Jan 31, 2004 - 2:39 AM
Enthusiast ![]() ![]() ![]() Joined Sep 6, '03 From hudson ,iowa Currently Offline Reputation: 1 (100%) |
what woudl be the best turbo in your guy's opinion for the 5sfe
Feb 1, 2004 - 1:24 AM
cant say, depends on your power goals and how much, if any, internal work you plan to do.
low boost/power ct26 mid range t3 higher range t3/t4 hybrid stock internals wont handle enough to get into the peak efficiency of a t3. This post has been edited by 97sccelica: Feb 1, 2004 - 1:25 AM -------------------- 1994 Celica GT4 WRC Edition
@gt4.wrc on Instagram |
Feb 2, 2004 - 1:04 AM
in the future when i turbo i plan on port and polish , lower compression forged pistons and stronger rods
Feb 3, 2004 - 12:25 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 26, '02 From Alabama Currently Offline Reputation: 2 (100%) |
anything ball-bearing.
Feb 3, 2004 - 6:01 PM
Enthusiast ![]() ![]() ![]() Joined May 17, '03 From Florence, KY Currently Offline Reputation: 0 (0%) |
Garrett T25 ball-bearing turbo. Up to 225 hp. Plenty good for a 5sfe.
Feb 4, 2004 - 7:35 AM
![]() Enthusiast ![]() ![]() Joined Jan 8, '03 From Miami, FL Currently Offline Reputation: 0 (0%) |
what about Garrett GT28 for the 3sgte??? fensport makes a kit using that turbo... is it anygood... how would 22psi from that turbo compare to the ct20b. how does it compare to the T3 in spool time and max psi...
Mina This post has been edited by XXX_Mina: Feb 4, 2004 - 7:36 AM |
Feb 4, 2004 - 9:58 AM
Is the GT-28 the
"Disco Potato?" lol |
Feb 5, 2004 - 6:47 PM
I don't get it... Definitely get ball-bearing. It's supposed to spool faster and be more reliable. Doesn't it also eliminate the need for oil return lines? Correct me if I'm wrong on that. I may be repeating wrong info. |
Feb 5, 2004 - 7:48 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jan 9, '03 From St. Louis Currently Offline Reputation: 0 (0%) |
I think the disco potato was the 240 in scc, but, I could be wrong, but I think it was a car in scc
I cant remember why they called it the disco potato -------------------- [img]http://photos-081.facebook.com/n6/081/n15913038_30266081_3342.jpg[/img]
Feb 7, 2004 - 2:46 AM
yea, the car was nasty and brown, so the guy called it his 'disco potato'.
Anyway, they put the new turbo on and it made MAD gains, so they called the turbo 'the disco potato' Or something,and yes, I think the ball bearing turbos are self-contained to some point. |
| Lo-Fi Version | Time is now: May 19th, 2026 - 11:01 AM |
