10 Pages V  « < 3 4 5 6 7 > »
> The GT-Four Brake Upgrade, ST205 Brake Upgrade for 5x100 & 5x114 PCB
post Oct 24, 2014 - 1:51 AM
olilaroche
Joined Feb 21, '14
From l'assomption, Québec
The Centric C-TEK Drilled & Slotted Brake Rotors
from 2012 impreza wrx (227.47021R and 227.47021L) seems like a pretty good deal for the front.
from what I've found its 294mm.
What are you using as a 5x100 replacement for st205 front disc besides of impreza?
post Dec 14, 2014 - 7:08 PM
felipeandrest205
Joined Dec 14, '14
From Chile
Im looking on Evo 6 brake discs.
Celica brake discs diameter is 315mm, Evo 6 is 320mm, with proper machine could decrease it to 315mm
Celica brake disc thickness is 32mm max and 30mm min, Evo 6 thickness is 32mm max and 29.8min, so its ok.
Well here comes the problem, hat height of the Celica brake disc is 59mm and the evo 6 is 43,5mm, so a spacer could fix the 11.5mm difference of the height, it should be ok?
Hub bore of the Celica brake disc is 55mm and Evo 6 is 69mm, just need to bored the hun hole to 55, it could be possible?
The best is that 2 front brake discs of evo 6 is just 85,49 on camskill
post Jan 22, 2015 - 3:11 PM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
Thanks to Fate for pointing it out to me, but I made an itsy bitsy large oversight in the swap details, and the step necessary step of shaving off some of the inside of the front caliper like such
Him and I will be looking into the exact thickness it will need to be shaved down to, but it looks like that amount may vary depending on the rotor thickness you will be using.
エキサイティングカーレーシングチーム!
post Jan 22, 2015 - 5:21 PM
about 2mm IIRC.
I would love to find out the exact.
reference
http://www.6gc.net/forums/index.php?showtopic=74140
This post has been edited by Batman722: Jan 22, 2015 - 5:24 PM
post Jan 23, 2015 - 6:56 AM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
QUOTE (Batman722 @ Jan 22, 2015 - 5:21 PM) *
about 2mm IIRC.
reference
I was wondering where that image came from, Fate just handed it to me haha. Im going to add the link to the FP
He was telling me that some have shaved of 5mm+/-
I am going to measure the thickness of mine next week and Fate is going to measure the thickness of the stock bracket so we can get some solid numbers
This post has been edited by Tigawoods: Jan 23, 2015 - 6:59 AM
エキサイティングカーレーシングチーム!
post Mar 16, 2015 - 11:06 PM
felipeandrest205
Joined Dec 14, '14
From Chile
For the rear brake rotors, I was looking at the WRX (G3) up to 2007, there are some difference from the height, but maybe can do something
DBA 2663 WRX
Specifications
Diameter 290
Height 64
Thickness 18
Min Thickness 16
C/Hole 58
Bolt holes 5 X 100 PCD
CELICA
Vent Vented
Diameter 315
Height 59
Thickness 16
Min Thickness 15
Centre Hole Dia 55
Bolt Holes 5
There are just 5mm of difference on the height and a minor difference on the thicknes. Anyone has tested this?
WRX from 2009 and up, rear brake rotors have a 64mm of height vs 59mm of the Celica ones, maybe there could be an option
post Mar 19, 2015 - 2:27 PM
Ok. To add more fuel to drama. I have found rotors very close to spec. For the scion frs. I have been looking on phone so i may have missed some stuff.
http://www.fr-sforum.com/forums/targa-newf...920/topics/8058
Some pics to summariZe
It comes as a kit. Wonder if rotors can be sold
This is where i get lost.
It states 299 mm with 32 mm diameter and 5x100.
Wonder if sold separately and if they are centered for the gt4 caliper
post Mar 19, 2015 - 4:59 PM
Found the disc....
http://counterspacegarage.com/ap-racing-cp...disc-right.html
post Mar 19, 2015 - 6:26 PM
Fate
Joined Nov 30, '04
From Atlantic City
http://counterspacegarage.com/products/bra...gt86-right.html
^Complete assembly
post Mar 19, 2015 - 7:25 PM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
ORLY??
エキサイティングカーレーシングチーム!
post Mar 19, 2015 - 8:54 PM
I l know its pricy investment initially however. More adapt for track...now the question if it fits!!! Lol
post Mar 20, 2015 - 6:22 PM
MGCustoms325
Joined Feb 28, '08
From Miramar, Florida
That's not a bad price. I spent a lot more on my TRD Front BBK. Wish this would've been around before I bought my set.
post Mar 21, 2015 - 7:42 PM
mi645
Joined May 23, '12
From northridge,CA
so? front gt4 calipers with those counterspace garage rotors and tapping thread on the factory hub and all bolt on?
post Mar 21, 2015 - 8:50 PM
No,no, no. We dont know the offset specs of those rotors.
The hat looks too tall
post Mar 23, 2015 - 1:43 PM
Culpable04
Joined Apr 17, '06
From New Jersey
I printed the image and while I could not get it to print at scale, I got it very close to, given that is not 100% scale ( yet ) I cant say it with certainty, but it does seem to fit,
but if my calculations were right back then, you should not consider any disc with a height of 55mm or higher, while it will clear everything up to 59 mm height ( I think ) and driving straight; under stress when cornering and high speed suspension flexing, the ball joints will come in contact with the disc. ( of course this will change from setup to set up, ride height suspension mods etc, but when I experienced the issue ( ball joints hitting disc ) I did some more calculations and came up with a safe and very conservative disc height to fix the issue. that's when I upgraded to the Supra NA disc.
This post has been edited by Culpable04: Mar 23, 2015 - 1:44 PM
post Mar 24, 2015 - 9:09 PM
i have been looking at wilwood hats, and they dont measure in mm, they use hat offset.
the bolt pattern is 5x3.93 thats the closest to 5x100
hat offset i beleive is close would be 0.5 or less, the problem is that there are 2 different ones, with the rotor bolt circle of 8*7.0, and i dont know what the bolt pattern in this rotor is, or would it be compatible with wildwood hats..
looks like there are 8 bolts, but unsure...
http://www.wilwood.com/Hats/HatList.aspx
just search at 5x3.93
post Apr 20, 2015 - 6:18 PM
olilaroche
Joined Feb 21, '14
Does anyone have the part number for the rear st205 caliper bolts? Or the specs of the bolts so I can buy the right sized bolt?
post Apr 22, 2015 - 7:34 AM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
QUOTE (olilaroche @ Apr 20, 2015 - 7:18 PM) *
I cant tell off the top of my head. They should be the same thread pitch as the stock bolts but a few MM longer
エキサイティングカーレーシングチーム!
post Apr 22, 2015 - 8:07 AM
olilaroche
Joined Feb 21, '14
Would the supra turbo bolts would be the same? Since its basically the same caliper...
post Apr 26, 2015 - 11:21 AM
lots of cool info in here guys good work on all parts!
i know daniel added it to the sticky post, but since this is one of the most popular upgrades for the 6gc guys in general, i think it needs to be available right at the top of the forum, with less clicks..lol
29 User(s) are reading this topic (29 Guests and 0 Anonymous Users)
Lo-Fi Version Time is now: June 23rd, 2026 - 10:41 AM
