> 98 5s stuck in neutral, Video of exactly what's happening uploaded last page
post Sep 9, 2012 - 2:59 AM
Malhar95
Joined Jul 5, '09
From Katy/houston
So with this parts car I have, the guy I got it from said The cv axles were bad that messed up the transition
Basically the car is in neutral. Even when we put it in park or drove it acts like its in neutral.
Any suggestions what it could be?
(when I was picking up the car, the driver side cv was being attempted to take out, like it was out of the hub nut not I pulled it a little bit but it didn't slip out, maybe the clip inside it broken, could that result in the car reacting this way?)
Itd a 98 5sfe auto
This post has been edited by Malhar95: Oct 5, 2012 - 9:50 AM
4 Pages V   1 2 3 > »
Replies (1 - 19)
post Sep 9, 2012 - 3:18 AM
Box
Joined Feb 23, '12
From Warrior, AL
Transmission solenoid perhaps.
2001 Miata LS 5-speed
post Sep 9, 2012 - 9:05 AM
Malhar95
Joined Jul 5, '09
From Katy/houston
QUOTE (Box @ Sep 9, 2012 - 4:18 AM) *
How can I diagnose it? If im not wrog that's a cheap fix rite?
And when i say neutral i mean even when the car is off and in park, if i pukk the e brake down its gonna roll do really in neutral haha
post Sep 9, 2012 - 9:53 AM
richee3
Joined Jun 29, '08
From Denver
I had a 5S auto tranny do that once. Here was the problem.
Result of stupidity and neutral bombing. Yours might not be as serious, as an open diff will send power through the path of least resistance. If an axle pops out of place, that's where the power will go. I find it peculiar that even in park, it still rolls. I can see where it could be either issue.
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Sep 11, 2012 - 3:07 PM
Malhar95
Joined Jul 5, '09
From Katy/houston
QUOTE (richee3 @ Sep 9, 2012 - 9:53 AM) *
But even if one axle pops out (not sure how that would happen but u never know) shouldn't the other side hold it?
post Sep 11, 2012 - 3:09 PM
richee3
Joined Jun 29, '08
From Denver
Not without LSD. An open diff will send power to the missing axle.
1998 Celica GT-
BEAMS Swapped.
post Sep 11, 2012 - 3:12 PM
Malhar95
Joined Jul 5, '09
From Katy/houston
Oh yea lol...so what can I check for?
post Sep 11, 2012 - 3:53 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
jack the car up, look behind the engine to see if the passenger axle is mounted to the block on a carrier. if it is, then take the drivers wheel off, and check to see if the drivers axle popped out.
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Sep 12, 2012 - 4:16 PM
Malhar95
Joined Jul 5, '09
From Katy/houston
cv axles are in...
anything else i should check? checked the fluid too btw
post Sep 13, 2012 - 2:24 PM
Special_Edy
Joined Oct 29, '11
From Haltom City, Texas
Yes check the shifter linkage if you havent already.
post Sep 13, 2012 - 2:34 PM
zfjohnson07
Joined Apr 11, '09
well i found a 96 gt in fort worth for sale for 700 that wont shift out of neutral either, i might buy it !
post Sep 13, 2012 - 3:09 PM
Malhar95
Joined Jul 5, '09
From Katy/houston
QUOTE (zfjohnson07 @ Sep 13, 2012 - 3:34 PM) *
Clean title? How's te body?
Sorry but what do u mean by shifter linkage (the thing that rotates when u shif get on the tranny?)
Sorry in still learning terms and names lol
post Sep 13, 2012 - 3:29 PM
Special_Edy
Joined Oct 29, '11
QUOTE (Malhar95 @ Sep 13, 2012 - 3:09 PM) *
Yeah, the linkage is what connects the shifter inside the cabin to the transmission. Mine is a manual so I dont know the exact location on a Auto 6gc where it connects to the transmission but it should move some kind of arm on the transmission when you move the shifter inside the cabin.
post Sep 13, 2012 - 3:42 PM
Malhar95
Joined Jul 5, '09
From Katy/houston
Yup checked it it's rotating with the gears too...
Torque converter?
post Sep 13, 2012 - 4:03 PM
Special_Edy
Joined Oct 29, '11
The torque converter wouldnt make the transmission act like its in neutral when its in park. 90% odds its the axle and you will be back on the road soon
post Sep 13, 2012 - 4:45 PM
richee3
Joined Jun 29, '08
From Denver
Silly question, and I'm sure it's the first thing you checked and I've just missed reading it in this thread. Have you checked the trans fluid? An auto tranny with no fluid won't move an inch.
1998 Celica GT-
BEAMS Swapped.
post Sep 13, 2012 - 5:14 PM
zfjohnson07
Joined Apr 11, '09
http://dallas.craigslist.org/ftw/cto/3268078806.html
post Sep 13, 2012 - 7:10 PM
Special_Edy
Joined Oct 29, '11
QUOTE (richee3 @ Sep 13, 2012 - 5:45 PM) *
The big thing in this case is that when the car is in park it still rolls like its in neutral. Theres only a few explanations for this. Shifter linkage malfunctioning, axle shaft poped out or there is serious internal damage to the transmission
post Sep 16, 2012 - 4:10 AM
Malhar95
Joined Jul 5, '09
From Katy/houston
Okay I was looking at the car again today...dot j ow how I missed it before but the passenger side cv axle is bad.
The boot is completely worn and basically torn off from where the clamp holds.
It's not the side that connects to the wheel, but the side that connects to the trany.
Could this cause the car reacting like such
(I'm going to fix it regardless but until I do curiosity)
post Sep 16, 2012 - 7:39 AM
zfjohnson07
Joined Apr 11, '09
dont think so, i bought a 94 that was ripped and still would drive with just one axle
4 Pages V   1 2 3 > »
Lo-Fi Version Time is now: July 31st, 2026 - 10:54 AM
