> DCW Triple Gauge Pod Installation Question, Routing the wires
post Jan 1, 2015 - 4:03 PM
msk59
Joined May 10, '14
From Tulsa, OK
Hello all: For those who have installed the triple gauge pod on the dash above the vents. How do you run the wires from the gauges through the dash. In other words, what is the best way to run the wires without drilling a hole on the top of the dash? A picture would help.
Thanks
This post has been edited by msk59: Jan 1, 2015 - 4:24 PM
post Jan 1, 2015 - 9:25 PM
msk59
Joined May 10, '14
From Tulsa, OK
Anyone ?
post Jan 2, 2015 - 2:29 AM
igpx12
Joined Jan 30, '14
From Cortland NY
This is how I ran my gauge wires, you don't have to drill or anything to run the wires through the crease line, only thing is you have to deal with wires showing.
This post has been edited by igpx12: Jan 2, 2015 - 2:30 AM
1997 ST:Limitedly Green
This car is not about racing... This car is not about power or performance... It's purely about being cool.
post Jan 2, 2015 - 8:00 AM
msk59
Joined May 10, '14
From Tulsa, OK
Thanks for the picture jgpx12 but i have the one that will go on top of the dash above the clock and vents.
post Jan 2, 2015 - 8:41 AM
malpaso
Joined Feb 3, '06
From Czech Republic (Europe)
I got those and wires just squeezed between dash and removable center panel. It's like this many years. No issues.
post Jan 2, 2015 - 8:44 AM
igpx12
Joined Jan 30, '14
From Cortland NY
QUOTE (msk59 @ Jan 2, 2015 - 8:00 AM) *
Kinda like mine you could run the wires at the top of the center bezel right where the crease is above the vents. I would say to see about running it through the vents on the top of the dash, however you would have to take your dash out and drill a hole through your vent duct under the dash. If you wanted to hide your wiring somewhat that would be the way to go but if your looking for an easier install with no drilling, running it through one of the panel creases is your best bet.
post Jan 2, 2015 - 9:00 AM
msk59
Joined May 10, '14
From Tulsa, OK
Got it thanks very much. I would like to do a clean install.
Lo-Fi Version Time is now: August 27th, 2026 - 7:38 AM
