Nov 7, 2013 - 4:06 PM
Enthusiast ![]() Joined Oct 10, '13 From Ontario, Canada Currently Offline Reputation: 0 (0%) |
I really need your knowledge guys! I found that the reason my oil filter is dry is because my car is leaking a huge amount of oil right where the oil filter goes. Does anyone know how I can stop this and what I would need to do and change?
Thanks for your time |
danmumo Oil filter leak Nov 7, 2013 - 4:06 PM
Box Silly easy questions first, is it the right filter... Nov 7, 2013 - 4:16 PM
danmumo QUOTE (Box @ Nov 7, 2013 - 5:16 PM) ... Nov 7, 2013 - 4:37 PM
Box QUOTE (danmumo @ Nov 7, 2013 - 3:37 ... Nov 7, 2013 - 5:19 PM
richee3 Did you make sure the old oil filter gasket stayed... Nov 7, 2013 - 5:02 PM
danmumo I will check tomorrow afternoon when I get home fr... Nov 7, 2013 - 7:09 PM
Box Other places to check would be oil pan seal and va... Nov 7, 2013 - 7:15 PM
danmumo QUOTE (richee3 @ Nov 7, 2013 - 6:02 ... Nov 7, 2013 - 8:38 PM
Box I've never heard of them, I'd stick to OEM... Nov 7, 2013 - 9:42 PM
danmumo QUOTE (Box @ Nov 7, 2013 - 9:42 PM) ... Nov 8, 2013 - 12:31 AM
Box Idle issue is most likely due to a dirty IACV. Ca... Nov 8, 2013 - 12:58 AM
richee3 Cometic makes good gaskets. Nov 8, 2013 - 3:25 AM
RabidTRD GT or ST? If it's the GT, it could be the oil ... Nov 8, 2013 - 11:09 AM
danmumo QUOTE (RabidTRD @ Nov 8, 2013 - 12:0... Nov 8, 2013 - 12:55 PM
RabidTRD Check around the base if the oil cooler that sits ... Nov 8, 2013 - 3:47 PM![]() ![]() |
| Lo-Fi Version | Time is now: September 12th, 2026 - 12:41 PM |
