> Does anyone have a push start ignition, NEED HELP WITH WIRING
post Jul 31, 2012 - 8:33 PM
Lil-Joe101
Joined Dec 7, '07
From Corpus Christi, TX
So I ordered a push start ignition and got the red, black wires figured out obviously. But there are two blue wires. One to the ignition wire (positive) and the other Iginition wire(negative). Does anyone know what color the positive n negative to the iginition wires and where in the steering column they are?
This post has been edited by Lil-Joe101: Jul 31, 2012 - 10:35 PM
post Jul 31, 2012 - 10:33 PM
Lil-Joe101
Joined Dec 7, '07
*BUMP* Need some kind of info
post Aug 1, 2012 - 1:42 AM
Nihil
Joined Jul 17, '12
From Slovenia
This cheat sheet will help you. You will probably install the engine start button at the cigarette lighter, so easiest way to get to all the wires is the ignition harness. You will need to remove the panel below the steering wheel to get to it. Don't know about no negative wire for the ignition...
My guess you need two wires (12V and GND) for the button light, and other two to tap into ignition. I'd use ignition wire (tap into the one that gives 12V when you turn key to ON position) for power supply. As for the wire that button triggers... you'll have to use starter wire (the same 12V key ON source on one wire of the button and other tapped into the starter wire). But this depends on what kind of button have you got - some buttons need relays and some don't.
But I've never done this before, so be careful at this... I suggest you get a voltmeter and check every single wire (also on the button) before doing anything. And remember to disconnect the battery before tapping into the wires, this might spare you a fuse or two.
This post has been edited by Nihil: Aug 1, 2012 - 1:43 AM
post Aug 1, 2012 - 3:06 AM
smkr3w
Joined Nov 29, '10
From Lake Havasu City, AZ
Jason did it awhile back, he's got a bunch of work done like that. He's the guy to talk to he also has a YouTube page for his remote start and push button start.
http://www.6gc.net/members/kamakaze
This post has been edited by smkr3w: Aug 1, 2012 - 3:24 AM
post Aug 1, 2012 - 10:39 AM
I did a push button start a looooong time ago, still had to use the key.
are you going S2k style with Key + button, or trying to ditch the key all together?
i believe this was the wire:
SECOND IGNITION WIRE BLUE/RED Ignition Harness
i tried to look for my ignition photos from my tear down, but you can't see anything clearly frown.gif
This post has been edited by playr158: Aug 1, 2012 - 10:46 AM
post Aug 1, 2012 - 6:33 PM
Lil-Joe101
Joined Dec 7, '07
Well on my wifes car the is a harness that the ignition and then there are two smaller wires. one is yellow with an organe dot and white with a black stripe all the way down. it. are these important? The push start is an ebay purchase the key is still required.
Lo-Fi Version Time is now: August 29th, 2026 - 2:49 PM
