Sep 9, 2012 - 2:59 AM
Enthusiast ![]() ![]() ![]() Joined Jul 5, '09 From Katy/houston Currently Offline Reputation: 16 (100%) |
So with this parts car I have, the guy I got it from said The cv axles were bad that messed up the transition
Basically the car is in neutral. Even when we put it in park or drove it acts like its in neutral. Any suggestions what it could be? (when I was picking up the car, the driver side cv was being attempted to take out, like it was out of the hub nut not I pulled it a little bit but it didn't slip out, maybe the clip inside it broken, could that result in the car reacting this way?) Itd a 98 5sfe auto This post has been edited by Malhar95: Oct 5, 2012 - 9:50 AM -------------------- For Sale:OEM tail lights - make offer
Malhar95 98 5s stuck in neutral Sep 9, 2012 - 2:59 AM
Box Transmission solenoid perhaps. Sep 9, 2012 - 3:18 AM
Malhar95 QUOTE (Box @ Sep 9, 2012 - 4:18 AM) ... Sep 9, 2012 - 9:05 AM
richee3 I had a 5S auto tranny do that once. Here was the ... Sep 9, 2012 - 9:53 AM
Malhar95 QUOTE (richee3 @ Sep 9, 2012 - 9:53 ... Sep 11, 2012 - 3:07 PM
richee3 Not without LSD. An open diff will send power to t... Sep 11, 2012 - 3:09 PM
Malhar95 Oh yea lol...so what can I check for? Sep 11, 2012 - 3:12 PM
Smaay jack the car up, look behind the engine to see if ... Sep 11, 2012 - 3:53 PM
Malhar95 cv axles are in...
anything else i should check? ... Sep 12, 2012 - 4:16 PM
Special_Edy Yes check the shifter linkage if you havent alread... Sep 13, 2012 - 2:24 PM
zfjohnson07 well i found a 96 gt in fort worth for sale for 70... Sep 13, 2012 - 2:34 PM
Malhar95 QUOTE (zfjohnson07 @ Sep 13, 2012 - 3... Sep 13, 2012 - 3:09 PM
Special_Edy QUOTE (Malhar95 @ Sep 13, 2012 - 3:0... Sep 13, 2012 - 3:29 PM
Malhar95 Yup checked it it's rotating with the gears to... Sep 13, 2012 - 3:42 PM
Special_Edy The torque converter wouldnt make the transmission... Sep 13, 2012 - 4:03 PM
richee3 Silly question, and I'm sure it's the firs... Sep 13, 2012 - 4:45 PM
Special_Edy QUOTE (richee3 @ Sep 13, 2012 - 5:45... Sep 13, 2012 - 7:10 PM
zfjohnson07 http://dallas.craigslist.org/ftw/cto/3268078806.ht... Sep 13, 2012 - 5:14 PM
Malhar95 Okay I was looking at the car again today...dot j ... Sep 16, 2012 - 4:10 AM
zfjohnson07 dont think so, i bought a 94 that was ripped and s... Sep 16, 2012 - 7:39 AM
Malhar95 Never mind what I said earlier,
When I was trying... Sep 24, 2012 - 10:17 PM
Special_Edy QUOTE (Malhar95 @ Sep 24, 2012 - 10... Sep 24, 2012 - 11:26 PM
Malhar95 It's the passenger side,
Here's a pic Sep 25, 2012 - 1:23 AM
Special_Edy Yeah the carrier bearing is bolted to the engine b... Sep 25, 2012 - 9:23 AM
Malhar95 QUOTE (Special_Edy @ Sep 25, 2012 - 9... Sep 25, 2012 - 9:33 AM
Special_Edy QUOTE (Malhar95 @ Sep 25, 2012 - 10... Sep 25, 2012 - 10:53 AM
Smaay torn boot does not mean replace axle. the CV might... Sep 25, 2012 - 5:20 PM
Malhar95 QUOTE (Smaay @ Sep 25, 2012 - 5:20 P... Sep 25, 2012 - 6:46 PM
Special_Edy You could of done it in a day or weekend. Too bad ... Sep 25, 2012 - 11:15 PM
Malhar95 QUOTE (Special_Edy @ Sep 25, 2012 - 11... Sep 26, 2012 - 11:48 AM
richee3 I've found it's helpful to have a friend h... Sep 26, 2012 - 12:11 PM
Special_Edy You need a friend to hold down the brake pedal to ... Sep 26, 2012 - 12:12 PM
Malhar95 QUOTE (Special_Edy @ Sep 26, 2012 - 12... Sep 26, 2012 - 1:02 PM
Special_Edy We're both talking about the large nut that ho... Sep 26, 2012 - 1:08 PM
Malhar95 QUOTE (Special_Edy @ Sep 26, 2012 - 1... Sep 26, 2012 - 2:00 PM
Special_Edy Yeah your probably gonna need someone to hold the ... Sep 26, 2012 - 2:26 PM
zfjohnson07 if you come pick up special_edy ill come wth lol o... Sep 26, 2012 - 3:02 PM
Malhar95 If u guys wanna help I would appropriate it , I... Sep 26, 2012 - 3:22 PM
richee3 It sounds to me like the hub is turning with the a... Sep 26, 2012 - 3:37 PM
Malhar95 QUOTE (richee3 @ Sep 26, 2012 - 3:37... Sep 26, 2012 - 4:00 PM
Special_Edy Hmm thats bad if its like richee said, maybe a vid... Sep 26, 2012 - 4:10 PM
Malhar95 I'll make one tonight, probably bad lighting b... Sep 26, 2012 - 4:27 PM
richee3 Well lets hope that its only the axle that is dama... Sep 26, 2012 - 5:19 PM
Malhar95 How would the hub be damaged? I'm still confus... Sep 26, 2012 - 5:36 PM
richee3 The end of the axle and the hub both have splines ... Sep 26, 2012 - 6:05 PM
Malhar95 Okay makes sense. Thanks
But the thing is, if I do... Sep 26, 2012 - 6:57 PM
Malhar95 I'm sorry but this is what I could do rite now... Sep 30, 2012 - 6:24 PM
Special_Edy Yes the passengerside cv axle is bad, order a new ... Sep 30, 2012 - 7:58 PM
Malhar95 That's the problem, when I'm trying to rep... Oct 1, 2012 - 10:09 AM
zfjohnson07 try pinch off tool i understand its not round but ... Oct 1, 2012 - 2:53 PM
Special_Edy Watch this first one, its the best explanation you... Oct 2, 2012 - 12:48 AM
Malhar95 Okay so I had it towed to a shop (just brakes) for... Oct 2, 2012 - 9:16 PM
Special_Edy IDK what format your video is, I cant watch it.
A... Oct 2, 2012 - 11:31 PM
zfjohnson07 if you want to make sre you get the right axle go ... Oct 2, 2012 - 11:54 PM
Malhar95 Went to advance, I'm pretty sure it's the ... Oct 3, 2012 - 2:09 AM
Malhar95 http://i855.photobucket.com/albums/ab119/m...0A840... Oct 4, 2012 - 5:25 PM
Malhar95 Did everyone stop caring about this now haha Oct 5, 2012 - 7:56 PM
Special_Edy QUOTE (Malhar95 @ Oct 5, 2012 - 7:56... Oct 6, 2012 - 2:03 PM
Malhar95 QUOTE (Special_Edy @ Oct 6, 2012 - 2... Oct 6, 2012 - 3:32 PM
Malhar95 Passenger side replaced, car runs now. I can drive... Oct 6, 2012 - 8:11 PM
Box . Oct 6, 2012 - 9:20 PM
Malhar95 Transmission shop diagnosed it as a bad bearing
It... Oct 9, 2012 - 5:12 PM
Malhar95 Transmission shop called and said the differential... Oct 10, 2012 - 6:01 PM
Smaay 600 bucks!!! dude you can find another... Oct 11, 2012 - 8:50 AM
Malhar95 Yea that's what I though but then u dont reall... Oct 11, 2012 - 3:42 PM
Special_Edy I dont understand why you need a transmission. You... Oct 12, 2012 - 10:07 AM
Malhar95 QUOTE (Special_Edy @ Oct 12, 2012 - 10... Oct 12, 2012 - 11:38 AM
Malhar95 car came back today. apparently after the differen... Oct 24, 2012 - 9:11 PM![]() ![]() |
| Lo-Fi Version | Time is now: August 4th, 2026 - 2:59 PM |
