14 Pages V  « < 2 3 4 5 6 > »
> how to swap a 2grfe V6 into a st204, Toyota reliability, with less moving parts than a turbo
post Oct 23, 2014 - 9:32 AM
My cars now and my last car were all drive by wire.
I have to say I miss direct throttle cable soooo much. The only good drive by wire car i've driven extensively is the E46 M3 otherwise.
Are you keeping AC?
post Oct 23, 2014 - 11:29 AM
Yes. Everything will work. Crossing fingers
post Oct 23, 2014 - 12:43 PM
Syaoran
Joined Jan 4, '12
From US
DBW is bad on stock ECUs. On standalones however it's nearly the same as cable throttle. It responds just as fast, but the direct link feel is lost, because the pedal almost always has less resistance to it.
1993 Celica GT Coupe - sold
1994 Celica GT Liftback
post Oct 23, 2014 - 2:40 PM
QUOTE (Syaoran @ Oct 23, 2014 - 12:43 PM) *
True. But 275 hp in n/a. With spare parts stateside is appealing to me..
post Oct 23, 2014 - 7:02 PM
Bitter
Joined Mar 11, '06
From Way South Chicago
post Oct 23, 2014 - 11:42 PM
perkyshadow
Joined Nov 13, '10
From Greenville, SC
QUOTE (njccmd2002 @ Oct 23, 2014 - 10:14 AM) *
thanks. 2grfes dont use cable throttles. they are drive by wire and use a specific pedal..
You are a crazy man. Crazy genius. But still crazy! I honestly can't even imagine the work just to do the pedal! I'm going to have to come to TN so see this beast when it is finished!
post Oct 24, 2014 - 7:22 AM
QUOTE (Bitter @ Oct 23, 2014 - 7:02 PM) *
I will leave the pedal alone, i dont want it getting stuck.
QUOTE (perkyshadow @ Oct 23, 2014 - 11:42 PM) *
the bracket itself took 7 hours, give or take 2. because i had no idea of the positioning of the pedal, so it was trial and error. now that i have a basic idea, should be quicker.
This swap is slow, because im collecting parts as i go. If i break one barrier, i move on to the next. remember, i had no idea the engine would fit in the bay, it would have been a 2700$ loss for me... ( there are cheaper, but not with less than 25K miles and complete with all accessories).
this is the bracket on the car...
DSCN1377
of course had to make sure that
DSCN1376
i used long bolts, and thread locker... Do not want to get loose on me.. Same went for the pedal...
DSCN1378
and next task, will be to find out if these go in with no problem...
DSCN1379
hate to take a loss on them.....
This post has been edited by njccmd2002: Sep 21, 2017 - 12:07 AM
post Oct 24, 2014 - 7:45 AM
perkyshadow
Joined Nov 13, '10
From Greenville, SC
QUOTE (njccmd2002 @ Oct 24, 2014 - 8:22 AM) *
Man, I hope they fit! It looks crazy tight already!
post Oct 24, 2014 - 9:10 AM
Syaoran
Joined Jan 4, '12
From US
Good vibes, hope they fit
post Oct 24, 2014 - 11:39 AM
Box
Joined Feb 23, '12
From Warrior, AL
Make them fit!
2001 Miata LS 5-speed
post Oct 24, 2014 - 11:58 AM
bloodMoney
Joined Aug 4, '06
From Chicagoland
Are those the Gouky headers?
~bloodMoney
post Oct 24, 2014 - 7:21 PM
teaser for tonight, guokys header.....
DSCN1385
im to lazy to post...
This post has been edited by njccmd2002: Sep 21, 2017 - 12:18 AM
post Oct 24, 2014 - 8:09 PM
Box
Joined Feb 23, '12
From Warrior, AL
post Oct 24, 2014 - 8:11 PM
Bitter
Joined Mar 11, '06
Won't you throw automatic transmission DTC's with the PCM for the 2GR, or did your 2GR come from a manual car?
post Oct 24, 2014 - 9:07 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
yes he will, the only car with a 2GR thats a manual is the Lotus Evora. Most of the AT codes can be defeated except one. The MR2 guys have been fighting it for years.
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Oct 24, 2014 - 9:23 PM
Bitter
Joined Mar 11, '06
And that puts the engine in limp too, doesn't it?
post Oct 25, 2014 - 6:05 AM
to answer the questions...
1. I know how the rears fit... wont say for now..
2. Yes i will throw a code..
3. it wont put the engine on limp, otherwise i would not have done swap.. (mr2 guys have all of it covered.)
post Oct 25, 2014 - 3:12 PM
Bitter
Joined Mar 11, '06
I remember a fellow with a MZ in their MR2 that was doing funky things with an auto PCM, pulling timing at certain RPM's and I think it was related to the codes thrown.
post Oct 25, 2014 - 3:36 PM
Box
Joined Feb 23, '12
From Warrior, AL
At some point wouldn't it just be easier to use a standalone than to bother with the factory ECU?
post Oct 26, 2014 - 8:13 AM
QUOTE (Box @ Oct 25, 2014 - 3:36 PM) *
2 points.
1. yes if you live in an area that does not do obd2 checks.
2. It has not been fully developed yet. So i would rather be safe for now, than sorry, than to blow an engine. I cant tune, and wont be paying hundreds to get it tuned, nor do i have a dyno near.
Lo-Fi Version Time is now: September 14th, 2026 - 1:47 AM
