't be the problem because it's done it before with the stock intake. Anyone know what can be the problem?
post Mar 30, 2012 - 5:19 PM
essexgt4
Joined Jun 7, '09
From essex,uk
try cleaning out the idle control valve.
post Mar 30, 2012 - 11:54 PM
Bitter
Joined Mar 11, '06
From Way South Chicago
I'll second that. I suggest you remove it from the car and clean it and make sure to pick the carbon off of it. It rotates back and forth to let more or less air past. Usually it gets clogged up with carbon, you can take the coil off the end and pull the part out to really clean it good.
post Mar 31, 2012 - 2:50 PM
ILoveMySilly97
Joined Mar 8, '12
QUOTE (Bitter @ Mar 30, 2012 - 11:54 PM) *
What should I clean it with? I'm from California and I don't know if carb cleaner is legal here.
post Mar 31, 2012 - 2:55 PM
Bitter
Joined Mar 11, '06
Seafoam Deep Creep spray, a small screw driver, and a brass brush. Make sure you have a new gasket to reinstall it to the throttle body with.
post Apr 2, 2012 - 2:32 PM
ILoveMySilly97
Joined Mar 8, '12
QUOTE (Bitter @ Mar 31, 2012 - 3:55 PM) *
Yea I decided to give a seafoam a shot. Thanks.
post Apr 2, 2012 - 9:36 PM
Galcobar
Joined Mar 3, '05
From Richmond, B.C.
How do you guys get it off without having to uninstall the throttle body as well, the screws are on the underside of the IACV?
post Apr 5, 2012 - 1:18 PM
ILoveMySilly97
Joined Mar 8, '12
QUOTE (Galcobar @ Apr 2, 2012 - 10:36 PM) *
I had to take off the TB. I haven't found a way to get to the screws because of the angle it's in and the hoses/wires that are in the way.
Lo-Fi Version Time is now: July 29th, 2026 - 5:33 AM
