Mar 17, 2013 - 12:38 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jul 12, '08 Currently Offline Reputation: 5 (100%) |
Hello 6gc,
My release bearing started making noise whenever the clutch pedal was pushed in the other week. I reluctantly got everything ready and tore the transmission out. When I finally reached the culprit bearing I noticed that the inner race wasn't snug against the input shaft collar. This made me suspect that maybe clutchmasters sent me the release bearing for an e153 when they put my hybrid clutch kit together. Sure enough when I checked on my awd trans, the bearing slid onto the input shaft collar with a snug fit. I also checked on toyodiy and the e153 and s54 do indeed have different part numbers for their bearings. What all this means is that my release bearing has most likely been exposed to radial loads every time I pressed on the clutch, which would explain the short life. So that's my assessment for the moment. However before I purchase a bearing from Toyota I'd like to confirm that you guys use an s54 specific release bearing with your hybrid clutch setups. Who knows maybe a little slop between the bearing and shaft collar is no big deal and I should chalk it up to a defective bearing This post has been edited by enderswift: Mar 17, 2013 - 12:41 PM -------------------- ![]() |
Mar 17, 2013 - 1:19 PM
It takes an S54 TOB.
Mar 17, 2013 - 11:32 PM
That's what I figured. Sigh, still wanted to make sure because I have certainly been surprised by counter intuitive stuff more than once.
This post has been edited by enderswift: Mar 18, 2013 - 2:14 PM -------------------- ![]() |
Mar 18, 2013 - 12:59 AM
Enthusiast ![]() ![]() ![]() Joined Jan 26, '09 From Los Angeles Currently Offline Reputation: 1 (100%) |
Well damn..I noticed the slop too when I put my hybrid clutch together.
I used the old retaining clip from the s54 because the one CM sent me with the bearing was a little different...I really..really hope the slop is normal and you just got a defective bearing.. -------------------- |
Mar 18, 2013 - 1:31 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 7, '07 From Corpus Christi, TX Currently Offline Reputation: 7 (100%) |
This maybe a stupid question and I hope I'm not thread jacking. I still don't understand why u would need a 3sgte clutch and an s54 input shaft collar if the trans mates and works fine with the 3sgte. Why not just use 3/5sfe clutch and gte pressure plate then?
This post has been edited by Lil-Joe101: Mar 18, 2013 - 1:33 AM -------------------- From Japan to Texas my st202 follows me.
![]() Being different from every angle of the word, leading the Revolution (TOYOTA NATION) The RHD st202 that made it from Japan check it out. http://www.6gc.net/forums/index.php?showtopic=78103 |
Mar 18, 2013 - 7:22 AM
Enthusiast ![]() ![]() ![]() ![]() Joined May 16, '10 From Raleigh Currently Offline Reputation: 12 (100%) |
The splines are different.
Mar 18, 2013 - 10:43 AM
The splines are different. Yup the splines are different and the shaft collar OD is different between the s54 and the e153. Which means a hybrid setup needs a 3s clutch kit with an s54 spline on the disc, and an s54 release bearing to properly fit the collar. On the one hand I can see how clutchmasters made the mistake, but on the other hand clutch combos are why they exist... -------------------- ![]() |
Mar 18, 2013 - 11:00 AM
Hello 6gc, My release bearing started making noise whenever the clutch pedal was pushed in the other week. I reluctantly got everything ready and tore the transmission out. When I finally reached the culprit bearing I noticed that the inner race wasn't snug against the input shaft collar. This made me suspect that maybe clutchmasters sent me the release bearing for an e153 when they put my hybrid clutch kit together. Sure enough when I checked on my awd trans, the bearing slid onto the input shaft collar with a snug fit. I also checked on toyodiy and the e153 and s54 do indeed have different part numbers for their bearings. What all this means is that my release bearing has most likely been exposed to radial loads every time I pressed on the clutch, which would explain the short life. So that's my assessment for the moment. However before I purchase a bearing from Toyota I'd like to confirm that you guys use an s54 specific release bearing with your hybrid clutch setups. Who knows maybe a little slop between the bearing and shaft collar is no big deal and I should chalk it up to a defective bearing I had the same problem with clutchmasters. The TO bearing the sent was loose on the input shaft, and I had to special order an s54 one from toyota. Id call CM and see if they can at least give you a partial refund or something. And tell them this is not the first time this has happened. When I ordered mine, I was very clear about what I wanted and they still made a mistake. Lucky I caught it before everything got put back together. This maybe a stupid question and I hope I'm not thread jacking. I still don't understand why u would need a 3sgte clutch and an s54 input shaft collar if the trans mates and works fine with the 3sgte. Why not just use 3/5sfe clutch and gte pressure plate then? A 5sfe pressure plate doesn't bolt up to a 3sgte motor. So you need a 5sfe clutch kit (clutch, throw out bearing, alignment tool), with a 3sgte pressure plate. -------------------- 15PSI - 30MPG - Megasquirt Tuned
Mar 21, 2013 - 8:33 PM
QUOTE I had the same problem with clutchmasters. The TO bearing the sent was loose on the input shaft, and I had to special order an s54 one from toyota. Id call CM and see if they can at least give you a partial refund or something. And tell them this is not the first time this has happened. When I ordered mine, I was very clear about what I wanted and they still made a mistake. Lucky I caught it before everything got put back together. Thanks for chiming in. In a way I'm glad that I'm not the only one that had to go through this. I just installed the proper bearing and the car is running fantastically again. Plus its a little easier to pull away from a dead stop smoothly now. I've already emailed CM and they aren't responding. I doubt they'll want to work something out, especially since its past the 90 day limit. Heads up everyone check your bearings! -------------------- ![]() |
Mar 23, 2013 - 12:30 PM
this is why i recommend Southbend. just call them up, tell john or andy what you have and they will send it out.
Mar 23, 2013 - 4:18 PM
Well damn..I noticed the slop too when I put my hybrid clutch together. I used the old retaining clip from the s54 because the one CM sent me with the bearing was a little different...I really..really hope the slop is normal and you just got a defective bearing.. If you had to change out the clip then you for sure got the wrong bearing. the e153 clutch fork has notches cut into it for the clip to fit into, whearas the s54 piece has no notches. If you develope a whine that only comes on when the clutch is pushed in then you're in for some fun. Smaay how much commission do you earn per southbend referral? -------------------- ![]() |
Mar 23, 2013 - 6:42 PM
none, a few years ago i needed a clutch and they hooked me up, i dont get anything special from them, im just very happy with their quality clutches and service.
| Lo-Fi Version | Time is now: September 1st, 2026 - 12:08 AM |
