> [5s-fe] Engine doesnt turn over.
post Sep 12, 2012 - 2:00 PM
Syaoran
Joined Jan 4, '12
From US
So, I went to turn on the car this morning and I missed two of my classes thanks to it not wanting to start over.
I have not done diagnostics as I had no time to do so. I tried turning it over many times and the lights just dimmed down as if cranking but there was no response.
1993 Celica GT Coupe - sold
1994 Celica GT Liftback
post Sep 12, 2012 - 4:15 PM
Box
Joined Feb 23, '12
From Warrior, AL
I'm going to go out on a whim and say dead battery.
2001 Miata LS 5-speed
post Sep 12, 2012 - 5:27 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
QUOTE (Box @ Sep 12, 2012 - 2:15 PM) *
ill second that...seriously OP?
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Sep 12, 2012 - 7:17 PM
zfjohnson07
Joined Apr 11, '09
or BAD CONNECTION! We just discussed this already:
http://www.6gc.net/forums/index.php?showtopic=86029
and seriously, the lights dimmed and you didnt realzie that the battery might be going dead? frown.gif tisk tisk, maybe you should trade your celica and get a honda tongue.gif
post Sep 12, 2012 - 7:58 PM
richee3
Joined Jun 29, '08
From Denver
The lights will dim even on a fully charged battery. That's normal. It's just to what extent they dim. It could easily be a loose or corroded battery terminal mimicking a dead battery. Or, I've seen batteries that are great one time you start thR car, leave it sit for a few hours, and the battery is shot. (Wal Mart Neverstart batteries in that instance.) Either way, I'm willing to bet its something battery related and that your next post in this thread will be like "I had a look at it and the problem was (insert incredibly simple fix here.) I can't believe I missed that!" Good luck. thumbsup.gif
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
richee3
Joined Jun 29, '08
From Denver
Double post.
This post has been edited by richee3: Sep 12, 2012 - 7:59 PM
1998 Celica GT-
BEAMS Swapped.
post Sep 12, 2012 - 8:15 PM
Syaoran
Joined Jan 4, '12
From US
QUOTE (richee3 @ Sep 12, 2012 - 8:58 PM) *
Lights even dim when starting my Mazda3, and it has a brand new Optima Yellowtop. The car always dims the lights when cranking. Voltage drops from 12v to around 9v when cranking a car. I'm not an idiot. (comment directed at everyone else)
I'm going to do some tests tonight and tomorrow morning and I'll see what happens, but it's starting to look like something starter related rather than battery (relay or starter itself)
EDIT:
Went to start it earlier without doing anything to it, and it just decided to start over just fine.
I guess it didn't want to go to college today.
This post has been edited by Syaoran: Sep 12, 2012 - 10:11 PM
post Sep 13, 2012 - 12:25 AM
TannerEsser
Joined Oct 17, '11
From Kent, WA
QUOTE (Syaoran @ Sep 12, 2012 - 8:15 PM) *
EDIT:
i think he charged it and he isn't telling us.. biggrin.gif btw your battery should never read 9v even 12.00v is a dead battery a charged battery should be around 12.6v
post Sep 13, 2012 - 12:44 AM
Syaoran
Joined Jan 4, '12
From US
I'll just have to tell you to take my word for it. Charging a cheap, wet-cell battery isn't a good idea either. Let's see if it doesn't do it again tomorrow. This car has a life of its own.
post Sep 13, 2012 - 2:00 AM
6gcpr
Joined Apr 29, '11
From Puerto Rico
Had the same problem today with my celica as well. It has a new battery, turned on fine the other day, today nothing. I'll check it again in two days or so and see if it feels like turning on hahaha
1980 mitsubishi champ- stolen
1995 toyota corolla. - daily driver
1994 toyota celica gt. - project car
1984 honda civic hatch - wifes
post Sep 13, 2012 - 2:30 AM
Syaoran
Joined Jan 4, '12
From US
QUOTE (TannerEsser @ Sep 13, 2012 - 1:25 AM) *
Go measure the voltage going to your ECU's main power, or anything that needs to have power while cranking. Come back to me with your results. 12.5V is a brand new battery. Most car electrical systems are meant to run using 12V. Anything below 12V and you should check your battery (unless you have a lower voltage only when cranking, which is perfectly normal)
The power wire going to my Megasquirt-II reads 9V when cranking, 12.5V while in the "on" position, and 14v while on.
QUOTE (6gcpr @ Sep 13, 2012 - 3:00 AM) *
I have a feeling it's got something to do with the starter, hopefully not the starter itself... that's going to cost some money.
post Sep 13, 2012 - 2:38 AM
6gcpr
Joined Apr 29, '11
From Puerto Rico
Lets hope its not the starter, that will set u back for a while money wise. Bought a new starter for the 84 civic and it cost $80!!! 1984!!
post Sep 13, 2012 - 8:09 AM
Special_Edy
Joined Oct 29, '11
From Haltom City, Texas
EDIT:
It takes 75%-85% of a full charge to crank the starter. If your battery is at 12 volts then it has less than 25% charge. If it dips below 12 volts then it is fully discharged.
You need about 12.4-12.5 volts normally to start the car
post Sep 13, 2012 - 9:14 AM
Smaay
Joined Dec 8, '03
From Lancaster CA
QUOTE (6gcpr @ Sep 13, 2012 - 12:38 AM) *
i dont miss the days when i thought 80 bucks was a setback. i just spent 250 bucks on the bearings for my Supra alone! that's just the freaking bearings. I have already spent over 4,000 bucks in rebuilding the engine. Just in buying parts.
post Sep 13, 2012 - 12:57 PM
Syaoran
Joined Jan 4, '12
From US
QUOTE (Special_Edy @ Sep 13, 2012 - 9:09 AM) *
EDIT:
All I can say is go measure power going to something that has to keep power while cranking (e.g. ECU)
I think there's a misunderstanding from both sides.
QUOTE (Smaay @ Sep 13, 2012 - 10:14 AM) *
Well that's all part of having one of the most overrated cars on this side of the globe (thank you Fast & Furious)
This is supposed to be relatively inexpensive since a Camry is pretty much so.
post Sep 13, 2012 - 1:24 PM
Xander_X
Joined Apr 22, '12
From Central NY
Sounds like the actuator in the starter is sticking.
99 Celica GT-S
91 Subaru Legacy Sport AWD Turbo
2010 Acura RDX Turbo w/ Technology Package
68 Impala SS Convertable
post Sep 13, 2012 - 1:26 PM
Syaoran
Joined Jan 4, '12
From US
QUOTE (Xander_X @ Sep 13, 2012 - 2:24 PM) *
Is that the solenoid with the single, 16ga wire going to it?
post Sep 14, 2012 - 3:09 PM
TannerEsser
Joined Oct 17, '11
From Kent, WA
QUOTE (Syaoran @ Sep 13, 2012 - 3:30 AM) *
what ever your thinkin man! ****ty battery is a ****ty battery my battery doesnt read that.... why dont you try opening a text book. if you dont want to take peoples advice and be an ass about it. then dont ask for help. damn. push start the bi*ch for all i care.
post Sep 14, 2012 - 3:55 PM
Special_Edy
Joined Oct 29, '11
QUOTE (Syaoran @ Sep 13, 2012 - 1:26 PM) *
Smack it with a wrench, if it suddenly starts then there is your problem.^^
Id be looking at the ground wires, the two on top of the transmission and the one next to the alternator. Also, check your battery cables. Everyone checks the clamp itself and battery posts but they are usually to stupid to check the connection between the clamp and cable
This post has been edited by Special_Edy: Sep 14, 2012 - 5:28 PM
post Sep 14, 2012 - 4:15 PM
Syaoran
Joined Jan 4, '12
From US
I'm pretty close to redoing all major wires. I want to do a battery relocation to the trunk, and I think I'm going to refresh everything with new OFC wiring.
Lo-Fi Version Time is now: September 15th, 2026 - 11:38 AM
