Apr 16, 2014 - 6:34 PM
Enthusiast ![]() Joined Nov 15, '10 From ABERDEEN WA Currently Offline Reputation: 3 (100%) |
well i've started what most people dont have time for. I'm in the middle of building my 5sgte and Rwd conversion,
I have a couple pictures to start with. If you have any question, just ask. ![]() ![]() I'm using a 88 toyota truck rear end 2wd. This rear end is harder to find, because it uses the 8 inch center section. And that comes with 30 spline axles. I'm not using the third member. I went with a toyota v-6 4x4 3rd member, that will allow you to buy a supra lsd that will bolt into the v-6 housing. I'm going to be using the stock v-6 gears that comes with 4.10 gears, It may be a little high, but i'll run those for a little bit. Also when i have the lsd out, i'm install a WEIR MAXGRIP LSD Kits It increases the locking force of the clutches. So i'll be posting pictures as i go. This post has been edited by toy8490: Apr 16, 2014 - 6:43 PM |
toy8490 5sgte rwd conversion Apr 16, 2014 - 6:34 PM
toy8490 Fitting the engine and transmission, Dont worry, t... Apr 16, 2014 - 7:18 PM
toy8490 I'll be using a 1990 ford mustang rack and pin... Apr 16, 2014 - 7:25 PM
Fate looking forward to this build, awesome work thus f... Apr 16, 2014 - 8:03 PM
JoshuaM Wow, that's awesome!!! Apr 16, 2014 - 8:36 PM
smkr3w Should be awesome. Definitely going to watch this... Apr 16, 2014 - 8:57 PM
cardshark525 At least she'll have a low center of gravity ... Apr 16, 2014 - 9:05 PM
playr158 if you're using the 5sfe block, what transmiss... Apr 16, 2014 - 9:18 PM
cheela subscribed! Apr 16, 2014 - 9:28 PM
toy8490 QUOTE (cheela @ Apr 16, 2014 - 10:28... Apr 16, 2014 - 10:59 PM
Smaay i believe that is an R154 transmission or is it t... Apr 16, 2014 - 11:04 PM
Box R154 was in the Supra Turbo, W58 was in the non tu... Apr 17, 2014 - 1:19 AM
ILoveMySilly97 Nice. A 5sgte that's something uncommon and es... Apr 17, 2014 - 2:12 AM
playr158 W58 requires a 2s bell housing to mount to the 5s/... Apr 17, 2014 - 8:12 AM
njccmd2002 this is finally happening. RWD conversion... YA... Apr 17, 2014 - 9:04 AM
toy8490 The transmission is very close to a r154. The tran... Apr 17, 2014 - 9:40 AM
94GreenLantern NICE! pictures of rear from underneath? Apr 17, 2014 - 9:47 AM
mkernz22 Now this is something I might have to do in the fa... Apr 17, 2014 - 12:03 PM
toy8490 Heres a picture of the suspension, Not very bright... Apr 17, 2014 - 1:29 PM
sandusky1977 If you're going through all that effort, why s... Apr 17, 2014 - 2:08 PM
toy8490 This 4 cylinder that i'm building will be ligh... Apr 17, 2014 - 2:14 PM
richee3 Very cool stuff. Will this be a DD, track car, dr... Apr 17, 2014 - 2:16 PM
Box QUOTE (richee3 @ Apr 17, 2014 - 2:16... Apr 17, 2014 - 2:26 PM
toy8490 QUOTE (richee3 @ Apr 17, 2014 - 3:16... Apr 17, 2014 - 3:59 PM
toy8490 Heres some more pictures, with the engine all clea... Apr 18, 2014 - 1:54 PM
CrossCudi AWESOME ! Apr 18, 2014 - 2:05 PM
Box I wonder how such a severe tilt will effect things... Apr 18, 2014 - 3:31 PM
SupraKid *Thinks dirty, dirty 2jzgte thoughts* Apr 18, 2014 - 5:01 PM
toy8490 Heres some pictures of the rear suspension
The su... Apr 19, 2014 - 10:05 AM
toy8490 Now heres some pictures of the steering and engine... Apr 19, 2014 - 10:17 AM
team_omega Its looking good. You want to do mines after your... Apr 19, 2014 - 10:48 AM
toy8490 QUOTE (team_omega @ Apr 19, 2014 - 11... Apr 19, 2014 - 3:54 PM
kormysh8 I can't wait to see the final product. I'v... Apr 19, 2014 - 10:19 PM
PR0PH37 Wow. I don't know what the heck I'm lookin... Apr 19, 2014 - 11:19 PM
njccmd2002 one questions, those tie rods will be under pressu... Apr 20, 2014 - 7:57 AM
toy8490 [quote name='njccmd2002' date='Apr 20,... Apr 20, 2014 - 10:50 AM
toyota123 I have to say I'm very intrigued by what you a... Apr 20, 2014 - 10:09 AM
LimitedGT4 Sweet.
I was planning on doing somethin like thi... Apr 25, 2014 - 8:49 PM
toy8490 Getting closer. Got the struts mounted, so that it... May 5, 2014 - 3:13 PM
toy8490 I dont know if this is the same pictures as from b... May 5, 2014 - 3:20 PM
Smaay the R154 must have been in the MKIII because the M... May 5, 2014 - 3:49 PM
mgnt232 QUOTE (Smaay @ May 5, 2014 - 4:49 PM... May 5, 2014 - 4:26 PM
toy8490 QUOTE (Smaay @ May 5, 2014 - 4:49 PM... May 5, 2014 - 9:29 PM
Smaay no i dont read everything, i dont need to read 3 w... May 5, 2014 - 9:59 PM
cardshark525 Franken-build progressing nicely.
A rwd 6gc runni... May 5, 2014 - 10:32 PM
toy8490 i'll be uploading more updates tomorrow of my ... May 11, 2014 - 10:38 PM
toy8490 Well was almost done, had the complet dash inside ... May 12, 2014 - 12:34 PM
Special_Edy Im far from being an expert, and Im having difficu... May 12, 2014 - 2:09 PM
toy8490 Here some more progress pictures, motor mounts / t... May 15, 2014 - 10:00 AM
njccmd2002 wow this is significant progress. May 15, 2014 - 11:52 AM
Malek Seriously! ^^
This is some good stuff! May 15, 2014 - 1:54 PM
ClevelandGaint I want this May 15, 2014 - 3:47 PM
playr158 its crazy.....its impractical.....its freaking awe... May 15, 2014 - 9:29 PM
jeffrosie Awesome build M8.
Was just thinking, why not use t... May 16, 2014 - 6:04 PM
Special_Edy Naw he should use the straight axle. Maybe get a s... May 16, 2014 - 7:13 PM
lagos Impressive project! May 17, 2014 - 9:46 AM
toy8490 I hope you guys are ready for this, I'm gettin... May 31, 2014 - 11:31 PM
toy8490 Picture time, I love it.
I'm going ... May 31, 2014 - 11:38 PM
Box It's so weird seeing the engine longitudinally... May 31, 2014 - 11:50 PM
BonzaiCelica wow at that point why not fit the intake manifold ... Jun 1, 2014 - 3:25 PM
playr158 So much awesome. Jun 1, 2014 - 7:39 PM
Batman722 IC piping is gonna be funky. I see a lot of lag co... Jun 1, 2014 - 8:20 PM
LimitedGT4 QUOTE (Batman722 @ Jun 1, 2014 - 8:2... Jun 1, 2014 - 8:26 PM
toy8490 I already have the front mount Intercooler from my... Jun 2, 2014 - 6:20 PM
toy8490 got the intake modified, it fit perfect. Jun 23, 2014 - 12:45 AM
njccmd2002 dang... thats a nasty beautiful intake..... glad ... Jun 23, 2014 - 11:48 AM
Malek truth ^^
This thing is sweet Jun 23, 2014 - 4:23 PM
ricochet1490 nicely done. I appreciate the fabrication here. Jul 6, 2014 - 8:11 PM
dudeofchaos Woww. I wanted to do this for years with my st204 ... Jul 14, 2014 - 5:02 PM
BonzaiCelica update? so rare! Jul 28, 2014 - 2:05 PM
HaysoosKreesto wow, it's like you took every st204's fant... Jul 28, 2014 - 5:17 PM
toy8490 I just now got the car running today, Just have to... Aug 20, 2014 - 2:16 PM
Box I can't believe you think this is taking awhil... Aug 20, 2014 - 3:40 PM
IllIllIll When I first saw the thread I assumed that this wo... Aug 30, 2014 - 9:39 AM
toy8490 QUOTE (IllIllIll @ Aug 30, 2014 - 9... Oct 12, 2014 - 1:57 PM
mkernz22 RE: 5sgte rwd conversion Oct 12, 2014 - 2:11 PM
toy8490 I hope this works
http://vid266.photobucket.com/a... Oct 12, 2014 - 9:50 PM
toy8490 QUOTE (toy8490 @ Oct 12, 2014 - 9:50... Oct 17, 2014 - 9:54 AM
Syaoran oh boy Oct 12, 2014 - 9:52 PM
mkernz22 That a$$ end is way high! Oct 12, 2014 - 11:13 PM
HaysoosKreesto That sound makes my face look like that Kim Kardas... Oct 12, 2014 - 11:22 PM
enderswift holy crap you finished O.O
good work! Oct 13, 2014 - 12:06 AM
kurt95gt This is crazy!
Love it! Oct 14, 2014 - 12:44 PM
SwissFerdi Nice! Good on you, man. You've done what 9... Oct 15, 2014 - 10:11 AM
njccmd2002 And people, lot of people, i mean lots of people. ... Oct 16, 2014 - 5:54 PM
Box QUOTE (njccmd2002 @ Oct 16, 2014 - 5... Oct 16, 2014 - 6:38 PM
Arturio55 This makes the awd conversion look as simple as dr... Oct 16, 2014 - 6:51 PM
HaysoosKreesto Worked for me Oct 17, 2014 - 9:59 AM
Smaay impressive work....
how are you going to do the i... Oct 26, 2014 - 8:09 PM
toy8490 I'm planning on doing my own header and new tu... Oct 27, 2014 - 3:53 PM
toy8490 Looking to buy a gt35 twin scroll turbo, I'll ... Apr 2, 2015 - 9:56 AM
toy8490 New turbo has made it here. Time for some work now... Apr 21, 2015 - 9:36 AM
toy8490 I removed the factory turbo, (which is for sale) ... Apr 25, 2015 - 1:20 PM
pitcelica Here's a place where you can find a 3rd gen ex... Apr 26, 2015 - 8:16 AM
toy8490 Thank you for the site link for the exhaust flange... Apr 28, 2015 - 9:52 AM
toy8490 Started and mostly finished my own built header, I... May 7, 2015 - 9:52 AM
bsamps4 Where did you buy the piping? Looks good! May 7, 2015 - 11:48 AM
toy8490 QUOTE (bsamps4 @ May 7, 2015 - 11:48... May 7, 2015 - 1:40 PM
toy8490 Removed the header so i can weld it up, May 8, 2015 - 9:33 AM
bsamps4 Good lord man! I'd never be able to get a ... May 9, 2015 - 10:09 AM![]() ![]() |
| Lo-Fi Version | Time is now: August 21st, 2026 - 3:50 PM |
