Apr 12, 2012 - 12:44 PM
Enthusiast ![]() Joined Apr 10, '12 From Chicago Currently Offline Reputation: 0 (0%) |
Okay so I've broken 3 driver side and 2 passenger side.. I've had this celica since August 2011... I bought it with broken wheel bearings. I thought it was my driving so after the last repair I began to drive more carefully. This time I broke both front ones at the same time! What do you think could be the reason I'm burning through wheel bearings??? Because this is just crazy. I've put more money in wheel bearings than any other repair on my car. Something more has to be wrong if I'm breaking a bearing which seems like every other month.. Please someone help. I have a 94 Celica GT
This post has been edited by SiriusVirus: Apr 12, 2012 - 12:44 PM |
Apr 12, 2012 - 12:58 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jul 7, '03 Currently Offline Reputation: 55 (100%) |
it sounds like the hubs are toast, if you put a good bearing on a bad hub it will ruin the bearing in no time.
If I remember toyota recomends replacing both. There are some threads on this in suspension/brake forum. This post has been edited by 97lestyousay: Apr 12, 2012 - 12:58 PM -------------------- JDM guy made me do it.
Apr 12, 2012 - 1:05 PM
Enthusiast ![]() ![]() Joined Oct 23, '08 Currently Offline Reputation: 24 (100%) |
if you are using wheel spacers they will wear out bearings
Apr 12, 2012 - 1:34 PM
Just check and make sure the axle nuts are completely tight as well.
Apr 12, 2012 - 1:51 PM
it sounds like the hubs are toast, if you put a good bearing on a bad hub it will ruin the bearing in no time. If I remember toyota recomends replacing both. There are some threads on this in suspension/brake forum. ^I agree with this, a bad hub will destroy bearings faster than you could imagine. With the frequency of your issue, this is where I would start. |
Apr 12, 2012 - 1:53 PM
What brand are you buying?
At the very least I would try to pick some up that carry a warranty. You should be able to find at least a 3 year warranty if not a lifetime warrenty so it will stop costing you $ everytime they burn up(which they shouldnt in the first place) Have you been using a torque wrench when you install them? You can rent a decent one at the parts store or buy a cheapie for around $20. |
Apr 12, 2012 - 2:04 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 7, '03 From Northern Virginia Currently Offline Reputation: 23 (100%) |
Get an alignment. A caster problem can also prematurely wear your wheel bearings. Have you been changing one side at a time?
Apr 12, 2012 - 2:38 PM
My bearings are under warranty. one hub has been replaced the other hasnt. Its costing me so much because I'm paying my cousin labor and having a shop press the bearing. Thanks I'm gonna replace one hub was previously replaced. My one friend was telling me how I'm supposed to replace both bearings at the same time. I have gotten an alignment done at just tires when I got my new tires. Hopefully after the new hubs everything will be fixed. Because I really want to start fixing up my car but all my spare cash has been going to pay labor on wheel bearings >_<. Thanks for the help everyone
This post has been edited by SiriusVirus: Apr 12, 2012 - 2:43 PM |
Apr 13, 2012 - 12:02 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined May 10, '10 From MA Currently Offline Reputation: 37 (100%) |
getting both hubs, with the bearings and seal kits is going to cost you around $600. it was just over $200 for my passenger stuff
Apr 13, 2012 - 1:33 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 24, '07 From Oahu, Hawaii Currently Offline Reputation: 23 (100%) |
Do what the other guys suggested: -change hubs -get alignment -check axle nuts -check the person doing the job You have to remember a warranty is a manufac. defect on these things, it's not "oh it broke again 1 1/2 out I'm gonna go get another one". If something's causing the bearings to go faster most shops will not honor the warranty period, especially if its the 2nd or 3rd time this is happening. -------------------- I don't normally drive fast, but when I do its on a curvy section of this island
Apr 13, 2012 - 3:14 PM
Enthusiast ![]() ![]() ![]() ![]() Joined May 16, '10 From Raleigh Currently Offline Reputation: 12 (100%) |
Is your car lowered?
Apr 13, 2012 - 7:19 PM
I get my bearings done cheap kind of... Auto Zone they dont check labels etc they are basically no questions asked heres your new bearing good luck. I just got one new hub because the mechanics doin my work busted the knuckle pressing a bearing. My cousin has been doing the work. My car isnt lowered either.. I'm gonna take my car to a mechanic and have then look at everything and see if they see something my cousin isnt seeing.
Apr 13, 2012 - 10:46 PM
What are you torquing the axle nut to?
Apr 14, 2012 - 8:55 AM
Enthusiast Joined Apr 12, '12 From California, Japan, Sometimes Europe Currently Offline Reputation: 0 (0%) |
Okay so I've broken 3 driver side and 2 passenger side.. I've had this celica since August 2011... I bought it with broken wheel bearings. I thought it was my driving so after the last repair I began to drive more carefully. This time I broke both front ones at the same time! What do you think could be the reason I'm burning through wheel bearings??? Because this is just crazy. I've put more money in wheel bearings than any other repair on my car. Something more has to be wrong if I'm breaking a bearing which seems like every other month.. Please someone help. I have a 94 Celica GT There are a number of potential possibilities, also once chronic damage has taken place often times a primary component can become out of spec and irreversibly corrected. ie you might simply have to replace the hubs completly. One user on here, nearly hit the nail square on. He mentioned wheel spacers. Only one aspect to consider. 3/4ths the vehicles I see rolling around are waiting diasters. Suspension geometry is very important. Excessive negative camber will wear hubs like crazy, spacers alter geometry as well and thus must be corrected. Beyond that if you have the wrong wheel offsets you'll find a slew of problems as well thus compounding other issues you might already have with ride height, caster, camber, amongest other things. Simply said, you need to correct your suspension geometry and or have exceeded the factory geometry. I can't help you beyond this, not unless I know more about the specific set up you have. PS, It's often easier if people reply via my in box. Mick - |
| Lo-Fi Version | Time is now: July 29th, 2026 - 7:08 PM |
