Jul 30, 2012 - 12:11 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 7, '07 From Corpus Christi, TX Currently Offline Reputation: 7 (100%) |
So while I working on my car trying to get most of it back together, I ran into a snag. I though the 3sfe A/C compressor would directly bolt on but as I muscled n muscled Im starting to figure that it doesnt unless Im doing something wrong. Does anyone know if the A/C compressors are interchangable or not or where I can get one that will work? No, Im not going without A/C in this Texas heat, no way!!!!!! Its a must down here.
This post has been edited by Lil-Joe101: Jul 30, 2012 - 12:12 PM -------------------- From Japan to Texas my st202 follows me.
![]() Being different from every angle of the word, leading the Revolution (TOYOTA NATION) The RHD st202 that made it from Japan check it out. http://www.6gc.net/forums/index.php?showtopic=78103 |
Jul 31, 2012 - 9:17 AM
id have to see a pic of the compressor. maybe you are missing a mounting bracket. what compressor are you trying to mount on what engine?
Jul 31, 2012 - 6:16 PM
id have to see a pic of the compressor. maybe you are missing a mounting bracket. what compressor are you trying to mount on what engine? 3sfe compressor to the gen 3 3sgte -------------------- From Japan to Texas my st202 follows me.
Aug 2, 2012 - 6:56 PM
Enthusiast ![]() ![]() ![]() ![]() Joined May 16, '10 From Raleigh Currently Offline Reputation: 12 (100%) |
There is no mounting bracket for the 3s compressor. The 5 s compressor will fit. Did u not receive a compressor for the 3s with your swap?
Aug 2, 2012 - 7:55 PM
There is no mounting bracket for the 3s compressor. The 5 s compressor will fit. Did u not receive a compressor for the 3s with your swap? I did but they cut the lines and if the 5sfe is similar to the 3sfe and the 5s compressor fits, then hopefully I can get the compressor from 3sfe to fit as well, I can only hope -------------------- From Japan to Texas my st202 follows me.
| Lo-Fi Version | Time is now: August 11th, 2026 - 9:56 PM |
