Jan 28, 2013 - 10:40 AM
Enthusiast ![]() ![]() ![]() ![]() Joined Sep 27, '10 From pittsburgh Currently Offline Reputation: 4 (100%) |
How does this work? Currently I dont have the diag port wired, but i'm assuming its the TE1/TE2 connections on the ECU.
Engine is still cutting out in the high rpms after I run it for 20 very hard miles. Starts at like 6k rpms then slowly works it way down to 3500 rpm. Replaced the ignition system and it did nothing. -------------------- -93 Rx7, Turbo 6.1L v8, 725rwhp/760rwtq
-95 Celica GT Rally Car - 3sge/AWD -10 F150 Always buying stock wheels... PM me if interested in selling. |
Jan 28, 2013 - 5:14 PM
whats the gap on the plugs?
Jan 29, 2013 - 7:27 AM
whats the gap on the plugs? To be honest I cant remember, probably .035-.04. I can check, it's nothing crazy like the .01x i run on my rx7. -------------------- -93 Rx7, Turbo 6.1L v8, 725rwhp/760rwtq
Jan 29, 2013 - 9:05 AM
Enthusiast ![]() ![]() Joined Mar 1, '12 From iowa Currently Offline Reputation: 0 (0%) |
What year is the car? Which obd harness are you running? What year ecu are you using?
Jan 29, 2013 - 9:19 AM
What year is the car? Which obd harness are you running? What year ecu are you using? 3rd gen 3sge. No OBD harness. Pretty much a custom harness. I checked it last night, the engine light just flashes continuously with the same intervals and no pauses, which according to the manual says theres no codes. But there is a check engine light on, so i'm not sure whats up with that. -------------------- -93 Rx7, Turbo 6.1L v8, 725rwhp/760rwtq
Jan 29, 2013 - 1:43 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 11, '08 From Auckland, New Zealand Currently Offline Reputation: 0 (0%) |
fuel and spark are the only things i can think of that will show up nothing on the dashboard
-------------------- Mike W
| Lo-Fi Version | Time is now: June 25th, 2026 - 3:29 PM |
