> Harness info
post Mar 11, 2014 - 11:08 AM
Smaay
Joined Dec 8, '03
From Lancaster CA
I searched and couldn't find a thread that had detailed pictures and description of the 2 big plugs in the fuse box and where those wires go.
I know its been talked about several times in swap threads but i couldn't find anything. It might be because i cant see most hosted images from work.
So lets make a sticky that shows the connectors, and description of color of wires and where they go. This will really benefit the V6 swappers. The V6 harness' do not have several wires that the celica harness does.
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
- Smaay   Harness info   Mar 11, 2014 - 11:08 AM
- - richee3   You are welcome to use any of my pictures of the E...   Mar 11, 2014 - 12:51 PM
- - Smaay   That would be awesome, where are they? If you have...   Mar 11, 2014 - 2:32 PM
- - richee3   They are hosted on Photobucket but I'll get on...   Mar 11, 2014 - 4:34 PM
- - Smaay   yeah and which wire goes where. ill snap pics of w...   Mar 11, 2014 - 6:40 PM
- - Smaay   ok here is what i have so far. this is the EA1 pl...   Mar 11, 2014 - 7:51 PM
|- - MaskedMan   QUOTE (Smaay @ Mar 11, 2014 - 5:51 P...   Mar 12, 2014 - 4:05 AM
- - Smaay   Thanks for the info, Ok you confused me, the black...   Mar 12, 2014 - 8:58 AM
- - richee3   Here you go. Pretty much the same as your V6/5S pl...   Mar 13, 2014 - 11:08 AM
- - Smaay   ok the plug in my hand is the magnetic clutch for ...   Mar 18, 2014 - 1:18 AM
- - Smaay   Update here is the old harness that MR220V did f...   Mar 23, 2014 - 11:52 PM
- - njccmd2002   Hopefully came to right place. Questions and mor...   Nov 21, 2014 - 12:33 AM
- - Smaay   ELS is just an input to the ECU. it detects when a...   Nov 21, 2014 - 10:14 AM
- - njccmd2002   ok, so that IG signal you talk about, that is not ...   Nov 21, 2014 - 11:25 AM
- - njccmd2002   You are right, thanks man. The beams throws the t...   Nov 21, 2014 - 11:40 AM
- - Smaay   CF is a ground provided by the ECU to charge the r...   Nov 21, 2014 - 3:24 PM
- - njccmd2002   if i recall the wiring diagram, On the GT the wate...   Nov 22, 2014 - 6:49 AM
- - Smaay   yes i think thse are the same on the GT. the ST ha...   Nov 24, 2014 - 12:35 AM
- - doory100   just a few questions about the above tread: -Are...   Oct 24, 2015 - 7:43 AM
|- - njccmd2002   QUOTE (doory100 @ Oct 24, 2015 - 7:4...   Oct 26, 2015 - 10:27 AM
- - Smaay   what is your email and ill send you the wiring dia...   Oct 26, 2015 - 9:40 AM
- - doory100   Sorry it's a 1999 Solara 1mzfe going into a 19...   Oct 26, 2015 - 1:53 PM
- - richee3   No, just the engine harness.   Oct 26, 2015 - 2:19 PM
- - doory100   Yes but those wires come out into the engine bay t...   Oct 26, 2015 - 2:32 PM
- - richee3   Yeah, you're making the engine harness match t...   Oct 26, 2015 - 2:38 PM
- - 1mzfecrazy   How is it going everyone I had to build a new acco...   Sep 8, 2018 - 10:32 PM
Lo-Fi Version Time is now: June 11th, 2026 - 12:40 PM
