Dec 10, 2013 - 12:06 AM
Ok this is how I did it, some steps can be done in different orders. This is for information only and I am not responsible for any oops on your part.
Lets get started Here is your engine bay, First remove the hood. Unplug the water line for the squirters and remove the (2) 12mm bolts on each side of the hood. ![]() ![]() ![]() ![]() Jack the front of the car up and drain the oil. ![]() Remove the battery ![]() ![]() ![]() Remove the (3) 10mm bolts holding the cruise control actuator. ![]() remove the plastic cover ![]() Using 14mm wrenches, loosen the nuts securing the throttle cable ![]() ![]() Unplug the cruise actuator ![]() Now with the actuator in your hands, rotate the cable to remove it from the actuator ![]() Unplug the radiator fans ![]() Under the radiator, unscrew the plastic drain cock and let coolant pour out into a bucket Unplug the Radiator temp sensor ![]() Remove the radiator hoses ![]() ![]() ![]() ![]() remove the (2) radiator clamps, each held in with a 12mm bolt ![]() Unplug the other fan plug ![]() Lift out the radiator ![]() ![]() drain the transmission fluid, remove this bolt, its a 24mm ![]() While that's draining, remove the stock airbox, first remove the snap clamps and the spiral clamp around the intake hose. ![]() there are (3) 10mm bolts holding the airbox in. 2 are inside the box and the last one is outside by the fuel filter. ![]() ![]() ![]() Remove this grounding cable, there are (2) 10mm bolts here and a single 12mm bolt on the transmission right next to the reverse switch ![]() ![]() remove the fuse box cover ![]() Push in the tabs to lift up the junction box (what i call it) ![]() ![]() Unplug the harness from both sides. the white plug is a typical plug, push in the tab and lift. the large connector you have to push in the tab and rotate the lock down. ![]() ![]() ![]() Unplug the igniter and resistor box ![]() remove the diagnostic box ![]() ![]() This is the EVAP purge VSV, I believe this is only on 99 Celicas. unplug it if you have it, follow the hose up to the intake manifold and unplug that too. ![]() Loosen the other spiral clamp on the hose at the throttle body. its a 10mm head with a phillips screwdriver so either will work ![]() ![]() This is the return fuel line, remove that and remove the fuel feed line at the filter. Its the 17mm Banjo bolt on the filter right next to the EVAP VSV ![]() This is the MAP sensor, unplug it ![]() This is the harness going through the firewall to the ECU. its held in by (2) 10mm nuts. ![]() This line feeds the brake booster you can remove it from either side or both and just get it out of the way ![]() This is a vapor filter for the MAP sensor. be careful removing the hose. you don't want to break off the nipple ![]() Remove the passenger side foot trim. this will make it easier to pull the harness through and easier to get to the AC plug ![]() ![]() ![]() This is the AC plug, don't forget to unplug it. ![]() I forgot to mention these, remove the small clip to free the shifter cables, then use large pliers to get out the C clips that hold the cables in place. ![]() ![]() Back to the ECU, unplug the ECU, Circuit Opening Relay, and the body harness. ![]() ![]() Carefully lift out the harness ![]() Ok lets get the alternator out of the way. First loosen the pivot bolt. ![]() Remove the sideways bolt, that clamps the alternator in place, then take out the long tightening bolt. ![]() remove the electrical connections ![]() ![]() ![]() Alternator removed, Now lets get the AC compressor out of the way. First unplug it ![]() ![]() There are (3) long 12mm bolts holding the compressor to the block. remove those and let the compressor down out of the way. ![]() ![]() ![]() ![]() Not too much is left, by now the transmission should be drained, if you haven't done so already, put the drain plug back in. Now take off the wheels. ![]() ![]() ![]() Remove the cotter pin and nut cover. ![]() ![]() Stick a screwdriver in the rotor and brake caliper. this will hold it in place while removing the 30mm axle nut ![]() ![]() Remove the ABS sensor if you have one, unclip the harness and get it out of the way ![]() ![]() Remove the brake caliper. there are (2) 14mm bolts on the backside. once those are out remove the brake pads. ![]() Smack the axle with a dead blow hammer. this will knock it out of the hub ![]() Remove the (2) 19mm bolts from the hub to strut. pull the hub away and the axle will be free ![]() With a friend holding the axle straight and rotating it, use a pry bar on the CV housing at the transmission and pop out the axle. It will come, you just need to find the sweet spot. ![]() ![]() ![]() The passenger side is easier, remove the (2) 14mm bolts from the axle bearing carrier and the axle will slide right out ![]() Spray some penetrating oil on the exhaust bolts. let that sit for a while and then remove the 3 bunts holding the downpipe to the header. ![]() Remove the locking bolt on the power steering pump. ![]() I should have circled it, loosen the pivot bolt on top of the power steering bolt, if you can get it out here, that's awesome, I had to jack the engine up to get clearance. ![]() Here is another pic of the fuel return line unplugged and the feed line. if you haven't done so, remove them now. ![]() ![]() Remove the 2 water lines for the heater. ![]() ![]() Its hard to see here, but looking in through the drivers side wheel area, this is the rear engine mount bolt. its in the shadows. If its hard to get out, come back to it after removing the front mount. rock the engine and you should be able to pull it out. ![]() Remove the Front engine mount, its a 17mm bolt through the mount. then remove the (2) 14mm bolts on the bottom. lift out the mount. then remove the bracket from the transmission. ![]() Now get your hoist ready and hook up. ![]() Remove the starter, first the 12mm nut for the hot feed, then the ground plug. there are (2) 14mm bolts on each side holding it on the transmission. ![]() Unplug the reverse switch to get it out of the way. ![]() Now free the slave cylinder. remove the 10mm bolt securing the hard line, the (2) 12mm bolts on the slave and the 10mm bolt in front of the transmission ![]() ![]() ![]() Remove the drivers side engine mount. its a 14mm long bolt and (2) 14mm nuts and a short bolt. then remove the bracket from the transmission. Those are 14mm also ![]() ![]() ![]() Remove the passenger side engine mount. ![]() ![]() ![]() ![]() ![]() Start to lift the engine, here you can see the power steering bolt that gave me trouble. now you can pull it out and set the power steering pump aside ![]() And out it comes ![]() ![]() ![]() And finally the MONEY SHOT
This post has been edited by Smaay: Feb 27, 2014 - 6:07 PM -------------------- 2001 Celica GT-S Turbo
Smaay How to remove engine from car (5S-FE) Dec 10, 2013 - 12:06 AM
Smaay Here is a preview of whats to come Dec 10, 2013 - 12:15 AM
richee3 Great writeup! I'm surprised in all the ye... Dec 10, 2013 - 12:18 AM
H8TRAIN Killer documentation. Thanks for taking the time, ... Dec 10, 2013 - 12:18 AM
celicakitten Money shot...ummm yeah sure, that works too
QUOT... Dec 10, 2013 - 12:32 AM
njccmd2002 yup, great documentation. Everything was covered.... Dec 10, 2013 - 12:39 AM
mi645 I am impressed thanks for covering the part I forg... Dec 10, 2013 - 1:17 AM
Syaoran Great write up.
That turbo manifold.... I am inte... Dec 10, 2013 - 10:08 PM
Smaay QUOTE (Syaoran @ Dec 10, 2013 - 7:08... Dec 22, 2013 - 5:39 PM
cardshark525 Fantastic write up. It's EXTREMELY helpful whe... Dec 10, 2013 - 11:19 PM
ILoveMySilly97 QUOTE (cardshark525 @ Dec 10, 2013 - 8... Dec 11, 2013 - 5:34 AM
PegGTS QUOTE (Smaay @ Dec 9, 2013 - 11:06 P... Dec 10, 2013 - 11:42 PM
Smaay QUOTE (PegGTS @ Dec 10, 2013 - 8:42 ... Dec 11, 2013 - 12:20 AM
PegGTS QUOTE (Smaay @ Dec 10, 2013 - 11:20 ... Dec 11, 2013 - 12:55 AM
celicakitten QUOTE (Smaay @ Dec 11, 2013 - 12:20 ... Dec 11, 2013 - 3:47 AM
Box I couldn't help but expect two more cylinders ... Dec 11, 2013 - 1:08 AM
Tigawoods sweet write up!!! Dec 11, 2013 - 7:29 AM
enderswift Well done dude Dec 11, 2013 - 10:48 AM
VavAlephVav You had me at Money Shot. Dec 18, 2013 - 12:52 AM
Syaoran Oh so that's one of the prototype kits. Nice.
... Dec 25, 2013 - 8:23 AM
Smaay they take about 6 hours to make, i think i can sel... Dec 26, 2013 - 2:38 AM
Icewata I am look at turboing my 5s. I see that you live i... Jan 2, 2014 - 6:27 PM
Smaay there is no such creature as a CARB turbo kit for ... Jan 4, 2014 - 12:26 AM
Icewata I see, thank you for the quick response.
On ano... Jan 4, 2014 - 1:36 AM
azn87 did u use a oil filter relocation kit? Jan 4, 2014 - 2:01 AM
Smaay QUOTE (Icewata @ Jan 3, 2014 - 10:36... Jan 4, 2014 - 10:08 PM
PegGTS First of all, this thread is super helpful! I... Aug 13, 2015 - 12:05 PM
Smaay QUOTE (PegGTS @ Aug 13, 2015 - 10:05... Aug 16, 2015 - 10:17 PM
richee3 You can actually remove that horseshoe clip and le... Aug 16, 2015 - 9:28 PM
PegGTS Ah alright so it's a 14mm then. I read 10mm an... Aug 16, 2015 - 11:43 PM
doory100 Is it necessary to drain the tranny oil? will it s... Nov 16, 2015 - 8:23 PM
richee3 Yeah, it'll drain out of the axle holes. Nov 16, 2015 - 8:50 PM
doory100 How do you get the shifter cables off? Never mind ... Nov 18, 2015 - 1:43 PM![]() ![]() |
| Lo-Fi Version | Time is now: September 6th, 2026 - 5:44 PM |
