> What Exactly is Limp Mode?, Can anyone explain this?
post Mar 21, 2014 - 10:34 PM
Lil-Joe101
Joined Dec 7, '07
From Corpus Christi, TX
So I'm wandering if my car is in limp mode. Why? Well the check engine light is on and she idles fine for a minute or two, then completely drops fuel pressure and dies. If this is not limp mode then what is causing this? I just replaced all for injectors, believing that this was the original cause for it not running right i.e. rough idle, fluctuating fuel pressure before it completely drops and dies. I've also done the general maintenance as well like change oil, flush and change both radiator and heat exchanger, replace h spark plugs and also the battery. I have replaced the fuel pump, filter, and now injectors. She idles fine now, like a dream then given a minute or two drops pressure and dies. Also she's running really rich, so much in fact, you can smell the extra fuel that's being dumped to compensate. Can anyone tell me what's going on, or what it is I'm doing wrong here, cause I'm lost, frustrated beyond belief, and almost fed up with the whole thing.
- Lil-Joe101   What Exactly is Limp Mode?   Mar 21, 2014 - 10:34 PM
- - cardshark525   Limp mode or "safe mode" is when the car...   Mar 21, 2014 - 10:45 PM
- - Lil-Joe101   cardshark like you said it might be electrical. I ...   Mar 22, 2014 - 10:08 AM
- - mgnt232   Check your engine light code. There is a reason To...   Mar 22, 2014 - 10:33 AM
- - SupraKid   A lot of the time a car will go into limp mode due...   Mar 22, 2014 - 10:39 AM
- - cardshark525   What code is your check engine light on for? That ...   Mar 22, 2014 - 11:23 AM
- - playr158   Limp mode doesn't always limit rpm....depends ...   Mar 22, 2014 - 12:50 PM
|- - mgnt232   QUOTE (playr158 @ Mar 22, 2014 - 12...   Mar 23, 2014 - 7:55 AM
- - Lil-Joe101   I haven't checked the codes yet. I only ran it...   Mar 22, 2014 - 12:55 PM
- - mkernz22   Did you replace the FPR?   Mar 22, 2014 - 1:49 PM
- - Lil-Joe101   Yes, pump, fpr, filter, and injectors are all bran...   Mar 22, 2014 - 1:51 PM
- - playr158   What gen 3sgte did you swap in? And currently my ...   Mar 22, 2014 - 2:41 PM
- - Lil-Joe101   3rd gen, and that sounds like a better plan lol.   Mar 22, 2014 - 3:19 PM
- - Lil-Joe101   I think it's code 54. 5 flashes pause 4 flashe...   Mar 22, 2014 - 8:32 PM
- - jordisonjr   A quick google search of a Toyota CEL's shows ...   Mar 22, 2014 - 9:05 PM
- - Lil-Joe101   So I ran my CEL results through this site http://w...   Mar 22, 2014 - 10:19 PM
- - JasonTX   my mr2 had a similar issue when i had a bad o2. i ...   Mar 22, 2014 - 10:40 PM
- - Lil-Joe101   I never would have imagined that an o2 sensor or a...   Mar 23, 2014 - 6:52 AM
|- - playr158   QUOTE (Lil-Joe101 @ Mar 23, 2014 - ...   Mar 23, 2014 - 8:03 AM
|- - playr158   QUOTE (Lil-Joe101 @ Mar 23, 2014 - ...   Mar 23, 2014 - 8:15 AM
- - Lil-Joe101   Temp gauge is fine, not rising or standing, it rea...   Mar 23, 2014 - 9:20 AM
Lo-Fi Version Time is now: August 22nd, 2026 - 9:32 PM
