> Radiator fans.., thin ones
post Aug 11, 2014 - 8:57 PM
anyone have a setup they recommend. Im running out of space in the bay, may need on thin fan.... any ideas?
post Aug 11, 2014 - 9:14 PM
Box
Joined Feb 23, '12
From Warrior, AL
Maybe this? http://www.mishimoto.com/mishimoto-slim-li...tor-fan-12.html
This post has been edited by Box: Aug 11, 2014 - 9:14 PM
2001 Miata LS 5-speed
post Aug 11, 2014 - 9:39 PM
thanks.!!!
post Aug 11, 2014 - 10:16 PM
Box
Joined Feb 23, '12
From Warrior, AL
Welcome!
post Aug 11, 2014 - 10:25 PM
problem. cant find a proper shroud! do they just bolt in?
post Aug 12, 2014 - 2:45 PM
Box
Joined Feb 23, '12
From Warrior, AL
Says they can be mounted on any convenient location on the radiator. It's hard to tell from the picture, but I think it has an integrated shroud/casing thing going on.
post Aug 12, 2014 - 5:19 PM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
エキサイティングカーレーシングチーム!
post Aug 13, 2014 - 3:53 AM
BonzaiCelica
Joined Apr 24, '08
From Orange County, CA
QUOTE (BonzaiCelica @ Jun 17, 2012 - 6:22 PM) *
before I had these universal 14 inch fans just attached to the radiator with zip ties. Now I've made brackets :
post Aug 13, 2014 - 7:27 AM
mmh, i rather have a shorud, but thanks for the idea..
post Aug 13, 2014 - 7:52 AM
Syaoran
Joined Jan 4, '12
From US
QUOTE (njccmd2002 @ Aug 13, 2014 - 8:27 AM) *
A shroud for slim fans is a custom DIY job.
1993 Celica GT Coupe - sold
1994 Celica GT Liftback
post Aug 14, 2014 - 6:23 AM
chacha
Joined Dec 29, '05
From So-Cal
come on...this is a challenge for those can make one and sell me one as well...not much markets for celica...having a shroud for the mitismoto rad would be a nice add-on
post Aug 15, 2014 - 7:44 AM
Special_Edy
Joined Oct 29, '11
From Haltom City, Texas
Summit racing sells shrouds I think.
If I were you I would order a plate of 1/16" aluminum from some place like metaldepot.com. You should be able to get a 2'×3' for maybe $30, dont quote me on that. If you order some angle aluminum, like 10' long with 1" wide sides or less, you could get that for around $10. Then you can use industrial adhesive, rivets, bolts or welds to attach the angle aluminum around the perimeter of the plate. Cut out holes in the plate for the fans to sit and you have a professional quality all aluminum shroud.
This post has been edited by Special_Edy: Aug 15, 2014 - 7:45 AM
post Oct 25, 2014 - 7:50 AM
bringing back from the dead, has anyone mounted these fans on the other side of the radiator. I need the space. cannot find any pics on the site.
do you have to reverse the fan direction, or does it even matter?
post Oct 25, 2014 - 1:25 PM
you can mount them on the outside, but the a/c condenser may interfere.
post Oct 25, 2014 - 1:27 PM
Box
Joined Feb 23, '12
From Warrior, AL
Hmm, don't see why you couldn't mount on the outside. You'd want it to push outside air in, instead of trying to suck the hot air out.
post Oct 25, 2014 - 1:33 PM
Box
Joined Feb 23, '12
From Warrior, AL
That and you could try running a 70/30 mix to help keep it cooler.
post Oct 25, 2014 - 2:21 PM
if you think about it, you need to circulate air to the fins.
when you drive, the air is being pushed in from the front. Do the fans push air against this, or do they suction air faster ( pretty stupid question, as i should know, but i dont.)
i just need space on the half passenger side. i just have none....
post Oct 25, 2014 - 3:10 PM
Bigblock
Joined Feb 14, '09
From Mid West
Fans behind the radiator "suck " air
In front, they push air
Bitter
Joined Mar 11, '06
From Way South Chicago
Fans inside let air flow through when driving, fans outside tend to block airflow when driving some. You can shroud the bumper to force more air through the radiator when driving. Generally slim fans don't move as much as they sound like they do since the slim blades often spin too fast and just chop up the air instead of moving it, however the stock radiator fan controls have variable speed operation so they'll be running lower speed most of the time. Can you run one pusher and one puller? A puller on the side away from the headers and a pusher on the side with the headers. I bet even a double thick half rad with a push and pull fan would work pretty well, halving the length but doubling the thickness is just as good usually, though you do need more airflow for a thicker core so slim fans may not move air as well as regular shrouded fans.
post Oct 25, 2014 - 3:42 PM
Box
Joined Feb 23, '12
From Warrior, AL
May have to use a GT-Four front end or the like to let enough air in to cool things off.
Lo-Fi Version Time is now: September 16th, 2026 - 10:52 AM
