> 5sgte rwd conversion
post Apr 16, 2014 - 6:34 PM
toy8490
Joined Nov 15, '10
From ABERDEEN WA
well i've started what most people dont have time for. I'm in the middle of building my 5sgte and Rwd conversion,
I have a couple pictures to start with. If you have any question, just ask.
I'm using a 88 toyota truck rear end 2wd. This rear end is harder to find, because it uses the 8 inch center section. And that comes with 30 spline axles. I'm not using the third member. I went with a toyota v-6 4x4 3rd member, that will allow you to buy a supra lsd that will bolt into the v-6 housing. I'm going to be using the stock v-6 gears that comes with 4.10 gears, It may be a little high, but i'll run those for a little bit. Also when i have the lsd out, i'm install a WEIR MAXGRIP LSD Kits
It increases the locking force of the clutches. So i'll be posting pictures as i go.
This post has been edited by toy8490: Apr 16, 2014 - 6:43 PM
- toy8490   5sgte rwd conversion   Apr 16, 2014 - 6:34 PM
- - toy8490   Fitting the engine and transmission, Dont worry, t...   Apr 16, 2014 - 7:18 PM
- - toy8490   I'll be using a 1990 ford mustang rack and pin...   Apr 16, 2014 - 7:25 PM
- - Fate   looking forward to this build, awesome work thus f...   Apr 16, 2014 - 8:03 PM
- - JoshuaM   Wow, that's awesome!!!   Apr 16, 2014 - 8:36 PM
- - smkr3w   Should be awesome. Definitely going to watch this...   Apr 16, 2014 - 8:57 PM
- - cardshark525   At least she'll have a low center of gravity ...   Apr 16, 2014 - 9:05 PM
- - playr158   if you're using the 5sfe block, what transmiss...   Apr 16, 2014 - 9:18 PM
- - cheela   subscribed!   Apr 16, 2014 - 9:28 PM
|- - toy8490   QUOTE (cheela @ Apr 16, 2014 - 10:28...   Apr 16, 2014 - 10:59 PM
- - Smaay   i believe that is an R154 transmission or is it t...   Apr 16, 2014 - 11:04 PM
- - Box   R154 was in the Supra Turbo, W58 was in the non tu...   Apr 17, 2014 - 1:19 AM
- - ILoveMySilly97   Nice. A 5sgte that's something uncommon and es...   Apr 17, 2014 - 2:12 AM
- - playr158   W58 requires a 2s bell housing to mount to the 5s/...   Apr 17, 2014 - 8:12 AM
- - njccmd2002   this is finally happening. RWD conversion... YA...   Apr 17, 2014 - 9:04 AM
- - toy8490   The transmission is very close to a r154. The tran...   Apr 17, 2014 - 9:40 AM
- - 94GreenLantern   NICE! pictures of rear from underneath?   Apr 17, 2014 - 9:47 AM
- - mkernz22   Now this is something I might have to do in the fa...   Apr 17, 2014 - 12:03 PM
- - toy8490   Heres a picture of the suspension, Not very bright...   Apr 17, 2014 - 1:29 PM
- - sandusky1977   If you're going through all that effort, why s...   Apr 17, 2014 - 2:08 PM
- - toy8490   This 4 cylinder that i'm building will be ligh...   Apr 17, 2014 - 2:14 PM
- - richee3   Very cool stuff. Will this be a DD, track car, dr...   Apr 17, 2014 - 2:16 PM
|- - Box   QUOTE (richee3 @ Apr 17, 2014 - 2:16...   Apr 17, 2014 - 2:26 PM
|- - toy8490   QUOTE (richee3 @ Apr 17, 2014 - 3:16...   Apr 17, 2014 - 3:59 PM
- - toy8490   Heres some more pictures, with the engine all clea...   Apr 18, 2014 - 1:54 PM
- - CrossCudi   AWESOME !   Apr 18, 2014 - 2:05 PM
- - Box   I wonder how such a severe tilt will effect things...   Apr 18, 2014 - 3:31 PM
- - SupraKid   *Thinks dirty, dirty 2jzgte thoughts*   Apr 18, 2014 - 5:01 PM
- - toy8490   Heres some pictures of the rear suspension The su...   Apr 19, 2014 - 10:05 AM
- - toy8490   Now heres some pictures of the steering and engine...   Apr 19, 2014 - 10:17 AM
- - team_omega   Its looking good. You want to do mines after your...   Apr 19, 2014 - 10:48 AM
|- - toy8490   QUOTE (team_omega @ Apr 19, 2014 - 11...   Apr 19, 2014 - 3:54 PM
- - kormysh8   I can't wait to see the final product. I'v...   Apr 19, 2014 - 10:19 PM
- - PR0PH37   Wow. I don't know what the heck I'm lookin...   Apr 19, 2014 - 11:19 PM
- - njccmd2002   one questions, those tie rods will be under pressu...   Apr 20, 2014 - 7:57 AM
|- - toy8490   [quote name='njccmd2002' date='Apr 20,...   Apr 20, 2014 - 10:50 AM
- - toyota123   I have to say I'm very intrigued by what you a...   Apr 20, 2014 - 10:09 AM
- - LimitedGT4   Sweet. I was planning on doing somethin like thi...   Apr 25, 2014 - 8:49 PM
- - toy8490   Getting closer. Got the struts mounted, so that it...   May 5, 2014 - 3:13 PM
- - toy8490   I dont know if this is the same pictures as from b...   May 5, 2014 - 3:20 PM
- - Smaay   the R154 must have been in the MKIII because the M...   May 5, 2014 - 3:49 PM
|- - mgnt232   QUOTE (Smaay @ May 5, 2014 - 4:49 PM...   May 5, 2014 - 4:26 PM
|- - toy8490   QUOTE (Smaay @ May 5, 2014 - 4:49 PM...   May 5, 2014 - 9:29 PM
- - Smaay   no i dont read everything, i dont need to read 3 w...   May 5, 2014 - 9:59 PM
- - cardshark525   Franken-build progressing nicely. A rwd 6gc runni...   May 5, 2014 - 10:32 PM
- - toy8490   i'll be uploading more updates tomorrow of my ...   May 11, 2014 - 10:38 PM
- - toy8490   Well was almost done, had the complet dash inside ...   May 12, 2014 - 12:34 PM
- - Special_Edy   Im far from being an expert, and Im having difficu...   May 12, 2014 - 2:09 PM
- - toy8490   Here some more progress pictures, motor mounts / t...   May 15, 2014 - 10:00 AM
- - njccmd2002   wow this is significant progress.   May 15, 2014 - 11:52 AM
- - Malek   Seriously! ^^ This is some good stuff!   May 15, 2014 - 1:54 PM
- - ClevelandGaint   I want this   May 15, 2014 - 3:47 PM
- - playr158   its crazy.....its impractical.....its freaking awe...   May 15, 2014 - 9:29 PM
- - jeffrosie   Awesome build M8. Was just thinking, why not use t...   May 16, 2014 - 6:04 PM
- - Special_Edy   Naw he should use the straight axle. Maybe get a s...   May 16, 2014 - 7:13 PM
- - lagos   Impressive project!   May 17, 2014 - 9:46 AM
- - toy8490   I hope you guys are ready for this, I'm gettin...   May 31, 2014 - 11:31 PM
- - toy8490   Picture time, I love it. I'm going ...   May 31, 2014 - 11:38 PM
- - Box   It's so weird seeing the engine longitudinally...   May 31, 2014 - 11:50 PM
- - BonzaiCelica   wow at that point why not fit the intake manifold ...   Jun 1, 2014 - 3:25 PM
- - playr158   So much awesome.   Jun 1, 2014 - 7:39 PM
- - Batman722   IC piping is gonna be funky. I see a lot of lag co...   Jun 1, 2014 - 8:20 PM
|- - LimitedGT4   QUOTE (Batman722 @ Jun 1, 2014 - 8:2...   Jun 1, 2014 - 8:26 PM
- - toy8490   I already have the front mount Intercooler from my...   Jun 2, 2014 - 6:20 PM
- - toy8490   got the intake modified, it fit perfect.   Jun 23, 2014 - 12:45 AM
- - njccmd2002   dang... thats a nasty beautiful intake..... glad ...   Jun 23, 2014 - 11:48 AM
- - Malek   truth ^^ This thing is sweet   Jun 23, 2014 - 4:23 PM
- - ricochet1490   nicely done. I appreciate the fabrication here.   Jul 6, 2014 - 8:11 PM
- - dudeofchaos   Woww. I wanted to do this for years with my st204 ...   Jul 14, 2014 - 5:02 PM
- - BonzaiCelica   update? so rare!   Jul 28, 2014 - 2:05 PM
- - HaysoosKreesto   wow, it's like you took every st204's fant...   Jul 28, 2014 - 5:17 PM
- - toy8490   I just now got the car running today, Just have to...   Aug 20, 2014 - 2:16 PM
- - Box   I can't believe you think this is taking awhil...   Aug 20, 2014 - 3:40 PM
- - IllIllIll   When I first saw the thread I assumed that this wo...   Aug 30, 2014 - 9:39 AM
|- - toy8490   QUOTE (IllIllIll @ Aug 30, 2014 - 9...   Oct 12, 2014 - 1:57 PM
- - mkernz22   RE: 5sgte rwd conversion   Oct 12, 2014 - 2:11 PM
- - toy8490   I hope this works http://vid266.photobucket.com/a...   Oct 12, 2014 - 9:50 PM
|- - toy8490   QUOTE (toy8490 @ Oct 12, 2014 - 9:50...   Oct 17, 2014 - 9:54 AM
- - Syaoran   oh boy   Oct 12, 2014 - 9:52 PM
- - mkernz22   That a$$ end is way high!   Oct 12, 2014 - 11:13 PM
- - HaysoosKreesto   That sound makes my face look like that Kim Kardas...   Oct 12, 2014 - 11:22 PM
- - enderswift   holy crap you finished O.O good work!   Oct 13, 2014 - 12:06 AM
- - kurt95gt   This is crazy! Love it!   Oct 14, 2014 - 12:44 PM
- - SwissFerdi   Nice! Good on you, man. You've done what 9...   Oct 15, 2014 - 10:11 AM
- - njccmd2002   And people, lot of people, i mean lots of people. ...   Oct 16, 2014 - 5:54 PM
|- - Box   QUOTE (njccmd2002 @ Oct 16, 2014 - 5...   Oct 16, 2014 - 6:38 PM
- - Arturio55   This makes the awd conversion look as simple as dr...   Oct 16, 2014 - 6:51 PM
- - HaysoosKreesto   Worked for me   Oct 17, 2014 - 9:59 AM
- - Smaay   impressive work.... how are you going to do the i...   Oct 26, 2014 - 8:09 PM
- - toy8490   I'm planning on doing my own header and new tu...   Oct 27, 2014 - 3:53 PM
- - toy8490   Looking to buy a gt35 twin scroll turbo, I'll ...   Apr 2, 2015 - 9:56 AM
- - toy8490   New turbo has made it here. Time for some work now...   Apr 21, 2015 - 9:36 AM
- - toy8490   I removed the factory turbo, (which is for sale) ...   Apr 25, 2015 - 1:20 PM
- - pitcelica   Here's a place where you can find a 3rd gen ex...   Apr 26, 2015 - 8:16 AM
- - toy8490   Thank you for the site link for the exhaust flange...   Apr 28, 2015 - 9:52 AM
- - toy8490   Started and mostly finished my own built header, I...   May 7, 2015 - 9:52 AM
- - bsamps4   Where did you buy the piping? Looks good!   May 7, 2015 - 11:48 AM
|- - toy8490   QUOTE (bsamps4 @ May 7, 2015 - 11:48...   May 7, 2015 - 1:40 PM
- - toy8490   Removed the header so i can weld it up,   May 8, 2015 - 9:33 AM
- - bsamps4   Good lord man! I'd never be able to get a ...   May 9, 2015 - 10:09 AM
6 User(s) are reading this topic (6 Guests and 0 Anonymous Users)
Lo-Fi Version Time is now: August 21st, 2026 - 10:21 PM
