5 Pages V  « < 2 3 4 5 >
> ENDLINK INFORMATIVE - QUICK HOW-TO ENDLINKS, ALSO MEVOTECH/MOOG ENDLINKS INSTALLED
post Feb 8, 2013 - 2:17 AM
BonzaiCelica
Joined Apr 24, '08
From Orange County, CA
MEVOTECH
now as you can see people masked man was right. its the placement of the rod. as you can see by the angle isn't that harsh at all. I will be bending the tab a bit more outward to get it to fit nicely like an oem size/style end link. so each joint is at 90 degree. I just have to return these ($112 from orielly) and buy a set online (once i get a job)
MOOG
This post has been edited by BonzaiCelica: Feb 18, 2013 - 10:44 PM
post Feb 8, 2013 - 3:55 AM
trdproven
Joined Aug 2, '05
From Guam
yea thats what i was saying about lining up one of the nuts and seeing where the rest of the endlink lines up from the top going down while comparing the other endlink behind it. still weird though your MOOG is still a bit crooked, mines totally straight. since you are using MOOG just like me im beginning to not also count out the strut bracket and sway bar because i think you and spyder both have KYBs and I don't. im going to take better pics tomorrow. my left side pics were crap, but my right side pics you can clearly see they are straight up, this time i'll get the pics in the day, those were taken at dinner.
just a wild idea but if you bend the kyb bracket to the right, im guessing it would line up straighter. maybe KYBs bracket is also too close?
This post has been edited by trdproven: Feb 8, 2013 - 4:03 AM
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Feb 8, 2013 - 4:22 AM
BonzaiCelica
Joined Apr 24, '08
oh yes i will bend bracket once i get a big enough vice grip and a set of my own moog end links in my hand...
from your blurry pics it seems as though the tab is nearly center on the shock housing. so i believe this kyb gr2 are off from the stock toyota shock. i need pics of oem shock.
This post has been edited by BonzaiCelica: Feb 8, 2013 - 4:50 AM
post Feb 8, 2013 - 12:02 PM
mkernz22
Joined May 10, '10
From MA
I'll have to get some pictures next weekend since I have the miata ones with coilovers cause I don't think mine look like that at all
post Feb 8, 2013 - 1:59 PM
BonzaiCelica
Joined Apr 24, '08
as you can see even the original housing is basically the same!! so far as i can tell from trd blurry pic the megans have a better mounting point for thicker end links. As you can see from the megan group buy back in 2009 the pics below show that they use a moog end link. so there is no need guys for you to post your pics unless you have a tein coilovers installed, then a rear pic would be helpful
QUOTE (Batman722 @ Sep 18, 2006 - 12:23 AM) *
there are a few ways to remove the sway bar end links. You need to remove them (or at least the top bolt) to change your rear struts (for lowering and such).
another angle
QUOTE (upscaleauto @ Oct 12, 2009 - 10:17 PM) *
Megan Racing Street Series Coilovers for 94-99 Toyota Celica FWD
$850/set with Discount Code! Free Shipping (lower 48 states)! Brand New with Warranty!
[i]
As you can see they also fit bc coilovers. because they look exactly the same in design except the color and spring rates.
This post has been edited by BonzaiCelica: Feb 12, 2013 - 8:08 PM
post Feb 8, 2013 - 5:32 PM
trdproven
Joined Aug 2, '05
From Guam
too bad my teins are for my 7th gen.
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Feb 8, 2013 - 5:37 PM
trdproven
Joined Aug 2, '05
From Guam
QUOTE (BonzaiCelica @ Feb 8, 2013 - 7:22 PM) *
i knew there was something else wrong, you already had the pics of the moog still crooked and you and spyder both had kybs. Since you already have the megan group buy pic, its for sure, no need for my pics like you said.
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Feb 19, 2013 - 12:55 PM
richee3
Joined Jun 29, '08
From Denver
Here are my RacingBeat Miata end links with stock struts, ignore how filthy everything is.
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Feb 24, 2013 - 5:20 PM
trdproven
Joined Aug 2, '05
From Guam
i get it already, my pics were blurry, but its not like you cant see anything, you can still tell what you are looking for.
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Apr 17, 2013 - 2:19 PM
BonzaiCelica
Joined Apr 24, '08
thx to diego i got the pic muhaha see fits perfectly on megans
Just proof that the mevotech and moot end links won't fit the TANABE Coilovers either
This post has been edited by BonzaiCelica: Sep 2, 2015 - 5:53 PM
post Apr 18, 2013 - 7:05 AM
mi645
Joined May 23, '12
From northridge,CA
Hello I read on twos r us that twos r us end links do not work withmegan racing coilovers for an sw20 now I'm not sure if that's the same case with celicas reason I ask is cuz my Celica has Megan racing coilovers and I want to invest in twos r us end links now does anyone here know if they ate compatable? Twos r us end links with Megan racing coilovers
post Apr 18, 2013 - 2:29 PM
BonzaiCelica
Joined Apr 24, '08
Edit why did i even waste my time
This post has been edited by BonzaiCelica: Apr 19, 2013 - 3:39 AM
post Apr 19, 2013 - 2:36 AM
mi645
Joined May 23, '12
From northridge,CA
I already have sw20 stainless end links for my sw20
post Apr 21, 2013 - 10:41 AM
malecrod
Joined May 30, '05
From MN
Just wanna add. I tried the mevotech end links front and rear but ended replacing them, not because they were bad but it did not offer what I wanted. So I went with the gt4 ones on page one. They can be found under an ebay seller out of Poland named': 'gt4goodies'. I hesistated at first because of the look of the design (especially the rear) and the expense. So I bought and tried the front first and was impressed. I ended buying the rear and was equally impressed. I have used them for just over 3months now, and I'm glad to say the are still as good as when first installed.
It actually made the suspension feel tight together. The cost (about $200) for front and back is a bit much. And remind you, the seller is based in Poland so it takes about 2-3weeks to get them here in the states.
Something to consider for those looking for a performance geared end links. I'm in no way saying they are the best but I wanted put it out there as an option for some 6gc members.
Mine are on TRD springs, OEM struts and whitelines sway bars for your information.
This post has been edited by malecrod: Apr 21, 2013 - 10:56 AM
3sgteing.
..burns twice as bright, lasts half as long.
"The weight of the world is love. Under the burden of solitude, under the burden of dissatisfaction."
-Allen Ginsberg-
post Apr 21, 2013 - 1:02 PM
BonzaiCelica
Joined Apr 24, '08
QUOTE (malecrod @ Apr 21, 2013 - 10:41 AM) *
you cannot compare solid end links to ball joint style end links. totally two different end links. thats not the correct term for the mevotech, moog and oem style but yea.
see link below to understand what i mean by spherical ball joints.
http://www.6gc.net/forums/index.php?showto...&hl=twosrus
This post has been edited by BonzaiCelica: Apr 21, 2013 - 1:05 PM
post Jun 3, 2013 - 1:34 PM
BonzaiCelica
Joined Apr 24, '08
Moog rear End links. oh yes i took one left hander turn and wow i'd say it handles like a Type r. but i still have yet to really test them out. I slightly bent the mounting tabs outward with a 10 inch vice grip in order to make sure the end link sat as parallel to the shock as possible
This post has been edited by BonzaiCelica: Jun 3, 2013 - 1:34 PM
post Jun 5, 2013 - 10:47 AM
trdproven
Joined Aug 2, '05
From Guam
wow haven't been here for a bit so you did the mevo up front and moog in the rears just like I did. nice
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Jun 13, 2014 - 6:19 AM
yellowchinaman
Joined Aug 11, '08
From London
Mine.
To me I don't get the logic of a moving pivoted bush and Z positioned fittings besides being more forgiving when fitting and compatibility in parts.
I've gone for a fixed 90deg links so that force is directly transferred to the ARB and not absorbed into bending of the link bushes.
I'll give some feedback and see how they go in a few weeks time.
This post has been edited by yellowchinaman: Jun 13, 2014 - 6:20 AM
post Jun 13, 2014 - 7:08 AM
toyota123
Joined Jan 13, '12
From Georgia
That's a hefty part there. Interested in how you like it
97 Celica GT liftback DD/ project
96 corolla back up DD
post Jun 13, 2014 - 1:49 PM
yellowchinaman
Joined Aug 11, '08
From London
QUOTE (toyota123 @ Jun 13, 2014 - 8:08 AM) *
Ill give some feedback in a few weeks and again a few months to see how they do.
its still a bit unknown how itll last being less forgiving with no ball joint.
I know for lower cars with more camber these wont fit as the struts and ARB needs to be near parallel to work. But in terms of performance I believe this should logically be best as it elements all soft play and flex transferring the force directly to the ARB.
This post has been edited by yellowchinaman: Jun 13, 2014 - 1:51 PM
Lo-Fi Version Time is now: August 31st, 2026 - 6:58 AM
