400 Pages V  « < 376 377 378 379 380 > »
> Teh Official "Dude Where's My Forum?" Thread, Brought to you by the minds of Box, and her fiancée, Lorelei
post Sep 12, 2020 - 8:27 PM
Box
Joined Feb 23, '12
From Warrior, AL
QUOTE (Bitter @ Sep 12, 2020 - 8:17 PM) *
And now it'll have Casey's package, heyooo. /thread.
Actually, I have casey's package.
-Lorelei "Nice Shift Kit, Hun" Moira
2001 Miata LS 5-speed
post Sep 12, 2020 - 8:37 PM
Box
Joined Feb 23, '12
From Warrior, AL
Wao...
That's ok, trying to figure out how to get the o.e. wheels home since they still have tires mounted on them.
post Sep 12, 2020 - 9:50 PM
Bitter
Joined Mar 11, '06
From Way South Chicago
Ok but seriously. Two side by side behind the seats, one in the passenger seat, and one in the 'trunk'. No?
Woot, found a scrap of the right size oil cooler hose in my basement junk. I can finish bending the aluminum lines and get the the thing installed tomorrow then run the car and check for leaks. I'm a bit worried that the 3/8th compression fittings feel a little loose around the tubes. I think they'll be ok, I've not slid ferrules on larger tubes like these so worst case I need to get flare fittings somewhere tomorrow I guess or figure something else out. Also debating on if I should run a stat on the cooler or not. I'm thinking no since it's a warm weather car. Another idea I had was to get an inline switch that's like 180 on and 160 off (most common temps) and have it drop ground to the radiator fan low speed relay to kick that fan on for trans temp but with the size of the cooler I doubt that'll be needed. Trans does have a thermistor inside it, but I haven't (yet) been able to find a temp-resistance chart for it so I can measure fluid temps accurately inside the trans.
Woot, figured out which code has two points of temp to resistance correlation, I can assume it's a linear thing and plot out a chart. Does anyone make a handy little temp display that's programmable?
This post has been edited by Bitter: Sep 12, 2020 - 10:39 PM
post Sep 12, 2020 - 10:32 PM
Box
Joined Feb 23, '12
From Warrior, AL
Well, the o.e. suspension will go into the trunk. Which if they were bare wheels it'd make life a lot easier, but it is what it is.
post Sep 13, 2020 - 10:25 AM
Bitter
Joined Mar 11, '06
Wait, are you just floating over on a cloud or something? Have whomever is driving you take some stuff back in their car!?
post Sep 13, 2020 - 10:42 AM
Box
Joined Feb 23, '12
From Warrior, AL
QUOTE (Bitter @ Sep 13, 2020 - 10:25 AM) *
Haha, feels like it. He said he'd wrap the wheels in garbage bags so then I don't have to worry about getting mom's car dirty. He also cleaned the Miata and sent me a pic just now:
post Sep 13, 2020 - 12:37 PM
Bitter
Joined Mar 11, '06
That looks good, not crazy about the tan top.
post Sep 13, 2020 - 5:25 PM
Buy it and don’t look back. I threw some Rotella in mine today, have yet to drive it but she usually runs better with fresh dino oil.
Also treated myself to a nice Corsair headset. Lows are a little disappointing, but otherwise the audio is very crisp. Simulated 7.1 is very nice for gaming, I can hear noobs in CSGO doing circles now. Feels built like a Volvo too, and very padded.
'90 MX-5 Mariner Blue
'15 Optima Grey
'04 206 GTi silve
post Sep 13, 2020 - 7:43 PM
Box
Joined Feb 23, '12
From Warrior, AL
Turns out it actually has 64K miles on it, so even better! Super nice guy and very helpful, absolutely the best car buying experience I've ever had! It has Dunlop Direzza DZ102 with plenty of tread left, very nice tires! The Bilstein/Fat Cat motorsports coil-overs ride great too! A bit nicer than the stock Shinsen my brother had actually. Took me awhile to get used to not having gobs of torque though, but I absolutely love it already! Some quick pics:
post Sep 14, 2020 - 12:28 AM
TimeslideZ
Joined Jun 9, '16
From Minnesota
Looks good for the age! What's the plan for it?
post Sep 14, 2020 - 7:01 AM
Box
Joined Feb 23, '12
From Warrior, AL
QUOTE (TimeslideZ @ Sep 14, 2020 - 12:28 AM) *
Thanks! Drive it! At some point I'd like to have the seats recovered though. Maybe vinyl wrap it purple. For now the only "mods" I plan on doing is swapping out the headlights for 9011/9012 bulbs and finding a good festoon LED for the courtesy light.
post Sep 14, 2020 - 7:18 PM
Has a 1.8, bitches about lack power. But congratulations. Looks like a nice set of go-fast parts as well.
'15 Optima Grey
'04 206 GTi silve
post Sep 14, 2020 - 7:55 PM
Box
Joined Feb 23, '12
From Warrior, AL
QUOTE (SwissFerdi @ Sep 14, 2020 - 7:18 PM) *
I really wasn't complaining it was just an observation in how it took me a bit to adjust, e.g. starting from a stop and climbing hills vs the Firebird. Trust me I'm MUCH happier with it as a whole. Thanks! The wheels, tires, and suspension make for a nice improvement over the Shinsen my brother had that I drove a few times.
I spent earlier carefully removing the camera and phone mounts off the dash, then used the last of my citrus air freshener to set the atmosphere. Then the plate/trunk lights broke trying to remove them to put in some LEDs I had, but I found some LED housings on eBay that're a direct replacement and ordered those.
post Sep 14, 2020 - 10:25 PM
Bitter
Joined Mar 11, '06
https://linustechtips.com/main/uploads/mont...4384d850d07.jpg
It's mounted, it's mostly plumbed, I could have gone bigger right?
post Sep 15, 2020 - 12:11 PM
Box
Joined Feb 23, '12
From Warrior, AL
You should've 6-speed swapped it, then wouldn't need a trans cooler. wink.gif
I suspect there's a stage 2 clutch in the Miata, as the clutch is grabbier with shorter travel and a firmer pedal than either my NA6 or the NB2 my brother had.
post Sep 15, 2020 - 12:35 PM
Bitter
Joined Mar 11, '06
Oh Lord I would need...
Clutch kit
Flywheel
A good C60 trans
Limited slip
Probably different axles
Shift cables
Shifter
Shifter base
Center console surround
Shift boot
Shift knob
Clutch slave
Clutch pedal assembly
Clutch master
Lines
Reservoir
ECU
Gauge cluster
And probably a few things I'm forgetting.
It would be a huge investment of time and money and totally change the character of the car and take away one of it's most unique quirks. Not saying it would be a bad thing, it would be great but I just don't think I'll ever do that unless the auto trans breaks and that's the cheaper option over fixing the auto.
post Sep 15, 2020 - 1:18 PM
Box
Joined Feb 23, '12
From Warrior, AL
QUOTE (Bitter @ Sep 15, 2020 - 12:35 PM) *
Clutch kit
Flywheel
A good C60 trans
Limited slip
Shift cables
Shifter
Shifter base
Shift boot
Shift knob
Clutch slave
Clutch master
Lines
Reservoir
ECU
Gauge cluster
Fair enough.
Was looking around at LEDs on Amazon, so who's the go to these days? Figured I'd ask you since you always seem to know what's best at the moment. As much as I'd like to do amber for the courtesy light, it's the only bulb in the interior so perhaps I should just go with blinding white. Though the factory lens is tinted for whatever reason.
post Sep 15, 2020 - 2:03 PM
Box
Joined Feb 23, '12
From Warrior, AL
From searching around seems like this Sirius LED might be the way to go? Hmm...
post Sep 15, 2020 - 3:10 PM
Bitter
Joined Mar 11, '06
Possibly, link some you're looking at and I'll check them out when I'm home.
post Sep 15, 2020 - 3:19 PM
richee3
Joined Jun 29, '08
From Denver
I think I have some Sirius LED’s in my Lexus. If not the Lexus then Brigette’s Rav, one or the other. I won’t call them great but they’re decent. It’s been over a year in the Rav and 11 months in the Lexus with no flickering. They’re just a little more blue than I would like and about 90% as bright as I would like but overall no complaints. I have a bunch of Yorkim LED’s from Amazon too and there’s no difference between the Sirius or Yorkim LED’s in either car, hence why I can’t remember which ones are there. I still prefer Diode Dynamics (although the fog lights are awful) but for the price, I’m satisfied with the Sirius LED’s.
Reference of why to not get Diode Dynamics LED fog lights. Yes, this picture is accurate. No, you can’t really tell that they’re even turned on. Yes, I do have 194’s that are brighter.
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
13 User(s) are reading this topic (13 Guests and 0 Anonymous Users)
Lo-Fi Version Time is now: April 9th, 2026 - 11:49 PM
