10 Pages V  < 1 2 3 4 5 > »
> The GT-Four Brake Upgrade, ST205 Brake Upgrade for 5x100 & 5x114 PCB
post Jan 12, 2014 - 9:37 PM
More english prease?!
The rotor sits perfect and does not hit the ball joint. But is off center to the caliper is what i'm gathering.
Does it sit too much towards the inside of the car or does it sit more towards the outside?
and your previous post said it was 326mm diameter...isn't it 26mm too large for the caliper as well?
This post has been edited by playr158: Jan 12, 2014 - 9:38 PM
post Jan 13, 2014 - 1:18 PM
found this on ebay, bought the last set, what are the chances...
http://www.ebay.com/itm/SET-OF-4-ALUMINUM-...04e&vxp=mtr
post Jan 13, 2014 - 1:21 PM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
make sure they dont sit higher than the rotor face!!
エキサイティングカーレーシングチーム!
post Jan 13, 2014 - 1:22 PM
QUOTE (playr158 @ Jan 12, 2014 - 8:37 PM) *
the rotor sits perfect, and the brake surface is excellent.
however i would either have to grind up to 5 mm from the caliper bracket area to even have it centered. i cannot even measure how much that rotor has to be resized, however i will post a pic in a couple of hours.
the rotor sits too much towards the outside, if we could find a caliper for this rotor, it woud be awesome....
post Jan 13, 2014 - 2:31 PM
pics...
but.... to keep caliper centered....
lots of grinding..
even trying to bolt caliper outside.. using a 20 mm spacer..
so just keep it simple, and get the supras, if you are able to find some that can be drilled and someone to do it...
or you want this rotor, you need to find another caliper.
lots of grinding....
that puts the rotor and wheel to far away from the center of rotation, and thats a no no...
post Jan 14, 2014 - 8:58 AM
Honestly, We could easily have an adaptor bracket made for this. (IE small block of aluminum cut and drilled) So that the caliper sits in the correct place and we have a bolt on rotor.
It looks like the caliper mounting holes are sitting right on top of the knuckle holes. This would be a pretty easy adaptor to fab up.
Then I could get these:
post Jan 14, 2014 - 9:21 AM
well actually no, because the caliper is not all the way sitting down and grasping the rotor... it still needs to be pushed down at least 10 mm, and still the holes do not align.
i was looking also at a camry spindle, looks alot like our celicas, with the difference of the mounts spaced further, giving chance of a bracket, but then again, too much trouble when u can just drill supra rotors.
post Jan 16, 2014 - 12:43 PM
Gotcha.
Well like all you other nuts, I picked up a "X" rotor today. We'll see how she fits and i'll report back, it should fit minus a 7mm offset.
Which is an easy $25 spacer and that's it, much easier than drilling.
PS njccmd2002 I saw your thread about brake rotors and the Subaru. I assume this was your research for the STI rotor.
To add information
CELICA GT OEM ROTOR
_____________________
Outer Dia:.....275mm
Height:.........49.3mm
Nom Thick:....28mm
Min Thick:......26mm
Hub Reg:.......55mm
Bolt Size:.......14.5mm
Weight:.........15lb
This post has been edited by playr158: Jan 16, 2014 - 2:11 PM
post Jan 16, 2014 - 12:57 PM
yup sti rotor
post Jan 16, 2014 - 6:04 PM
Rotor:
Part Number: Centric 121.47021
292MM FRONT DISC
*I do believe there is a 295mm disc as well*
(NOTE: This is with worn ST205 OEM pads, and unconnected calipers)
post Jan 16, 2014 - 7:32 PM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
エキサイティングカーレーシングチーム!
post Jan 16, 2014 - 8:14 PM
Subaru rotor? Thats good. Looks like regular impreza. Hmmm that is awesome. Maybe 2 mm shim spacers each side and perfect!!!!!
post Jan 16, 2014 - 8:44 PM
Yup BRZ, Legacy, Impreza wrx and a few others share this rotor.
post Jan 17, 2014 - 11:31 AM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
Info added! Thanks Dan!
I will be adding more info over the next few days as to our new found added options!
This post has been edited by Tigawoods: Jan 17, 2014 - 11:31 AM
エキサイティングカーレーシングチーム!
post Mar 25, 2014 - 8:02 PM
Syaoran
Joined Jan 4, '12
From US
That's a nice find. Two questions:
You removed the dust shield for the rotors right?
How did you compensate for the difference in height?
1993 Celica GT Coupe - sold
1994 Celica GT Liftback
post Mar 25, 2014 - 9:16 PM
I never had dust shields on this setup with the brz rotors.
There is no compensation, put everything on normally.
post Mar 27, 2014 - 12:40 PM
Syaoran
Joined Jan 4, '12
From US
So an update to this thread would be
Front: ST205 calipers bolted on and WRX front rotors bolted on
Rear: ST205 Calipers shimmed 5mm away from the bracket towards thr rotor and ST205 rotors?
Now we need to find an ST205 rotor replacement since I'm guessing they're gonna get hard to find and more expensive as time goes on.
The only thing I dont like about the setup is that the front brake rotors are smaller than the rears, 20mm smaller, too.
post Mar 27, 2014 - 12:45 PM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
QUOTE (Syaoran @ Mar 27, 2014 - 1:40 PM) *
that stuff had been added to the OP already.
St205 rotor replacement for what the rears? If so I have a site from the UK that sells EBC oem replacements. I doubt they will discontinue them for a while.
My personal experience with the larger rear rotors is that the brake bias feels ALOT more even. Braking isnt as nose heavy and the car doesnt dive forward at all during heavy braking, which I find VERY helpful when I race.
エキサイティングカーレーシングチーム!
post Mar 27, 2014 - 1:06 PM
Syaoran
Joined Jan 4, '12
From US
QUOTE (Tigawoods @ Mar 27, 2014 - 1:45 PM) *
That's interesting...
Yeah I was suggesting a replacement for the rears that perhaps we could find local to us.
post Mar 27, 2014 - 1:18 PM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
QUOTE (Syaoran @ Mar 27, 2014 - 2:06 PM) *
Ah gotchya. I think the 205 rears are out best bet.
The only downsides of that rotor are the spacing of the caliper and the ebrake shoe only has half contact on the inner drum.
Those arent really terrible downsides in my eyes.
the company in the UK that I have listed in the OP ships super fast with tracking too smile.gif
I will keep my eyes open for any rotors that look like a match to the 205 rears
This post has been edited by Tigawoods: Mar 27, 2014 - 1:19 PM
エキサイティングカーレーシングチーム!
14 User(s) are reading this topic (14 Guests and 0 Anonymous Users)
Lo-Fi Version Time is now: August 22nd, 2026 - 2:56 AM
