Apr 5, 2012 - 9:53 PM
![]() Enthusiast ![]() ![]() ![]() Joined May 13, '06 From Kaimuki, HI Currently Offline Reputation: 10 (100%) |
Member name: Jay
Market: USDM Year: 95 Model: GT Frame & Type: ST204 convertible Engine: factory --> swapped. 5S-FE --> Gen III 3sgte transmission: stock Update: Just installed an Innovate Motorsports dual gauge, pressure/temp gauge with two 3-way switches, one for selecting between coolant and oil pressure and one for selecting between coolant and oil temp. (Jan 2015) Video of the car running here! and a time lapse video of the GTFour front end install here (recent pic Jan 2016) ![]() installed 7th gen steering wheel from a shiftronic model Celica!! Found in junkyard for cheap. Using the buttons for I/C sprayers. ![]() I figure it's about time for me to start my old thread again. I bought a 3sgte that had been parted out, got it for a good deal, but I needed a lot of hard to find parts. I would start a thread when I was on a roll then I hit a stopping point because of a lack of certain key parts. Spent a long time trying to find everything, and now I have all of the engine parts and I'm not too far from completion. ![]() Significant other mods: Engine block basics: 45k miles .20 overbore, JN pistons, eagle rods (compression raised to 9.0:1) stock head gasket knife-edged crankshaft (with custom crank scraper to block oil from being kicked up inside the engine and keep it in the pan) ARP main studs (with the little section shaved out of the oil pan for them to fit) Engine head: non-turbo 3sge head WITH turbo cams/springs and 3sgTe powder coated valve cover HKS cam adjustable cam gears (currently set at 0) ARP head studs Accessories: 4th gen alternator, direct bolt in (and higher output) 4th gen compressor, direct bolt in stock power steering pump (new though) Electrical: Autronic SM4 EMS 4 wire o2 sensor upgrade (currently not in use) Haltech Dual Channel Wideband controller (one sensor), output to ecu. Innovate Motorsports dual series pressure/temperature gauge Two 3-way switches to select between oil/coolant pressure and oil/coolant temp in dual gauge 3-way switch triggering secondary relays to turn the fans on. (switch off = relay off, system works as if stock...switch on pos1 = relays triggered on and fans are always on...switch on pos2 = relay is triggered on when the EMS is set to trigger it on. Turbo: stock CT20b Mishimoto FMIC mounted to crashbar HKS SSQV BOV MAP sensor is built in to the Autronic K&N filter (with blue rim) conical 4 inch inlet stock VSV controlled by Autronic Trans: stock st204 5sfe trans Aisin clutch with TRD pads riveted in place Fizanda flywheel Fuel: stock genIII injectors, upgraded fuel pump (walbro, gss342 for mazda mx3) Coolant sys: Mishimoto radiator Silicone hoses (blue 3-way switch controlling two 5-pin relays breaking the connection for the stock fans (on/off/on = relay-on.always-ground/relay-off.factory-controlled-fans/relay-on.SM4-controlled) Ignition system: Audi 1.8t individual coils distributor is stock and the pickup inside is only used to give the Autronic the engine time. (set at 0 degrees instead of normal advance, timing is advanced in the ECU) BKR6E plugs (have to change every 10k miles) Exhaust: aftermarket downpipe (3inch) 3 inch mandrel bent piping into 3 inch magnaflow catalytic into 2.5 inch reducer (interchangeable resonator if I unbolt the cat) 2.5 inch piping into Borla universal turbo muffler Other: cheap ebay breather filter for crank vent. custom air filter heat shield custom battery tray mounted above trans mount custom fuse box for SM4 and extra components modified washer fluid reservoir to mount around FMIC piping Wiring was a little bit of a mess at this stage because I was in the middle of building the new harness... ![]()
This post has been edited by match220: Mar 21, 2016 - 8:05 PM -------------------- -Jay
95 GT conv. project car: Manual, Gen III 3sgte, JN pisons, Eagle rods, overbore, crank knife-edged, crank scraper, ARP head/main/flywheel, Autronic EMS, Haltech Dual Wideband O2 controller, Audi 1.8T individual coils, FMIC and SSQV BOV, 3" downpipe, 3" ultra-high-flow cat, 2.5" Borla muffler, +other 01 S2000: FMIC, Haltech EMS, Haltech wideband, 570cc inj, forged pistons/rods, sleeved block, 5 angle valve job, ported and polished 02 R6, all stock, except for braided stainless brake lines, frame sliders, and adjustable brake/clutch leve |
match220 white convertible Gen III 3s build Apr 5, 2012 - 9:53 PM
kurt95gt A 3s swapped vert would be an amazing summer car h... Apr 5, 2012 - 9:58 PM
match220 and some old pictures..
FMIC from s14/s15 hyrbid
... Apr 5, 2012 - 10:00 PM
match220 The most recent video update
http://www.youtube.... Apr 14, 2012 - 5:54 AM
808celica This is gonna a quick one Hawaii Cars FTW!... Apr 15, 2012 - 1:58 AM
match220 I'm still working on wiring, so it's still... May 2, 2012 - 1:24 PM
match220 And here's some pics of my injector wire-in, I... May 2, 2012 - 11:38 PM
match220 Did a little plastic fabricating the other day..I ... May 11, 2012 - 10:43 PM
match220 Just finished making a heatshield airbox today. Th... May 25, 2012 - 11:42 PM
ricochet1490 nice work so far.... lotta blue hose haha May 26, 2012 - 1:05 AM
match220 QUOTE (ricochet1490 @ May 25, 2012 - 8... May 26, 2012 - 1:09 AM
Ted95 nice build man! i hope those bulps are in ther... May 26, 2012 - 7:49 PM
match220 QUOTE (Ted95 @ May 26, 2012 - 2:49 P... May 27, 2012 - 12:14 AM
dliverance Those LED's in the cam cover are awesome. Real... May 26, 2012 - 8:08 PM
match220 A close-up of the LEDs in the timing cover and why... May 28, 2012 - 9:11 PM
match220 Here is the side view of my little air filter heat... Jun 8, 2012 - 12:03 AM
match220 the newest video (also updated in first post)..htt... Jun 23, 2012 - 5:26 AM
ricochet1490 beautiful thus far Jun 23, 2012 - 5:57 PM
delusionz U need a fabricator!
1 weld = cheaper than 1 ... Jun 23, 2012 - 6:34 PM
match220 QUOTE (delusionz @ Jun 23, 2012 - 1... Jun 23, 2012 - 6:55 PM
ricochet1490 blue tubing makes it have a "go fast" lo... Jun 23, 2012 - 8:34 PM
match220 QUOTE (ricochet1490 @ Jun 23, 2012 - 3... Jun 23, 2012 - 9:01 PM
match220 and more pictures! For the fuel pump I drilled... Jun 24, 2012 - 5:13 AM
match220 Finished rewire of engine harness....finally...and... Sep 7, 2012 - 4:57 PM
match220 Got the car running for the first time today, I... Mar 9, 2013 - 2:40 AM
RobStar86 Nice job! Once everything is buttoned up, it ... Mar 9, 2013 - 5:24 PM
match220 QUOTE (RobStar86 @ Mar 9, 2013 - 12... Mar 9, 2013 - 5:36 PM
RobStar86 QUOTE (match220 @ Mar 9, 2013 - 6:36... Mar 9, 2013 - 6:01 PM
richee3 Congrats on getting it running. Mar 9, 2013 - 8:12 PM
match220 Did two things today to it.
1) customized my wind... Mar 21, 2013 - 12:08 AM
Malek hahaha but seriously, that's a damn good idea ... Mar 21, 2013 - 12:24 AM
match220 QUOTE (Malek @ Mar 20, 2013 - 7:24 P... Mar 21, 2013 - 12:38 AM
match220 more blue!
I found some little blue anodized ... Mar 27, 2013 - 5:14 PM
match220 ..and of course my temperature gauge doesn't w... Mar 27, 2013 - 6:49 PM
Malek DO THAT ^^ When I first bought my RS, both the fac... Mar 27, 2013 - 7:26 PM
match220 QUOTE (Malek @ Mar 27, 2013 - 2:26 P... Mar 27, 2013 - 7:45 PM
match220 wired in a 470 ohm resistor to an old water temp s... Mar 27, 2013 - 9:13 PM
match220 someone hit my car overnight it's not bad..I ... Mar 27, 2013 - 10:31 PM
match220 I have a female friend that works at a graphics de... Apr 3, 2013 - 5:29 PM
bmj67 You should have put the QR code for 6gc in that st... Apr 3, 2013 - 10:09 PM
match220 QUOTE (bmj67 @ Apr 3, 2013 - 5:09 PM... Apr 3, 2013 - 10:13 PM
match220 110 miles on the new engine and I have successfull... Apr 4, 2013 - 6:52 AM
match220 Rewired my little fuse box area for the coils, ecu... Apr 6, 2013 - 8:55 PM
match220 Haltech wideband controller came in the mail today... Apr 10, 2013 - 10:22 PM
match220 1 year update! (almost)
in short: Put in preb... Mar 8, 2014 - 10:24 AM
match220 http://www.youtube.com/watch?v=OU9khGeS4Go
I star... Mar 12, 2014 - 7:40 AM
The_enD Good video, I learned something.
I am using my re... Mar 12, 2014 - 7:57 AM
match220 QUOTE (The_enD @ Mar 12, 2014 - 2:57... Mar 12, 2014 - 8:21 AM
match220 GTFour front end bolt on video
(note: both my fend... Jan 30, 2015 - 7:25 PM
match220 Had interior accent pieces painted professionally ... Jan 31, 2015 - 5:01 PM
match220 repinned st204 gauge connectors to accept ST205/ST... Jan 31, 2015 - 5:06 PM
match220 Got a new project to flip. It runs now after I rep... Jan 31, 2015 - 5:09 PM
match220 Added this dual-function gauge(middle). It will re... Feb 1, 2015 - 4:43 AM
enderswift I like the 3 way switch idea Feb 1, 2015 - 3:21 PM
match220 QUOTE (enderswift @ Feb 1, 2015 - 10... Feb 1, 2015 - 4:04 PM
match220 LED floor lights! Since I replaced the incande... Feb 10, 2015 - 12:56 AM
match220 after a bath and vacuum Feb 14, 2015 - 5:26 AM
match220 I've been tossing around the idea of running a... Feb 14, 2015 - 9:18 PM
match220 fog light button in the vent hole! Took some p... Feb 17, 2015 - 11:03 PM
match220 3 point strut tower bar installed! I also made... Mar 2, 2015 - 9:00 PM
match220 Curren tails, and a carbon fiber TRD Coupe spoiler... Mar 24, 2015 - 3:29 PM
match220 Found this little gen in a junkyard here....suuuup... Mar 21, 2016 - 8:02 PM
richee3 Good to see I'm not the only one playing aroun... Mar 21, 2016 - 9:41 PM
match220 QUOTE (richee3 @ Mar 21, 2016 - 4:41... Mar 21, 2016 - 10:29 PM
richee3 QUOTE (match220 @ Mar 21, 2016 - 10... Mar 22, 2016 - 6:49 AM
match220 QUOTE (richee3 @ Mar 22, 2016 - 1:49... Mar 22, 2016 - 2:48 PM
JPATTT so jelly that u found a trd coupe wing. ive been l... Mar 21, 2016 - 10:40 PM
match220 QUOTE (JPATTT @ Mar 21, 2016 - 5:40 ... Mar 21, 2016 - 10:46 PM
richee3 Just to have the extra two pins running through th... Mar 22, 2016 - 2:53 PM
match220 QUOTE (richee3 @ Mar 22, 2016 - 9:53... Mar 22, 2016 - 3:50 PM
ricochet1490 Loads of recent updates. Very nice. Very cool to s... Mar 22, 2016 - 7:00 PM
match220 QUOTE (ricochet1490 @ Mar 22, 2016 - 2... Mar 22, 2016 - 7:07 PM
richee3 I fully support your chosen uses for the buttons... Mar 23, 2016 - 10:55 AM
match220 QUOTE (richee3 @ Mar 23, 2016 - 5:55... Mar 23, 2016 - 8:03 PM![]() ![]() |
| Lo-Fi Version | Time is now: August 26th, 2026 - 7:12 AM |
