> 98 5s stuck in neutral, Video of exactly what's happening uploaded last page
post Sep 9, 2012 - 2:59 AM
Malhar95
Joined Jul 5, '09
From Katy/houston
So with this parts car I have, the guy I got it from said The cv axles were bad that messed up the transition
Basically the car is in neutral. Even when we put it in park or drove it acts like its in neutral.
Any suggestions what it could be?
(when I was picking up the car, the driver side cv was being attempted to take out, like it was out of the hub nut not I pulled it a little bit but it didn't slip out, maybe the clip inside it broken, could that result in the car reacting this way?)
Itd a 98 5sfe auto
This post has been edited by Malhar95: Oct 5, 2012 - 9:50 AM
- Malhar95   98 5s stuck in neutral   Sep 9, 2012 - 2:59 AM
- - Box   Transmission solenoid perhaps.   Sep 9, 2012 - 3:18 AM
|- - Malhar95   QUOTE (Box @ Sep 9, 2012 - 4:18 AM) ...   Sep 9, 2012 - 9:05 AM
- - richee3   I had a 5S auto tranny do that once. Here was the ...   Sep 9, 2012 - 9:53 AM
|- - Malhar95   QUOTE (richee3 @ Sep 9, 2012 - 9:53 ...   Sep 11, 2012 - 3:07 PM
- - richee3   Not without LSD. An open diff will send power to t...   Sep 11, 2012 - 3:09 PM
- - Malhar95   Oh yea lol...so what can I check for?   Sep 11, 2012 - 3:12 PM
- - Smaay   jack the car up, look behind the engine to see if ...   Sep 11, 2012 - 3:53 PM
- - Malhar95   cv axles are in... anything else i should check? ...   Sep 12, 2012 - 4:16 PM
- - Special_Edy   Yes check the shifter linkage if you havent alread...   Sep 13, 2012 - 2:24 PM
- - zfjohnson07   well i found a 96 gt in fort worth for sale for 70...   Sep 13, 2012 - 2:34 PM
|- - Malhar95   QUOTE (zfjohnson07 @ Sep 13, 2012 - 3...   Sep 13, 2012 - 3:09 PM
|- - Special_Edy   QUOTE (Malhar95 @ Sep 13, 2012 - 3:0...   Sep 13, 2012 - 3:29 PM
- - Malhar95   Yup checked it it's rotating with the gears to...   Sep 13, 2012 - 3:42 PM
- - Special_Edy   The torque converter wouldnt make the transmission...   Sep 13, 2012 - 4:03 PM
- - richee3   Silly question, and I'm sure it's the firs...   Sep 13, 2012 - 4:45 PM
|- - Special_Edy   QUOTE (richee3 @ Sep 13, 2012 - 5:45...   Sep 13, 2012 - 7:10 PM
- - zfjohnson07   http://dallas.craigslist.org/ftw/cto/3268078806.ht...   Sep 13, 2012 - 5:14 PM
- - Malhar95   Okay I was looking at the car again today...dot j ...   Sep 16, 2012 - 4:10 AM
- - zfjohnson07   dont think so, i bought a 94 that was ripped and s...   Sep 16, 2012 - 7:39 AM
- - Malhar95   Never mind what I said earlier, When I was trying...   Sep 24, 2012 - 10:17 PM
|- - Special_Edy   QUOTE (Malhar95 @ Sep 24, 2012 - 10...   Sep 24, 2012 - 11:26 PM
- - Malhar95   It's the passenger side, Here's a pic   Sep 25, 2012 - 1:23 AM
- - Special_Edy   Yeah the carrier bearing is bolted to the engine b...   Sep 25, 2012 - 9:23 AM
|- - Malhar95   QUOTE (Special_Edy @ Sep 25, 2012 - 9...   Sep 25, 2012 - 9:33 AM
|- - Special_Edy   QUOTE (Malhar95 @ Sep 25, 2012 - 10...   Sep 25, 2012 - 10:53 AM
- - Smaay   torn boot does not mean replace axle. the CV might...   Sep 25, 2012 - 5:20 PM
|- - Malhar95   QUOTE (Smaay @ Sep 25, 2012 - 5:20 P...   Sep 25, 2012 - 6:46 PM
- - Special_Edy   You could of done it in a day or weekend. Too bad ...   Sep 25, 2012 - 11:15 PM
|- - Malhar95   QUOTE (Special_Edy @ Sep 25, 2012 - 11...   Sep 26, 2012 - 11:48 AM
- - richee3   I've found it's helpful to have a friend h...   Sep 26, 2012 - 12:11 PM
- - Special_Edy   You need a friend to hold down the brake pedal to ...   Sep 26, 2012 - 12:12 PM
|- - Malhar95   QUOTE (Special_Edy @ Sep 26, 2012 - 12...   Sep 26, 2012 - 1:02 PM
- - Special_Edy   We're both talking about the large nut that ho...   Sep 26, 2012 - 1:08 PM
|- - Malhar95   QUOTE (Special_Edy @ Sep 26, 2012 - 1...   Sep 26, 2012 - 2:00 PM
- - Special_Edy   Yeah your probably gonna need someone to hold the ...   Sep 26, 2012 - 2:26 PM
- - zfjohnson07   if you come pick up special_edy ill come wth lol o...   Sep 26, 2012 - 3:02 PM
- - Malhar95   If u guys wanna help I would appropriate it , I...   Sep 26, 2012 - 3:22 PM
- - richee3   It sounds to me like the hub is turning with the a...   Sep 26, 2012 - 3:37 PM
|- - Malhar95   QUOTE (richee3 @ Sep 26, 2012 - 3:37...   Sep 26, 2012 - 4:00 PM
- - Special_Edy   Hmm thats bad if its like richee said, maybe a vid...   Sep 26, 2012 - 4:10 PM
- - Malhar95   I'll make one tonight, probably bad lighting b...   Sep 26, 2012 - 4:27 PM
- - richee3   Well lets hope that its only the axle that is dama...   Sep 26, 2012 - 5:19 PM
- - Malhar95   How would the hub be damaged? I'm still confus...   Sep 26, 2012 - 5:36 PM
- - richee3   The end of the axle and the hub both have splines ...   Sep 26, 2012 - 6:05 PM
- - Malhar95   Okay makes sense. Thanks But the thing is, if I do...   Sep 26, 2012 - 6:57 PM
- - Malhar95   I'm sorry but this is what I could do rite now...   Sep 30, 2012 - 6:24 PM
- - Special_Edy   Yes the passengerside cv axle is bad, order a new ...   Sep 30, 2012 - 7:58 PM
- - Malhar95   That's the problem, when I'm trying to rep...   Oct 1, 2012 - 10:09 AM
- - zfjohnson07   try pinch off tool i understand its not round but ...   Oct 1, 2012 - 2:53 PM
- - Special_Edy   Watch this first one, its the best explanation you...   Oct 2, 2012 - 12:48 AM
- - Malhar95   Okay so I had it towed to a shop (just brakes) for...   Oct 2, 2012 - 9:16 PM
- - Special_Edy   IDK what format your video is, I cant watch it. A...   Oct 2, 2012 - 11:31 PM
- - zfjohnson07   if you want to make sre you get the right axle go ...   Oct 2, 2012 - 11:54 PM
- - Malhar95   Went to advance, I'm pretty sure it's the ...   Oct 3, 2012 - 2:09 AM
- - Malhar95   http://i855.photobucket.com/albums/ab119/m...0A840...   Oct 4, 2012 - 5:25 PM
- - Malhar95   Did everyone stop caring about this now haha   Oct 5, 2012 - 7:56 PM
|- - Special_Edy   QUOTE (Malhar95 @ Oct 5, 2012 - 7:56...   Oct 6, 2012 - 2:03 PM
|- - Malhar95   QUOTE (Special_Edy @ Oct 6, 2012 - 2...   Oct 6, 2012 - 3:32 PM
- - Malhar95   Passenger side replaced, car runs now. I can drive...   Oct 6, 2012 - 8:11 PM
- - Box   .   Oct 6, 2012 - 9:20 PM
- - Malhar95   Transmission shop diagnosed it as a bad bearing It...   Oct 9, 2012 - 5:12 PM
- - Malhar95   Transmission shop called and said the differential...   Oct 10, 2012 - 6:01 PM
- - Smaay   600 bucks!!! dude you can find another...   Oct 11, 2012 - 8:50 AM
- - Malhar95   Yea that's what I though but then u dont reall...   Oct 11, 2012 - 3:42 PM
- - Special_Edy   I dont understand why you need a transmission. You...   Oct 12, 2012 - 10:07 AM
|- - Malhar95   QUOTE (Special_Edy @ Oct 12, 2012 - 10...   Oct 12, 2012 - 11:38 AM
- - Malhar95   car came back today. apparently after the differen...   Oct 24, 2012 - 9:11 PM
Lo-Fi Version Time is now: May 15th, 2026 - 9:04 AM
