> rear disc conversion
post Sep 12, 2012 - 6:46 PM
Amanda66
Joined Jun 20, '12
From Tucson, az
Will the rear disc brakes on a 92 Celica fit on my 97?
post Sep 12, 2012 - 11:41 PM
Hanyo
Joined Aug 16, '03
From Bay area
with some modification. yes!
http://www.6gc.net/forums/index.php?showtopic=45705
This post has been edited by Hanyo: Sep 12, 2012 - 11:42 PM
post Sep 19, 2012 - 2:06 PM
Amanda66
Joined Jun 20, '12
From Tucson, az
QUOTE (Hanyo @ Sep 12, 2012 - 11:41 PM) *
what year gt celica should i be looking for to rob the disc brakes off of and just go right in with little to no modification.
post Sep 19, 2012 - 2:19 PM
richee3
Joined Jun 29, '08
From Denver
Currently Online
Not sure I understand the question, but all 6th gen GT rotors/calipers/e-brake cables should fit right on to an ST with no modification, whereas the 5th gen brakes will require some work.
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Sep 19, 2012 - 3:45 PM
Amanda66
Joined Jun 20, '12
From Tucson, az
QUOTE (richee3 @ Sep 19, 2012 - 3:19 PM) *
K so from what 1993-1998? right?
post Sep 19, 2012 - 4:32 PM
BonzaiCelica
Joined Apr 24, '08
From Orange County, CA
QUOTE (Amanda66 @ Sep 19, 2012 - 3:45 PM) *
only from 1994-1999 celica's. the celica that looks like our cars with the 4 headlights
post Sep 19, 2012 - 5:04 PM
Amanda66
Joined Jun 20, '12
From Tucson, az
QUOTE (BonzaiCelica @ Sep 19, 2012 - 5:32 PM) *
post Sep 19, 2012 - 7:36 PM
i wll have rear calipers for sale soon. from a GT
post Sep 20, 2012 - 9:39 AM
Amanda66
Joined Jun 20, '12
From Tucson, az
QUOTE (njccmd2002 @ Sep 19, 2012 - 8:36 PM) *
sweet pm me when you have them for sale if i haven't found any by then i will deffinately buy them off you. thank you so much ^_^
post Sep 24, 2012 - 10:08 AM
celica74
Joined Feb 8, '10
From North Carolina
Does the hub have to be replaced? Or do you just remove the drum and shoes and slap on a caliper and rotor. I think this is the biggest ordeal with this conversion.
post Sep 24, 2012 - 5:29 PM
Amanda66
Joined Jun 20, '12
From Tucson, az
QUOTE (celica74 @ Sep 24, 2012 - 10:08 AM) *
post Sep 24, 2012 - 7:14 PM
Galcobar
Joined Mar 3, '05
From Richmond, B.C.
The hub is the piece upon which the rotor and wheel are mounted, which contains the bearing. On FWD cars, the rear hubs are only attached to the axle carrier (usually called that even though there's no axle).
A new hub is not necessary. However, you have to remove and replace the hub from the axle carrier in order to switch from the drum brake backing plate to the disc brake backing plate. This requires you to purchase a new O-ring for the hub.
Rear disc brakes on Toyotas use a drum-in-rotor design, where a small drum brake operated only by the e-brake handle is integrated into the rear disc. The hardware for the parking brake is mounted to a backing plate. You have to swap over the parking brake hardware and the cable (the e-brake cable from full drum brakes doesn't match the cable used on rear discs) as well as the rotor and caliper.
The hub is also the source of the difference between a fifth-gen and a sixth-gen centrebore. The rotor and the wheels are centre mounted, meaning the centre hole slides snugly over the hub. The fifth-gen hub is 54 mm in diametre, while the sixth-gen hub is 55 mm. Thus the hole in a fifth-gen rotor is 1 mm too small to fit onto a sixth-gen hub.
post Sep 25, 2012 - 11:57 AM
celica74
Joined Feb 8, '10
From North Carolina
Exactly what i need to know. Thanks
post Sep 27, 2012 - 5:30 PM
Amanda66
Joined Jun 20, '12
From Tucson, az
post Sep 28, 2012 - 3:55 AM
Galcobar
Joined Mar 3, '05
From Richmond, B.C.
A more complete discussion of the matter, albeit for a fifth-gen, is here: http://www.celicatech.com/forums/showthrea...Upgrade-Article
I suggest reading through the entire thread, it's only three pages with a fair number of photos.
post Sep 28, 2012 - 6:34 AM
its easy. only a couple of blots.
post Sep 28, 2012 - 11:24 AM
Amanda66
Joined Jun 20, '12
From Tucson, az
QUOTE (njccmd2002 @ Sep 28, 2012 - 6:34 AM) *
That's good I'm going out this weekend to a couple of salvage yards and see if I can find what I need. Wish me luck lol kindasad.gif
Lo-Fi Version Time is now: September 3rd, 2026 - 8:38 PM
