> CPR Celica Project
post Apr 28, 2013 - 9:12 AM
fatherof4
Joined Sep 25, '11
From GreatSmokyMtns NC
First a little about me. Single father of 4 kids. The oldest is 22, youngest is 13. So I dont think there is any way I'm going to be able to keep them away from this car.
We got the Celi a little over a year ago from my sister. It was her daily driver. As I understand she took it to one of the quick oil change places and had the oil changed.
three days later it started making noise. "Ckicking" low in the motor. Then just froze up.
She knew I liked the car so she gave it to me. It has been sitting for a year in the barn. First idea was a engine swap but I ditched the idea because I need the car to be simple enough to be fixed if the kids breaks down. And my 17 year old son is not taking on his buddy in his Sti.
I have done a LOT of reading...and I mean hours. I love this site! This wont be a 200hp car but I'd like to make it a car the looks good and is reliable enough for the kids to get to have fun with. (when they can pry it away from Daddy)
Ok, After a lot of searching I found a replacement 7afe with about 122,000. Pulled the valve cover and it looks clean. Still has the wire harness attached.
Spent the next few days ordering parts. (95 ST.) I want to know if anyone can think of something I'm missing. I'd like to do all this while the motor is out.
Exedy KTY18 Clutch kit.... Toyota OEM Rear main seal.
Penzoil Synchrom.... Toyota OEM Axle seals.
Oil Filter.... Timing belt
Fuel/Gas filter..... Timing belt tensioner
Air filter..... Timing belt tensioner spring
Distributor cap.... Valve cover gasket
Distributor Rotor.... Four spark plug tube seals
NGK Wire Set..... Three accessory drive belts
NGK Platinum Spark Plugs.... Front crankshaft seal
PCV Valve..... Camshaft seal
Distributor O-Ring..... Oil Drain Plug & Washer/Seal
Ebay Header (Not Headers lol)..... Heat wrap for header
Thermostat and gasket...... New Vacuum hoses
New Radiator hoses....... CAI Kit 90/93 Accord
Turned Flywheel...... Break pads/ Turned roters
Pulled motor, Checked motor mounts. And now we wait....
This post has been edited by fatherof4: Apr 28, 2013 - 9:18 AM
"Wheelman" for the Cardboard Mafia"
https://www.facebook.com/robert.davis.520
- fatherof4   CPR Celica Project   Apr 28, 2013 - 9:12 AM
- - fatherof4   Got some stuff in this week. Waiting on the head   May 4, 2013 - 11:59 AM
- - JoshuaM   Another Celi saved I wish my dad rebuilt a Celic...   May 4, 2013 - 7:49 PM
- - fatherof4   Cleaned most of the block today. whats the best wa...   May 5, 2013 - 5:45 PM
- - fatherof4   All the Parts came in from Toyota today for the he...   May 7, 2013 - 9:51 PM
- - jesse09   Looks like a fun project! Will be well worth t...   May 7, 2013 - 10:11 PM
- - rentaspace   Great to see another Celica saved from the scrap h...   May 7, 2013 - 10:18 PM
- - fatherof4   Head work is finally done.   May 11, 2013 - 4:24 PM
- - cheela   way to save a celi! We'll see how time you...   May 11, 2013 - 5:42 PM
- - fatherof4   Got a little more done today. Had to take a break ...   May 12, 2013 - 8:27 PM
- - fatherof4   Hope these sound good.   May 16, 2013 - 9:16 PM
- - RabidTRD   That's a good setup on the exhaust. I was opti...   May 16, 2013 - 10:40 PM
- - fatherof4   Da boy has to work weekends so he helps when he ca...   May 17, 2013 - 6:25 AM
- - Syaoran   Looks good so far. You mind sharing part number o...   May 23, 2013 - 2:31 AM
- - fatherof4   The part Number on the Megaflow is 14832. Ordered ...   May 23, 2013 - 5:45 AM
- - Syaoran   Thanks. A 1z swap as in 1zz?   May 23, 2013 - 8:22 AM
|- - richee3   QUOTE (Syaoran @ May 23, 2013 - 8:22...   May 23, 2013 - 2:06 PM
|- - Syaoran   QUOTE (richee3 @ May 23, 2013 - 3:06...   May 24, 2013 - 11:53 AM
|- - kurt95gt   QUOTE (richee3 @ May 23, 2013 - 2:06...   Jul 7, 2013 - 9:40 PM
- - fatherof4   Had to work alone today but I got it installed. To...   May 25, 2013 - 8:12 PM
- - Syaoran   Lookin good!   May 26, 2013 - 11:13 AM
- - fatherof4   Got some more done today. Tomorrow axles, Brakes a...   May 26, 2013 - 6:16 PM
- - fatherof4   It RUNS!!! Started on first try...   May 27, 2013 - 5:33 PM
- - fatherof4   http://www.youtube.com/watch?v=-V27Swxepd0   May 27, 2013 - 5:46 PM
- - Bitter   Don't forget the resonator after the cat, othe...   May 27, 2013 - 6:34 PM
|- - fatherof4   QUOTE (Bitter @ May 27, 2013 - 7:34 ...   May 27, 2013 - 8:49 PM
- - Syaoran   Right at the end that look at the camera felt like...   May 27, 2013 - 8:09 PM
- - fatherof4   Exhaust installed today. It was running a little r...   May 28, 2013 - 6:30 PM
|- - Box   QUOTE (fatherof4 @ May 28, 2013 - 6...   May 28, 2013 - 6:38 PM
- - Syaoran   Check the timing with a timing light. To read pr...   May 28, 2013 - 6:51 PM
- - fatherof4   Thanks, I'll check it this weekend.   May 28, 2013 - 8:42 PM
- - ricochet1490   You haven't been given nearly enough props for...   May 29, 2013 - 7:57 PM
- - Box   "What son?" he says.   May 29, 2013 - 8:19 PM
- - RabidTRD   Sick! It's always great to see a Celica li...   May 29, 2013 - 10:42 PM
- - fatherof4   Just a quick update. CAI is installed. Just receiv...   Jul 7, 2013 - 3:21 PM
- - Box   Don't blame the site, I've shown exemplary...   Jul 7, 2013 - 9:34 PM
- - fatherof4   Stuff to add this winter.   Sep 1, 2013 - 12:10 PM
- - fatherof4   Well, It's been almost a year. The car has com...   Feb 16, 2014 - 9:22 PM
- - JoshuaM   NICE!   Feb 16, 2014 - 10:04 PM
- - richee3   Manliest. Wheels. Ever.   Feb 16, 2014 - 10:18 PM
|- - mkernz22   QUOTE (richee3 @ Feb 16, 2014 - 10:1...   Feb 19, 2014 - 2:52 PM
- - njccmd2002   I see whar u did there.   Feb 16, 2014 - 11:17 PM
- - Ted95   The wheels live!! Car's looking good m...   Feb 19, 2014 - 2:59 PM
Lo-Fi Version Time is now: August 25th, 2026 - 4:39 PM
