> Seventh Gen Corolla, Transmission
post Jan 2, 2014 - 11:06 PM
DeviantCorndog
Joined Dec 6, '12
From Newnan, Ga
Just looking and could not find a lot of information, but is the 1.8 corolla manual transmission the same as the manual tranny in the celica 1.8?
post Jan 3, 2014 - 9:32 PM
Bitter
Joined Mar 11, '06
From Way South Chicago
I don't think they're identical but they should interchange. I believe slightly different ratio's. Look up the Wikipedia article about Toyota Transmissions and see the list of applications to find the trans model and check the ratios to confirm.
post Jan 3, 2014 - 10:58 PM
DeviantCorndog
Joined Dec 6, '12
From Newnan, Ga
Celica has the A246E while the corolla has the A245E still not much info on if they are interchangeable..will keep looking though.
post Jan 3, 2014 - 11:52 PM
Bitter
Joined Mar 11, '06
Those are automatic transmissions, you're asking about manuals...
post Jan 5, 2014 - 10:29 PM
RavenAegis45
Joined Jun 25, '08
From CA
Off the top of my head I believe as long as there both 1.8L engines (7A-FE) then they should both have the C56 transmission, But I could be wrong
post Jan 6, 2014 - 1:28 AM
7A-FE manual transmission is C52. Wouldn't 'Rolla use the same box as 7th gen Celica, C60 (or maybe C160)?
This post has been edited by SwissFerdi: Jan 6, 2014 - 1:29 AM
'90 MX-5 Mariner Blue
'15 Optima Grey
'04 206 GTi silve
post Jan 6, 2014 - 10:00 AM
Bitter
Joined Mar 11, '06
C60 is a 6 speed isn't? 6spd with a 7afe would be interesting though.
post Jan 7, 2014 - 3:33 PM
It bolts up, supposedly, just never documented as far as I know. I wouldn't mind a sixth gear at all, although I imagine the ratios are a bit off because the 7A really has to rev to go anywhere at all remotely in a hurry.
'15 Optima Grey
'04 206 GTi silve
post Jan 7, 2014 - 7:00 PM
delusionz
Joined Feb 11, '08
From Auckland, New Zealand
c60 is the 6 speed box for a 2zz, i think the c160 the 6speed box for the bz-r levin/trueno 4age blacktop
Mike W
269awhp / 273ft-lbs
post Jan 7, 2014 - 7:08 PM
delusionz
Joined Feb 11, '08
the blacktop 6 speed box revs really high to make the most of the 1.6 with 8200 limiter
that box in a celica with your 6800 usdm redline is going to cruise abnormally high revs and have a stupid low top speed in each gear you would definitely need to put some big wheels on or some ****
in the original car 4th gear cruising at 34mph it would rev around 3500
wonder if theres any reason why you cant drop a 2zz into a USDM ST and repin the fusebox plug with the entire 7th gen harness
Mike W
269awhp / 273ft-lbs
post Jan 7, 2014 - 10:11 PM
DeviantCorndog
Joined Dec 6, '12
From Newnan, Ga
Thanks for all the information guys i appreciate it. Still gathering information let you guys know when I find out more. Again thanks
Lo-Fi Version Time is now: July 31st, 2026 - 9:26 AM
